LED drivers and Accessories you want, but don’t exist
quite pricy LED, but like 6000 OTF lumens from 9mm² might be possible, which would even beat a very hard driven XHP35
Interesting, never heard of the Luminus CFT-90. The last gen models were so inefficient I wrote them off. This latest version is still inefficient but it is not that far off of what we drive other LED’s to here.
Still going to be a tough job to make a buck driver for that, it will need to be quite large to fit the components needed, even a 46mm driver could not be big enough for everything depending on what components are used.
The project is kinda floating right now, not gonna say too much till I know if it is going forward or being dropped.
Basically it is a 6s6p input that needs to provide 18V at ~30A output to some LED’s.
Some math can give you an idea of what the results might be.
This maybe?
http://www.international.mtnelectronics.com/index.php?route=product/product&path=67_115&product_id=846
2-4S input.
Luminus LED are 3-4v and use 30A+ current.
Take a look at some of the datasheets, it’s insane.
As with most LEDs you can drive them at even higher currents for more output as long as you give them enough cooling.
Let’s assume one wants to drive it at max allowed Tj (150C)
They rate Vf vs temp up to 120 degrees, let’s use that.
27A (this is the max, not 28) * 3.52 V = 95W.
Thermal resistance between PCB and junction is 0.45 C/W.
Let’s assume 30 degrees max ambient temperature. You need your host to have under 0.8 C/W. So even stock output will not be thermally sustainable in a passively cooled flashlight. Which is not always a problem. :wink:
The LED has a build in thermal resistor, so you can ramp down when it gets too hot
you can do it smart so that the ramp down also calculates the thermal difference to Tj which gets lower with less current
there are no thermally sustainable flashlights in that power range so far, the X9 might get 100W thermally stable
Not with that U.I.
I want all the nice features some of the BLF drivers have ;).
Regarding CFT-90:
When you a driving an LED with 95W you can add a fan. It makes no difference in the runtime in practical terms. The light needs to be big anyhow. You need lots of batteries, a big heatsink, large driver, large reflector or optic (only a thrower makes sense).
Boost driver for xhp and mt-g emitters with firmware adjustment of current limit and pwm for fan speed control so the higher the output the faster the fan spins. Sized for 3p or 4p 18650 or 26650.
I would be fine with a single mode UI for my flashlights tbh… :stuck_out_tongue:
To me 3 modes 10% - 30% - 100% is enough for lights up to 10 Watts.
for more powerful lights an extra ‘lower low’ is a must too.
I maybe look into building a buck-boost driver with the TPS63027, so 2A max output.
Another topic: looking at multiple posts about fans for cooling, I can’t quite get it. Where should the fan get air from to cool the components?
Air could be ducted from outside the light and blown across the fins of a heatsink allowing the emitter to be cooled in a manner similar to a computer cpu or gpu.
[quote=The_Driver]
Thanks for the info & links. I was hoping for something a little less expensive than $30 each, though.
Mine gets it from the back and exhausts heat near the head of the flashlight:
+1
I probably don’t know what I’m talking about but here goes
9v MT-G2 to 3S
we all hate pwm and we all want the efficiency I love ramping but it seem like the D4 is (dear I say it) too much of a hot rod for getting more lumens for longer time. (yup most lumens its great) but I keep waiting (and I think some lights can do it now) but 3k-4k continuous in a nice tint. Yes I know that the heat dissipation of the material is/can be a bottleneck even in lights larger then the D4.
Love the BIG floody MT-G2 when can we make them in triples?
XHP to me has too many artifact issues and unpleasant tint (never heard of a 4C tint in an XHP 35, 50, 70)
Again not up on the latest but what about progress for us guys who want say the smallest light possible that will run three MT-G2 at 3000 lumens continuously with out getting too warm. don’t care if turbo is 5k or 6k or ?k the peak numbers are almost a game because they don’t address what it take to keep belting out big lumens.
Love the D4, but its a case in point, it can run over 4k lumens but struggles to constantly run over 400-600 depending on emitter. again not an expert and not up on the “latest” but it seems like something is missing in the “improvement” trend over time of technology.
And yes I am thinking every day use (not necessarily carry but at least use) the BIG MONSTERS just don’t seem to get actually used.
I know its a jumble and thanks for listening
P.S.
There also a 36v MT-G2 that we never get to use.
6v
9v
36v
If we were starting from scratch with would be the smartest voltage to run?
Should we be specifying drivers in watts?
I so badly want a 2S current controlled buck driver that will output 5 to 6 amps at 6 volts! And then, a single cell boost driver for use with good 18650’s or 26650’s that will run the XHP50.2 as it should be.
2S to 6V would not be a buck driver… that would just be simply a 7135/linear driver.
right now, a driver that can drive the 6 and 12v xhp70s to 6000 lumens so i can put 3 of them into my chunky monkey. that should be about 8-10A an LED…
Noticed most of the wishlist are for the XHP variants.
The dream driver is for the battery omnivore for say the XM, XP leds as below…
  • Constant Current (or extremely high PWM if not possible)
  • Voltage input: 0.8V ~ 6.0V (AA/18650/2xCR123a)
  • Max Amp: 3A at least (with DD option would be nice)
  • Modes: Programmable with selections as currently available (from Moonlight to Max)
  • Diameter: Small enough to fit an E-series LE
But if the above can cater for the 6V LEDs as well (highly unlikely) then all the more the better!
Why the 1617? I don’t get it. The 1616 is much more attractive with it’s smaller size. How many pins do you need?
And why sit around and wait? Start with the 1634, and when the 1616 is widely available, port the firmware and make a new driver version.
