There is a boost driver floating around using this design and would fit your goals except for the firmware. It uses custom firmware instead of Narsil / Bistro like we are used to.
The firmware is one of the bigger issues. We need good workign firmware for the latest MCU generation then some good base Buck / Boost setups. After that we can combine them to fit whatever we want.
The Luminus LEDs which I mentioned are rated for a max of 28A. They will probably be able to take a bit more. So 30A is the absolute minimum here to make a driver interesting in this case!
The new Luminus CFT-90 is the one that is really interesting. It is much more efficient compared to older models. It is as bright as an XHP-70, but it’s factory de-domed and the DIE is only 9mm^2, the XHP-70(.2) should be around 14mm^2 when de-domed and 28mm^2 with dome). It also probably doesn’t have the 3D-Die of the Cree LEDs and will probably have a very high luminance (so very high throw with very high lumens). There is nothing on the market that matches it.
Please tell me more about your 30A project. You can PM me if you like.
5s buck driver. I have some black+decker 5s2p 4ah packs I would like to use to drive 12v leds, but can’t find a suitable driver that will accept 20+ volt input.
Interesting, never heard of the Luminus CFT-90. The last gen models were so inefficient I wrote them off. This latest version is still inefficient but it is not that far off of what we drive other LED’s to here.
Still going to be a tough job to make a buck driver for that, it will need to be quite large to fit the components needed, even a 46mm driver could not be big enough for everything depending on what components are used.
The project is kinda floating right now, not gonna say too much till I know if it is going forward or being dropped.
Basically it is a 6s6p input that needs to provide 18V at ~30A output to some LED’s.
Some math can give you an idea of what the results might be.
Luminus LED are 3-4v and use 30A+ current.
Take a look at some of the datasheets, it’s insane.
As with most LEDs you can drive them at even higher currents for more output as long as you give them enough cooling.
Let’s assume one wants to drive it at max allowed Tj (150C)
They rate Vf vs temp up to 120 degrees, let’s use that.
27A (this is the max, not 28) * 3.52 V = 95W.
Thermal resistance between PCB and junction is 0.45 C/W.
Let’s assume 30 degrees max ambient temperature. You need your host to have under 0.8 C/W. So even stock output will not be thermally sustainable in a passively cooled flashlight. Which is not always a problem.
The LED has a build in thermal resistor, so you can ramp down when it gets too hot
you can do it smart so that the ramp down also calculates the thermal difference to Tj which gets lower with less current
there are no thermally sustainable flashlights in that power range so far, the X9 might get 100W thermally stable
Not with that U.I.
I want all the nice features some of the BLF drivers have ;).
Regarding CFT-90:
When you a driving an LED with 95W you can add a fan. It makes no difference in the runtime in practical terms. The light needs to be big anyhow. You need lots of batteries, a big heatsink, large driver, large reflector or optic (only a thrower makes sense).
Boost driver for xhp and mt-g emitters with firmware adjustment of current limit and pwm for fan speed control so the higher the output the faster the fan spins. Sized for 3p or 4p 18650 or 26650.
I maybe look into building a buck-boost driver with the TPS63027, so 2A max output.
Another topic: looking at multiple posts about fans for cooling, I can’t quite get it. Where should the fan get air from to cool the components?
Air could be ducted from outside the light and blown across the fins of a heatsink allowing the emitter to be cooled in a manner similar to a computer cpu or gpu.
