LED drivers and Accessories you want, but don’t exist
498 posts / 0 new
Schoki
Schoki's picture
Last seen: 5 hours 57 min ago
I think it’s pretty clear what this thread is about. You can say what driver you want (linear, buck, buck-boost, current requirements, diameter, input voltage range, maybe desired IC, etc…). I’m sure there are some good ideas out there that just need someone to develop a driver. I can try to build driver boards as well, but I can’t program them. Just tell what your driver of your dreams would be, but please stay realistic. Now let’s see what you have in mind. Big Smile
Edit: 17mm boost driver in development
...don't tell me how electronic components work, i'm studying exactly that...
Edited by: Schoki on 05/20/2018 - 05:40
Texas_Ace
Texas_Ace's picture
Last seen: 1 day 7 hours ago
This is a good idea. If we can get next gen firmware running on the latest MCU’s (the 1617 looks the most promising but not sure if they are able to be programmed yet) then we can have a few universal hardware and firmware options that should be able to cover almost everything.
Schoki
Schoki's picture
Of course, when someone finds a very good IC that would work great with a driver, just post the datasheet. And if there is some interest, I can make a post briefly talking about different possibilities to “convert” regular buck drivers into LED drivers.
Enderman
Enderman's picture
Last seen: 1 hour 3 min ago
The 15A TA buck driver that nobody has built or tested yet.
Schoki
Schoki's picture
Do you mean the SRK type driver?
AlexGT
AlexGT's picture
Last seen: 3 days 1 hour ago
4×18650 series boost driver to power a XHP70.2 at 6000+ lumens with configurable brightness and number of modes from 1 to 7, ramp up, down, easy access to turbo and firefly, hidden SOS and blinkies, e-switch compatible with a find me led under the rubber button
The Miller
The Miller's picture
Last seen: 9 months 3 weeks ago
OK
A driver with:
6V input (2S)
Output two independent 10A channels (controlled by own switch)
Fan connector that recieves power based on either or both output cmchannels (so when the two are at max, fan runs at max)
Texas_Ace
Texas_Ace's picture
4s boost driver for an xhp70? Are you thinking of a buck driver? Or a 4P boost driver maybe?
Firmware sounds like you just want it to work with Narsil lol.
Schoki
Schoki's picture
Which diameter?
Schoki
Schoki's picture
Is there a test for the XHP70.2? How many amps do you need for 6000 lumens?
Jensen567
Last seen: 1 year 3 months ago
Ideally I would love a buck-boost driver with a 2.5V to 24V input, 2.5V to 36V output at 100W+.
Realistically I’d like to see a boost driver based on the MP3431 IC, and a buck driver based on the MPQ8632-20 IC.
For MCU it would be cool to see something more modern like an MSP430 or even an ARM Cortex M0+, but at the very least the Tiny1617.
Multiple output channels for multi-color lights would be nice.
Agro
Agro's picture
Last seen: 56 sec ago
1. Buck-boost-FET, 1s/2s in 1s/2s out. On fresh battery, it’s a buck. On less fresh buck-boost, at the end boost. For max power, FET. Near optimal efficiency and optimal peak output.
2. High power, very efficient 3V in 6V/12V out boost. Actually moderately-high power (like GXB17) would be superb too if it got first-class firmware.
Lexel
Lexel's picture
Last seen: 2 days 16 hours ago
Buck/boost driver for high Vf UV LEDs
Input 1S
Output 3.8-4.4V max. current 1500mA
At low current Vf can be down to 3.2V
If possible double sided 17mm with 5-6mm spring pad
ToyKeeper
ToyKeeper's picture
Last seen: 12 hours 39 min ago
For e-switch lights, firmware will probably be relatively simple. I’ve been making a UI toolkit which abstracts out the hardware details, so pretty much any UI should be able to run on pretty much any hardware. When there’s new hardware, patch the toolkit to add support, and then every compatible UI should work with little or no changes.
Or that’s the idea, at least. So far I’ve only actually tried it on the D4 and Q8 drivers.
scully012
scully012's picture
Last seen: 6 days 7 hours ago
A 17mm 3.7v input 6-12v output boost driver to put xhp series leds in a S2+ or C8.
Edit: or mtg2 leds
Texas_Ace
Texas_Ace's picture
It should be roughly the same as the xhp70 tests with a bit lower Vf.
At 6V it should need around 10A to reach 6000 lumens. Pretty normal for an XHP70 in a flashlight. Some are driving the .2 versions to almost 20A.
As a general rule we like to drive each die of an LED to 5A and as high as 10A. Less then this is not in great demand on BLF but there are cases where people would want this.
The Miller
Schoki wrote:
Which diameter?
Big, 4 26650 touching for 2S4P
Haven’t measured it but 46mm would be nice for compatibility.
The_Driver
The_Driver's picture
Last seen: 2 days 15 hours ago
There are a few that I want.
1. 1S Buck-Boost Driver for 2.8-4V LEDs which does up to 5A, but it configurable down to 3A. Controlled by eswitch with many low modes (like Zebralight), overtemp and overdischarge protection. Maybe also a version for clicky switches.
2. Buck driver with 7-8A for 3-4V LEDs and 2S-3s input. Should have all the usual features.
3. 30-50A Buck driver for 3-4V LEDs with flashlight compatible form (round, diameter not more than 50mm). Battery input should be 3-4S (with very low internal resistance). Must have overheating protection for driver and also LED. Must also have additional, small buck circuit for much lower modes. I know this one is rather difficult, but as long as it stays under 100$ and is actually useable it would be great. It would be used with Luminus CBT-140 and CFT-90 LEDs.
