Love the Narsil, and the Lexel built T/A drivers, but I still prefer the LD-2 and LD-2 M2 Linear drivers, because I can (cycle modes) using either switch, I also prefer the rear push button/tactical grip function over any e-switch. I like my 6D cell Mag-lite because I can rest it on my shoulder, and IF need be spin it over in a skull crushing/jaw busting down ward or side way swing! But that’s the only thing I like about it really, it’s soooooo under powered!
Back when my light was FX30 driver with resistor mod, smo and sliced dome xhp70 it was 115 kcd (678m) which is on the low side. Matt at ASF with the same exact mods got 164 kcd (809m).
When you go FET (12 amps or so) your in a whole new territory.
Then the 70.2 with FET (17 to 18 amps) your in another whole new territory.
I’ll try and measure mine shortly just out of curiosity. It shouldn’t be much behind Dales.
The most difficult part of doing this mod was probably removing the retaining ring that hold the L6 side button. :disappointed: I had to use a tweezers because no snap ring pliers in hand.
Finished installing TA FET driver on L6 and mine draws 9.5A at the tail i had to extend the LED cable with small 24awg wire as i dont have bigger wire that fits the hole. I have AWG16 cable but that is too big i will change to a proper cable when i got bigger cable.
Now the question is how many lumens with 9.5A draw on the tail? it got hot alot faster now i mean a lot!
Bypassing what territories have been entered and just looking at numbers, my L6 with SMO reflector and (nice tint ) XHP70.2 does 4500 lumen (just re-measured) with 100kcd throw, and the hottest XHP70.2 mod has about twice the output, so also about twice the throw.
That is on this same page and I missed it :person_facepalming:
All numbers look pretty consistent, and did anyone get even more throw with a sliced XHP70.2? Or has that not been done yet?
Hhmmmm, dunno if any measured #'s. Word is it doesn't help much, but not sure what that means. KB1428 has certainly dedomed anything and everything (), but not sure if he's got #'s, etc.
I got an SMO shipping today for the Haikelite MT07, already got the same XHP70.2 in it that does about 200 kcd with the stock OP at lower amps, so should bump well once converting the driver to FET based and swapping in the SMO.
Woah, hold on there. Doubling the 1 meter numbers does not even come close to doubling the throw. More like a 30% throw increase.
Throw is also very dependent on the focusing of the reflector. If you wanted max throw with the xhp70 you could slice the dome off to get a smaller hotspot and increase the throw, but you end up with an overall weaker output.
I stopped chasing throw and instead focused on a good balance between brightness and hot spot size.
I just did a few tests on my L6 with Liitokalas, 70.2, fet and smo. A rather disappointing 172 kcd. About 830m. Still, it’s impressive to see in person.
This is coming from an L6 that bone stock did 58 kcd 481m.
I remember that slicing the dome off my xhp70 gave a 24% boost, from 92,500 to 115,000. It might be worth it to a “throw seeker” to slice the 70.2 and see what happens.
If you did see a 24% boost in candela, that would take my 172 kcd to 213 kcd which would be 923m. That’s pretty impressive.
That’s really good for an OP reflector. You’d probably be about 195 kcd, like Tom E, with a SMO that was focused well.
In my older setup, a swap from op to smo went from 65 kcd to 81 kcd. Then when I cut the bottom out and got it to sit a bit lower, it went to 87.5 kcd.
All sounds legit - can't figure why your readings are lower than, but really they are not that much lower 172 kcd vs. 195 kcd. Last sentence is from what you said: "I remember that slicing the dome off my xhp70 gave a 24% boost"
I use a spring on my TA driver, so I guess you don't? Is there a brass button or something? I've never heard of burning bypass wires before - never happened to me, not on the 37K lumens S88 (20 AWG bypasses) clone or the 27K lumens MT03 (22 AWG bypasses) or the 18 amp L6. Big reason to use bypasses on springs for high amps is to prevent the springs from melting, so even 22 AWG wires should take the heat I would think, specially at such short distances.
I didn’t want you to think I sliced my 70.2 and got a 24% boost. That was an older xhp70.
The TA driver has the positive led wire go through the hole and connect to the end of the spring which is touching the battery. The spring doesn’t carry any load. So no need to bypass it.
On my tail spring I used some fine braided copper solder wick. I thought it would flex with the spring nicely. That burned through. So then I added a double layer of it and it burned through. So now I added some 18ga wire. So far so good.
Ahhh - yea, I gave up on solder wick couple years ago - too many broke. Silicon covered wire seems more reliable but isn't perfect either. Some lousy springs out there that the solder doesn't hold up well on.
