Has anyone here tried their luck with those PK RCR16340 cells Iām tempted to grab a fewā¦
Tempted as well, but I will wait for those 14500 first.
Has anybody ordered Pkcell 16340 ?
my 10440 and 14500 are fine.
need someone with test gear to test the others.
or some to find their way here.
Got 4 X of their 18350 900mah. Iāll discharge test two and report back.
Iāll do some ceiling bounce test with a cheap lux meter against Keeppower 18350 too. Havenāt got the Aspires yet
if i had something to use them in i would have gotten some.
looks promising if they are anything like the 14500.
got these in my watch list pending reviews from you guys
Subscribed
Discharge four 18350 at 0.5a. Got 888, 892, 893 and 909mah.
Also did a ceiling bounce test with a cheap UNI-T luxmeter and Emisar D4 XPL. Pkcell got 240 and Keeppower got 284.
I got four Pkcell for $10aud. So they are a bargain. The same seller on ebay even sells 12 for $23aud.
Good numbers for a first 500mA discharge. :+1:
give them a few cycles to break them in.
14500 cells arrived today.
They all came with 3.84V.
First test on one cell, charged to 4.2V@300mA (4.19V after 5 minutes), shows 831mAh at 500mA discharge current. Cut off voltage 3.0V (as specified in the data sheet).
Nice numbers for the moment.
2nd cell shows the same numbers and as I am pretty shure all the other cells will do the same, I will not continue testing.
snakebite did the test @1A. IĀ“m sure my cells would just confirm his numbers.
It would be interesting to see some discharge diagrams in near future.
So far I recommend this cells.
i need to order more of both the 10440 and 14500.
they all left in restomodded vintage lights with friends.
Would be nice if HKJ tested these.
I guess for āhigh drainā (but not too highā¦) usage the Windyfires are still the best?
But for ā¬11.13 i can get 5 14500 PKcells with free shipping, which is nice.
https://www.aliexpress.com/item/5PCS-ICR14500-14500-750mAh-3-7v-rechargeable-li-ion-Battery/32416099918.html
HKJ said that he had 14500 in the pipeline. But not 10440.
hi Box, what was the name of the ebay seller?
Awesome, thanks. This looks like it could be good, they have NiMH batteries and all!
Theyāre in my AliExpress cartā¦
