I use Chrome and they translate right away on my laptop, but not on the Android version of Chrome .
BTW, be aware that the zoomie 26650 has only a side switch and the tailcap threads are NOT anodized so there is no easy lockout. That made me not want to use it for the truck light I was thinking of . For a while I carried it with the cell reversed to avoid accidental turn on, but that is a PITA. It now sits on a shelf in the shop for occasional use.
Ya, I’m using google. I tried with chrome and safari but from iOS. I also tried with browser set to desktop. Maybe it’s because of iOS? But u did get there before so, hmm… I’ll need to dig out my computer and try it. I need to do some flashing anyway.
By the way, the two lights I ordered are the real deal! I’m trying to get back to the listings so I know what there called and to order a stack of them.
So… I purchased two lights that I found when viewing the taobao link above. I am trying to recall the purchase as I have lost all memory of it(this happens here and there). This one is frustrating me though as I would like to buy another light but I can’t figure out how I did it.
Whatever I did, I somehow transferred the items to my aliexpress account. If I look at my Ali perchase history they are right there. So how did I pay through my aliexpress acount? Any one have any insight? I will note that I didn’t pay any fees or shipping just $22 and some change for a $12 and $10 light.
I have reenacted the purchase a number of ways. They all require signing up for taobao or alipay or joining the site listed above. I couldn’t have used these methods however as I didn’t sign up for any accounts. I checked my email addresses into by trying password recovery but yielded a return of no acount found.
. Disappointing numbers of just under 900 lumens, under 200 kcd, and modes work differently than advertised, manual is in Chinese. Driver is labeled Shadow, light and box labeled Galuxia. It's driven at 2.55A in the highest mode, so if it was driven better at 3.5A or so, it just might achieve the listed specs.
Like that Amutorch. Buy the host for $3x, add dedomed SST-40, add FET+1 driver, improve thermal and electric path and have a 300 kcd light for <$50. Not bad me thinks.
What is the UI like ?i ordered this one bcaue the UI seems usable ad throw numbers were appealing…
Any way of reducing the sense resistor to increase current maybe ?
I ordered two, got 2. Each one has a different driver, different UI - dunno which is the "newer" one - think it's the red driver, dunno for sure.
If you get the red Shadow driver, then the power switch is ON/OFF, e-switch is mode changing - 2X is strobe.
If you get the green Shadow driver, you can use the e-switch to turn it ON and OFF, and the 2X click is turbo, which is more amps than the hi/turbo of the red driver.
:FACEPALM: - what a disaster, but mine are getting a FET+1 or 3 channel driver anyway.
Good catch. Though more like AL35-1.
Comparing with SS35-1 it has a different keys attachment (worse for me). And SMO reflector.
I said it once and will repeat: I’m in for AL35-3.
Hum, those references would be to aluminium construction, right?
As far as I recall the SS35 has a weird looking beam (greenish) and puts only 400lumens from a 18350. Maybe a “3 led” version could be interesting yes, if the output raises accordingly
