Gearbest New Arrival: March 22nd, Convoy H1 CREE 29.99$
Any update? It seems like you’re still missing it. Just sayin’ :stuck_out_tongue:
Hi, sorry, we now can not ship cells to Slovenia.
We have a survey on the Turkish mail, and if it has been put into use as one of Gearbest shipping options, we will update info and let the public know as soon as I can.
Thank you.
Philips Hue - Your personal wireless lighting system
Philips Hue connected bulbs and bridge let you take full control of your lighting.
Whatever you want to do with your lighting, Hue can.
Get started with the Philips Hue and experience high quality white and colored light that offers you endless possibilities.
Limitless possibilities - Download the App and discover the amazing things you can do with Philips Hue
● Play with light
Play with light and choose from 16 million colors with the tap of a finger
● Create your ambiance
Set the right ambience for any moment. Set the mood, change the ambience, feel different, feel better
● Sync with movies and music
Extend your TV viewing experience to the whole room or sync light to your favorite music and enjoy every beat to the fullest
● Light schedules for home automation
Wakes you up gently for a fresh start, and helps you get to sleep each day
● Control your lights from anywhere
Check if you have forgotten to switch your lights off before you left your home, and switch them on if you are working late
● Expand your Philips Hue system
Once you’ve set up your Philips Hue system, you can go on and add up to 50 Philips Hue lights
Turn on your imagination with Philips Hue and find more possibilities
Seek More: http://www.gearbest.com/smart-lighting/pp_343492.html
Promo Price can be pretty pretty nice for you: 199$
( Coupon will be set-effective tomorrow morning )
SUNCORE 20 x 50mm Binocular
- HD binocular with plastic + metal body for birds watching, climbing, hiking, hunting, etc.
- Fully multi coated and anti-fog lens offers clear images with improved light transmission
- Porro BAK - 4 prism provides a high definition view
- Center focus wheel and eyepiece adjustment for precisely focusing
- Compact and lightweight, easily being held by one hand
- With lanyard and storage bag, convenient to carry
Prism System: Porro System
Optical Material: BAK-4
Amplification Factor: 20X
Objective Lens (mm) : 50mm
Eyepiece Diameter: 25mm
Field of view: 168ft / 1000yds
Field Angle(degree): 2.9 degree
Exit pupil diameter: 2.5mm
Exit pupil distance: 18mm
Coating Film: FMC
Anti-fog, Foldable Eye Cup
Seek More about the item: http://www.gearbest.com/binoculars-and-telescopes/pp_638125.html
Coupon: SC25GB
Coupon Price: 31.99 $
2017 Aug 23th
KLARUS XT2CR CREE XHP35 HD E4 LED Flashlight
6500 - 7000K 1600LM USB Powered High Brightness
● CREE XHP35 HD E4 LED with higher photoelectric efficiency, max output up to 1600 lumens
● 18GT - 36 3600mAh 18650 battery included ( installed in flashlight )
● Intelligent battery load system compatible with a wide variety of batteries
● Robust stainless steel bezel ring protects components
● Patented dual-switch tail cap for easy tactile one-hand operation
● Digital intelligent charging algorithm with currents up to 1A
● All new ITS system monitors internal temperature and adjust output to regulate heat, protects LED and internal components for perfect balance of output and safety
● Front and rear internal mounted springs protect against shocks and drops
● Aerospace aluminum alloy construction; CNC precision machining; HAIII Mil-Spec anodizing
● Reverse polarity protection to prevent damage from incorrect battery insertion
● Hardened AR-coated lens, scratch resistant
Seek More from: https://www.gearbest.com/led-flashlights/pp_702467.html?wid=21
Coupon: KKSMK
Brinyte DIV12S CREE XML - L2 Diving Flashlight, A newly wonderful design of led tech diving flashlight with power indicating function aiming to enhance the safety of underwater diving.
Before your diving, the flashlight will remind you of battery low power by lighting a red ( less than 30pct ) or flickering red ( less than 10pct ) indicator next to the magnetic switch
If the indicator turns red while you are diving, which means you should go back to the land as soon as possible
Built by high strength aluminum AL - 6061 - T6 material with premium military type III hard-oxidation treatment
Powered by one 18650 rechargeable battery ( not included), can be continuously lighted for 2 hours under 1000 luminance and for 15 hours under 150 luminance
10-degree narrow beam, the light is the best choice for night diving and scuba diving as the backup light
Over-heat protection design to ensure working stable and safe use; reverse polarity protection to prevent from wrong installation of battery
Two O-ring offer extremely waterproof capability of maximum 100 meters underwater
The toughened lens with thickness 5mm to ensure excellent ability to resist water press
Seek More from here: https://www.gearbest.com/led-flashlights/pp_727449.html
Brinyte M18 XP - G2 Brass LED Mini Flashlight very compact, easy to carrying, can be used as a keychain
Charged via micro USB interface; two lighting mode: low; high
Reliable tail twist switch for a quick, one-handed operation
Comes with a 3.7V 1000mAh 10180 rechargeable battery ( installed at flashlight / 1*10180 Included)
Waterproof to IPX8 standard ( submersible up to 2 meters )
Seek More: https://www.gearbest.com/led-flashlights/pp_791951.html
Try the code: Enjoy 12% off discount with the code: GB17LED (code price 21.78:money_mouth_face:
Klarus Titanium H1A 550Lm CREE XP - L V6 Led Headlamp
Three light sources: long range main beam, floodlight, and red light
The main lamp features CREE XP - L V6 LED ( 6000 - 7000k ), maximum output up to 550L, extended range light.
