Pre production sample [Review] Astrolux MF-01 4x18650 flashlight supplied by Banggood
181 posts / 0 new
steel_1024
steel_1024's picture
Last seen: 1 week 4 days ago
Lexel wrote:
can you confirm it fits the light?
Yes, very perfect
Sorry for my poor english.
thegameisrigged
Last seen: 2 years 5 months ago
Where’s the beamshots?
JasonWW
JasonWW's picture
Last seen: 4 hours 52 min ago
Post #2.
steel_1024
I try to make another use of the NarsilM firmware driver.
Not working properly still.
After installing the battery, direct light high, and then will not light up again.
7135 using A705NGT-350 SOT-89
Flash firmware on Attiny85
FET 404
85fuses.bat:
REM BOD disabled:
Wp hvc
REM BOD enabled at 1.8V:
Avrdude -p t85 -c usbasp -Ulfuse: w: 0xe2: m -Uhfuse: w: 0xde: m -Uefuse: w: 0xff: m
85M.bat:
Rem 85NarsilM – downloads NarsilM (Tiny85 Multi-channel e-switch UI configurable)
Rem
Avrdude -p t85 -c usbasp -u -Uflash: w: NarsilM.hex: a
All 100%
Tom E
Tom E's picture
Last seen: 52 min 47 sec ago
I'm responding on the NarsilM thread.
Ronin42
Ronin42's picture
Last seen: 11 months 3 weeks ago
hIKARInoob wrote:
Edit:
Based on the run time data, I see a possibility that the light steps down aggressively when reaching 60 C to the 1100 lumen mode (for the Nichia version), and stays there until batteries are depleted. So there is no feedback control for output as a function of temperature.
If so it’s a bit unfortunate that there is no 2500~3000 lumen mode where the light can sustain output fairly continuously.
+1
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
steel_1024
NarsilM V1.0,Ramping TEST
Chinese:
Lexel
Lexel's picture
Last seen: 1 day 16 hours ago
I did today a measurement of the beam intensity of this light
measured @5m 2080 Lux cold start
so I get 52000 Lux @1m for the Nichia pre production light
this is just the Luxmeter set to show save max.
starting the light, 3 clicks to highest mode
then move the light a bit to get its peak output
hIKARInoob
hIKARInoob's picture
Last seen: 1 day 21 hours ago
Two big thumbs up! Big Smile
hIKARInoob
Is there a likeliness that the driver spring might bend when tightening the battery tube, causing a short? Something similar happened with an Acebeam K70 here: http://www.candlepowerforums.com/vb/showthread.php?436281-Should-I-be-sc...
What do you guys think?
Lexel
Lexel's picture
This can not happen with the MF01
I did not show a picture from the driver with the insulator inserted
Basically the platic insulator you see on the carrier here fits inside the insulator on top of the driver the distance between spring and ground is 12.5mm, also there is no ground spring
And the distance between pisitive spring and the ground ring is 12.5mm
hIKARInoob
Aha, thanks. It’s a plastic ring on the driver side. The picture on the Banggood site showing the three parts, head, battery tube and tailcap, made me worry it might be aluminium.
hIKARInoob
Ugh… First video of busted MF01
The_Flashaholic
The_Flashaholic's picture
Last seen: 3 days 6 hours ago
SteveMidwest wrote:
My thoughts exactly WTF (and hIKARInoob). You hit the nail on the head! Cool
Acebeam is really good at having a mode on its line of flashlights, that hits its heat dissipation sweet spot, exactly.
Take the newer X45 for example. Capable of putting out a total of about 16,500 lms. On high, which is a 4000 lm level. It can be turned on at that level, and it will stay there, with no step-downs, for 1.4 hours. At which point, the batteries can no longer maintain that output.
Even on the newest Acebeam X80. Which is a smaller sized flashlight, but capable of putting out approximately 25,000 lms. They pushed it even harder. In the high mode, when the flashlight is cool, and the battery levels are full. That flashlight can be turned on in high mode, and run at 5000 lms for 20 minutes, and then, it only steps down to 4000 lms. For the remainder of what the batteries can handle.
The Acebeam K60. The same way. Turn that flashlight on in level 6, and it will give you a constant 5000-ish lumens, for over an hour.
I too, would love to see more flashlight manufactures work on getting a ‘sweet-spot’ level figured out, and programmed into their flashlights. That they will maintain, from a cool start.
The EC50 Gen II can hold 1,500 for the duration too, Acebeam really are the daddies.