4. Boost Driver for 6V or 12V (preferably 6V) with 30W output, lots of low modes, eswitch, and all the other usual features.
lampyris
lampyris's picture
Last seen: 2 years 4 months ago
A twin button e-switch driver with miniscule queissant current draw, as I’m tired of button pushing!
Edit for spelling correction(s)
Schoki
Schoki's picture
As a Buck-Boost, one option would be the TPS63027 usable, maybe up to 2A for UV LEDs.
The more you step down voltage, the less efficient the driver is. So a 2S config for 3-4V LEDs would be better, or 4S with 2 3-4V LEDs in series or one 6V LED.
Texas_Ace
Texas_Ace's picture
Agreed, it would be foolish to input 4S and output 1S at 50A. There is no single LED that can handle that so you are better off running multiple LED’s in series. It makes things much simpler and more efficient.
Remember, voltage is easy, you pay no penalty for voltage other then needing to make sure your components can handle it (very easy up to around 30V).
On the other hand you pay BIG penalties for current. A 50A buck driver would be very difficult, I know as I am working on a driver that needs 30A and we ended up needing to split it into 2 separate 15A drivers to get the features we wanted.
Jerommel
Jerommel's picture
Last seen: 4 months 4 days ago
I need a 17mm boost driver to run a Nichia 144A at around 3 Amperes from 1 cell.
It would be nice to have a boost driver like that with the option to set the current, like from 3 to 6 Amperes.
Optional e-switch would be nice too.
Jerommel
Jerommel's picture
I haven’t yet seen ‘synchronous’ buck or boost drivers either.
Those are more efficient (iirc)
Texas_Ace
Texas_Ace's picture
Jerommel wrote:
I haven’t yet seen ‘synchronous’ buck or boost drivers either. Those are more efficient (iirc)
There is a boost driver floating around using this design and would fit your goals except for the firmware. It uses custom firmware instead of Narsil / Bistro like we are used to.
The firmware is one of the bigger issues. We need good workign firmware for the latest MCU generation then some good base Buck / Boost setups. After that we can combine them to fit whatever we want.
maukka
maukka's picture
Last seen: 11 hours 15 min ago
My wish is similar to Jerommel’s, but a 2S input would be nice too, so buck-boost.
Input: 1-2S
Output voltage: 144A or 3× 219B/C, so 5-10 volts
Output: three modes is enough from 100mA to 3A
The_Driver
The Luminus LEDs which I mentioned are rated for a max of 28A. They will probably be able to take a bit more. So 30A is the absolute minimum here to make a driver interesting in this case!
The new Luminus CFT-90 is the one that is really interesting. It is much more efficient compared to older models. It is as bright as an XHP-70, but it’s factory de-domed and the DIE is only 9mm^2, the XHP-70(.2) should be around 14mm^2 when de-domed and 28mm^2 with dome). It also probably doesn’t have the 3D-Die of the Cree LEDs and will probably have a very high luminance (so very high throw with very high lumens). There is nothing on the market that matches it.
Please tell me more about your 30A project. You can PM me if you like.
John-Galt
Last seen: 1 day 42 min ago
5s buck driver. I have some black+decker 5s2p 4ah packs I would like to use to drive 12v leds, but can’t find a suitable driver that will accept 20+ volt input. Sad
The_Driver
Easy! The German company pcb components offers this. There are different variants. Two for up to 3A LED current:
https://pcb-components.de/led-abwaertswandler-buck-step-down/micro-2800m...
https://pcb-components.de/led-abwaertswandler-buck-step-down/black-power...
and one for up to 11.5A:
https://pcb-components.de/led-abwaertswandler-buck-step-down/ampere-5000...
The US company TaskLED also has some: http://www.taskled.com/
Lexel
Lexel's picture
The Luminus LEDs which I meantioned are rated for a max of 28A. They will probably be able to take a bit more. So 30A is the absolute minimum here to make a driver interesting in this case!
The new Luminus CFT-90 is the one that is really interesting. It is much more efficient compared to older models. It is as bright as an XHP-70, but it’s factory de-domed and the DIE is only 9mm^2, the XHP-70(.2) should be around 14mm^2 when de-domed and 28mm with dome). It also probably doesn’t have the 3D-Die of the Cree LEDs and will probably have a very high luminance (so very high throw with very high luminance). There is nothing on the market that matches it.
quite pricy LED, but like 6000 OTF lumens from 9mm² might be possible, which would even beat a very hard driven XHP35
Texas_Ace
Texas_Ace's picture
Interesting, never heard of the Luminus CFT-90. The last gen models were so inefficient I wrote them off. This latest version is still inefficient but it is not that far off of what we drive other LED’s to here.
Still going to be a tough job to make a buck driver for that, it will need to be quite large to fit the components needed, even a 46mm driver could not be big enough for everything depending on what components are used.
The project is kinda floating right now, not gonna say too much till I know if it is going forward or being dropped.
Basically it is a 6s6p input that needs to provide 18V at ~30A output to some LED’s.
Some math can give you an idea of what the results might be.
Enderman
Enderman's picture
This maybe?
http://www.international.mtnelectronics.com/index.php?route=product/prod...
2-4S input.