Side lamp features CREE XP - E2 R2 LED ( 4000K ), flood light with even illumination, suitable for a short distance.
PMMA optical lens on the main lamp with a 92pct light transmission.
The lens of main lamp features patented design to protect user vision, improved comfort, and maximum optical advantage.
Fade-in and fade-out function when the Turbo mode is the initial mode for on and off to promote eyes safety and improve user experience.
90-degree adjustable angle illuminates from any direction.
Newest intelligent temperature protection System ( ITS ) monitors the internal temperature
Unique lock-out function to avoid accidental operation and activation during storage, preventing a risk of eye damage.
Intelligent battery indicator function displays remaining battery capacity at will to control light use.
Headband includes sweatband design for long term comfort.
Compatible with all AA alkaline, Ni-MH, and 14500 Li-ion batteries.
Comes with a 14500 rechargeable battery (battery Included).
The access: https://www.gearbest.com/headlights/pp_791949.html
Try the code: Enjoy 12% off discount with the code: GB17LED (code price 79.16:money_mouth_face:
Thumb-sized KLARUS Mi1C CREE XP-L HI V3 EDC Mini Flashlight, maximum output up to 600 lumens, up to 9 days running time in moon mode
Fade-in and fade-out function when the turbo mode is the initial mode for on and off.
Newest intelligent temperature protection system(ITS) monitors internal temperature
Intelligent battery capacity indicator to view remaining battery capacity at any time.
Lock-out mode prevents accidental activation; avoiding battery drains during storage or traveling and prevents unintended directly shining into eyes.
Reverse-polarity protection prevents damage due to incorrect battery orientation.
One-touch low and with mode memory function.
Aerospace aluminum alloy construction; CNC precision machining; Mil-Spec HAIII anodizing, anti-abrasive, lighter and robust.
Compatible with CR123A and 16340 Li-ion battery
KLARUS 16340 battery with a Micro- USB port is included ( installed at flashlight )
Magnetic tail can affix the flashlight to any steel surface
The access: https://www.gearbest.com/led-flashlights/pp_791915.html
Try the code: Enjoy 12% off discount with the code: GB17LED (code price 43.08:money_mouth_face:
KLARUS XT12S CREE XHP35 HI D4 Color Temperature: 6500-7000K High Brightness Flashlight, extreme spotlight capability and illuminates up to 402 meters.
Aerospace aluminum alloy body with CNC machining; Mil-spec HAIII hard anodizing.
Stainless bezel ring. Hardened mineral glass lens with AR coating.
Two interfaces: tactical setting; outdoor setting.
Tactical setting: classic KLARUS XT series control. One-touch strobe; one-touch turbo; versatile for all tasks.
Outdoor setting: One-touch low; One-touch turbo; multiple output levels with memory, SOS function.
Springs at bezel and tail resist shock and drop damages. Reverse polarity protection; eliminates damage from incorrect battery installing.
KLARUS 18GT-36 3600mAh 18650 battery included, 1A recharging current.
https://www.gearbest.com/led-flashlights/pp_799713.html
JETBeam TH15 CREE XHP35 E2 LED Flashlight
https://www.gearbest.com/led-flashlights/pp_1317536.html
Main Features:
• Using high-quality CREE XHP35 E2 bead with long lifespan of more than 50, 000 hours
• Max output up to 1300 lumens and throw distance of 228 meters with one 18650 battery
• Patented triple tail switches and a side switch for one-handed operation with ergonomic switch locations
• Patented JETBeam triple tail switches allow tactical mode with one-touch strobe and simplified outputs with high as default
• Convenient side switch allows 5 intensity selections ( excluding turbo and strobe ) with memory function
• Intelligent temperature control system to maximize lifespan of LED
• Low power indicator function reminds user of battery replacement in time
• Reverse polarity protection to prevent damage caused by improper battery insertion
• Built-in rechargeable 18650 battery
• Both clip and tactical ring included in package for different applications
• Toughened ultra-clear mineral glass with anti-reflective coating
• Constructed of aero grade aluminum alloy
• HAIII military grade hard-anodized finish
• Waterproof rating: IPX-8 ( 2 meters underwater )
Brightness Levels:
• Turbo - 1300LM
• High - 900LM - 1.2h
• Middle - 450LM - 3h
• Low - 180LM - 8.5h
• Ultra-low - 60LM - 30h
• Moon - 10LM - 140h
• Strobe - 900LM
Nitecore GP3 CREE XP - G2 LED Action Camera Light
https://www.gearbest.com/led-flashlights/pp_986776.html
Main Features:
● Action camera light
● Onboard sliding diffuser
● Utilizes a CREE XP - G2 LED
● Max output up to 360 lumens
● Max runtime up to 235 hours
● Micro-USB rechargeable with onboard charging circuit
● Universal mounting rings to secure the GP3 onto action camera mount
HaikeLite MT07S - HI CREE XHP35 HI LED Flashlight 7 Modes
https://www.gearbest.com/led-flashlights/pp_1303517.html
Main Features:
● 7 brightness levels: hidden turbo - high - medium II - medium I - low - hidden strobe - hidden moonlight
● Utilize a CREE XHP35 HI bead that can produce a blazing 3000LM illumination
● Waterproof IPX-8, suitable for usage in rainy weather
● Lightweight, easy to carry
● Powered by 4 x 18650 Li-ion battery ( not included )
● SMO aluminum reflector with double side AR coating glass lens for extreme reflector performance
● Lockout function: a single click followed by a long click to lockout the switch, repeat to unlock
Hey Gearbest, how about adding LiitoKala 26650-55A to your inventory?