Can’t wait to see their Nitecore Tip rival.
My 4K Lumen Whore Reviews (MS18, X70, MS12, DX80, X80-GT, X45vn etc) - http://www.youtube.com/c/FLASHAHOLIC_TV
Tom E
Tom E's picture
hIKARInoob wrote:
Ugh... First video of busted MF01
Well, Lexel pointed out the LED's are 3 sets of 2S3P, so has 3 pairs of wires, 3 separate circuits. So either there's a component failure or maybe loose wire in one of the 3 sets of parts and wires.
JasonWW
JasonWW's picture
Tom E wrote:
Well, Lexel pointed out the LED’s are 3 sets of 2S3P, so has 3 pairs of wires, 3 separate circuits. So either there’s a component failure or maybe loose wire in one of the 3 sets of parts and wires.
Not a loose wire as all 3 banks work at the other 4 levels. I’d look over the driver with a magnifying glass to see if a resistor or some other part was burned or not soldered properly. I don’t know if it uses 7135 current chips, but if it did, it could be a bad one of those on the bank that doesn’t work.
Tom E
Tom E's picture
Dunno, I was pretty blinded by the light - I could not make out bumping thru modes. No clue, no description by the poster. Only the lowest mode?
Mine is in the US some where, on the way from west to east... frown
Tom E
Tom E's picture
Lexel - is the MF01.ZIP board a go, and tested? It looks dated August 27th on OSHPark here. I see steel_1024 used an earlier version - seemed ok, not sure.
Let me know - I'd like to order them. Thanks!
JasonWW
JasonWW's picture
Tom E wrote:
Dunno, I was pretty blinded by the light – I could not make out bumping thru modes. No clue, no description by the poster. Only the lowest mode?
Yeah, only on the lowest level.
Tom E wrote:
Lexel – is the MF01.ZIP board a go, and tested? I see steel_1024 used an earlier version – seemed ok, not sure.
Let me know – I’d like to order them. Thanks!
On Lexels 4th batch page he says he can make them. One other person wanted one, but I think he was looking for at least 3 buyers for Oshpark, because he has to order 3.
Tom E
Tom E's picture
No, not interested in an assembled board. Been building dozens of my own, ordered probably about 100 OSHPark boards by now since February 2014.
I've had issues on the 7135 channel on my other high amp 2S cell builds: 16X XHP50 and MT03 with 3 XHP70.2's. Not completely resolved, been getting help from DEL. Dunno if Lexel has built anything true high amps in 2S, meaning maybe 20K lumens and up.
Lexel
Lexel's picture
I’ve had issues on the 7135 channel on my other high amp 2S cell builds: 16X XHP50 and MT03 with 3 XHP70.2’s. Not completely resolved, been getting help from DEL. Dunno if Lexel has built anything true high amps in 2S, meaning maybe 20K lumens and up.
The board from Oshpark is tested and fits the light
The missing ground on switch pad is fixed and C3 and C4 pads added
hIKARInoob
Another faulty MF01. At this rate the MF01 seems to become a total disaster:
Tom E
Tom E's picture
Ok - even more reason to get a custom driver goin asap!! smile
JasonWW
JasonWW's picture
It seems like the lights weren’t tested before shipping. Not looking good.
Let’s see how Banggood responds.
maukka
maukka's picture
Last seen: 1 day 4 hours ago
I’ll take one NarsilM driver for the MF01 as well.
Tom E
Tom E's picture
The board from Oshpark is tested and fits the light The missing ground on switch pad is fixed and C3 and C4 pads added
Ahh, ok - Thanx! I'll get an order in. My MF01 is still in transit. I'll check it out carefully when it arrives, post some stock #'s.
maukka wrote:
I'll take one NarsilM driver for the MF01 as well.
Finland? Oh boy. Maybe Lexel is gonna build a couple?
hIKARInoob
I’ll figure out myself as well. I’ve got two of those coming my way. Interestingly, it still doesn’t feel like a bad purchase; the price is just too good to take the risk, unlike with an Imalent DT70.
Lexel
Lexel's picture
He uses Meco protected battery
You can see clearly when powering directly to turbo protection kicks in as well when shut off
This is a poor battery fault not the light itself
hIKARInoob
This makes sense. And that’s certainly good news for the MF01. Also kudos to Meco, because their protection is working well.
JasonWW
JasonWW's picture
Nice find.
Why do people think they can install 4,000 mah protected cells in a 12k lumen light? That is false mah rating for sure on those cheap cells.
High current lights need high current cells. Good ones.
