So,I forget about X65 and X9.
Man that is what i like to hear! i know you will soon get another project going since Q8 and GT is basically complete.
The specs does have “monster” vibe to it :sunglasses: So which emitter? i am sure not XHP35 HI like in the original plan for Q16?
Put me on the list for a Q16.
Well this is not the Q16 thread, we need time to prepare first
Back to the DX80
Did anyone see if it has a fan and how long it is bright in the real world?
well Q16 made DX80 irrelevant
X65, forget about? Will the flashlight that this topic thread is about put more light out there at 400 yards/meters? Or will any other flashlight on the horizon put more light at 400 yards/meters than the X65? If yes, let me know, and I will buy two, one for each hand.
Me too.
With enough throw of course,not only flood.
I’m waiting for mine. :sunglasses:
as in not cancelling
Goinggear in the USA has them on order. It’s probably the best place to get one if you live here even if you have to pay more just in case you get one that doesn’t work properly.
All eyes on round two. I sincerely hope Imalent delivers a quality product. If not, it’s good for a giggle. Hey I make sure I find myself in a win win situation as often as possible.
:smiling_imp: :smiling_imp:
Hmmmm yummy, I wish they shaved domes like on DT70 but anyway let’s wait for first good working samples and some nice review…
I have been doing photos this afternoon, and this evening I have given a little turn with it. The low levels are sooo hight. Spec says that low is 120 lumen, but can not to be.
Where arrived at home i have done a fast test in the integrated sphere. Low, and the middle levels are really more higher than specified (a lot of). Hight is similar, and turbo is lower than specified, but it can to be because my IS its not calibrated to this lumens. In the next days i will make a correct test.
Imalent told me they tested the dx80 and got over 32,000 lumens. Will be interesting to see if that is true.
My Integrated Sphere is home made. I calibrate it whit Fenix Flashlight in a range of less 1 lumen to 4400 lumens. The diode that I´ve employee not capture the light in a totally linear (its curvilinear). So if 1X value are 100 lumens, then 10X are not exactly 1000 lumens. By means of statistic process I can estimate the lumens of flashlight whit a 1% error margin under 4400 lumens. Values more elevated can have higher margins of error. I can see that error margin its very low at around 10.000 lumens, but in this case, the model spec says 32000 lumens….
I will can not estimate exactly the turbo lumen. But in the tonight test i,ve see that its more powerfull that Acebeam X80 (spec = 25000 lumen, 22275 in my IS).
Tomorrow i will begin all Ansi test.
Exciting
How long does it give max?
Is continuous bright?
Tomorrow I will start all test
It is done when it is done
Where did you get yours, does it have problems like mentioned before?