Klarus Mini One XP - G3 LED Keychain Flashlight 3 Modes
https://www.gearbest.com/led-flashlights/pp_1476219.html
Main Features:
• Finger-sized mini-might flashlight, elegant and compact
• 10180 Li-ion rechargeable battery included
• Micro-USB charging port, easy to charge
• Fast charging, only 45 minutes charging needed, no waiting
• CREE XP-G3 LED, max output up to 130 lumens
• 2 brightness modes to meet your luminous needs
• Professional optical lens design, even-lit flood light, soft beam
LUMINTOP Tool AA EDC LED Flashlight Cree XP - L
https://www.gearbest.com/led-flashlights/pp_1476215.html
Main Features:
● Utilizes Cree XP - L HD LED with a lifespan of 50,000 hours
● 3 brightness levels with a max output 550 lumens
● Powered by one AA or 14500 rechargeable Li-ion battery ( not included )
● Handy and compact, easy to carry
● Red, blue and purple colors optional, gift package best for families and friends
● Digitally regulated output maintains constant brightness
● Detachable body clip for two position installation, easy to clip on your pocket or a hat
● Two ways to select outputs: Tail switching or twist the head
● Made of aircraft-grade aluminum alloy with anti-scratching type HAIII military grade hard-anodized finish
LUMINTOP Tool AAA EDC LED Flashlight CREE XP
https://www.gearbest.com/led-flashlights/pp_1476196.html
Main Features:
● Utilizes CREE XP-G2 R5 with a lifespan of 50,000 hours
● 3 brightness levels with a max output 110 lumens and max runtime 60h
● Powered by one AAA battery ( not included )
Nice Tool colours :+1: I love it!!
Hey Gearbest, I’m not if I’m writing in the right thread, but I have another inventory suggestion:
Amutorch JM70, both 1-cell and 2-cell. Seems like a nice value thrower.
Date:Dec 22
KLARUS Mi6 CREE XP - G3 Keychain LED Flashlight
https://www.gearbest.com/led-flashlights/pp_1499488.html
Dear Agro, thank you so much for your kind support about New Release items Recommendation, thank you!! Amutorch JM70 and Liitokala 26650-55A are being on survey, keep you informed, then
Thank you again, nice day, friend
Charger
1. ADEASKA SQ2 LCD Display Smart Battery Charger 2 Slots
You can monitors and charges each of the 2 slots independently
The charger can output via USB for mobile phones, laptops or other digital equipment.
Compatible With:
● 3.6V / 3.7V Li-ion / IMR / INR / ICR:
10440 / 10450 / 14650 / 16340 ( RCR123 ) /
17335 / 17500 / 17670 /
18350 / 18490 / 18500 / 18650 / 18700 /
22650 / 25500 / 26650 / 32650
● Ni-MH / Ni-Cd:
A / AA / AAA / AAAA / C / D / SC
https://www.gearbest.com/chargers/pp_1489093.html
2. ADEASKA SQ4 PLUS 4 Slot Smart Quick Battery Charger
LCD Display USB Output
Compatible With:
● Li-ion / IMR / LiFePO4:
10340 / 10350 / 10440 / 10500 / 12340 / 12500 / 12650 / 13450 / 13500 / 13650 /
14350 /14430 / 14500 / 14650 / 16500 / 16340 ( RCR123 ) / 16650 /
17350 / 17500 / 17650 / 17670 / 18350 / 18490 / 18500 / 18650 / 18700 /
20700 / 21700 / 22500 / 22650 / 25500 / 26500 / 26650
● Ni-MH ( NiCd ):
https://www.gearbest.com/chargers/pp_1486607.html
3. Authentic TOMO V6-2 Intelligent Charger
Compatible: AA,AAA,18650,14500,18500,16340 (RCR123),17650,10500
https://www.gearbest.com/chargers/pp_1530140.html
4. TOMO T2 Authentic DIY 2 x 18650 Li-ion Battery Power Charger
Dual outputs, can charge phones, pads or other small electronic devices simultaneously, Independent Circuit, Reverse Polarity Protection
https://www.gearbest.com/chargers/pp_1524289.html
Klarus Mi6 any good?
