I just got a Convoy S2+ with a biscotti driver, XPL HI, a lighted tailcap, and a clear rubber boot-
Lighted tailcap looks like it has two resistors marked 361-
Running a Samsung30Q button-top-
When I first got it and turned it on, it seemed to work fine, moon, medium, high, strobe, biking, battery-check, sos-
So I charge-up the 30Q, and the torch is whacked....I click and just low, I click, and nothing....then I noticed whenever I loosen the tailcap, then tighten it, it goes through the Group perfectly.
Just bridge from the minus pole of the Battery directly to the flashlight case (Plier, Knife, Tweezers, cable) - you will see if the light lights up or not
Some weeks ago I received a biscotti driver for a mod, from Simon and it had the same issue, it always turned ON on low and occasionally it switched to another mode/output, but it wasn’t possible to change it by pressing the tailswitch. Then I went to check the driver and a piece was missing. Maybe there is something missing there too…
