Just got the new LAN v2.0 in house here now.
I got the bead blasted version, nice and grey.
It is a little longer - 3,5mm than LAN v1.0 and 3,3g heavyer.
The LED, Nichia 291C 4000k, is a little more warmer than the LAN v1.0.
Is the battery tube the same diameter as the Pineapple? One thing that bugs me about the Pineapple is that it can’t take my Keeppower 14500 cells. They’re too thick. The battery tube is just wide enough to accept Eneloops, or unprotected 14500’s.
Since I’m not sure if the light has proper low-voltage protection, I’m reluctant to use unprotected 14500 cells in it. So, I’m stuck running it on AA’s, which makes it under-powered by today’s standards.
Hi WalkIntoTheLight…
Just measured, I have old protected Ultrafire 14500 that is 52.2mm long x 14.43mm wide and it fits in - no problem.
The same battery may be squeezed into the Pineapple or the LAN v1.0, but it works fine on the v2.0, so this tube is
a “hair” wider than the two other. These are my numbers.
Hope it helps. Good luck.
I’ll be waiting for that one :smiling_imp:
Meanwhile, great work on these lights Rey! :+1:
I’m not sure if I’ll get one, yet, but will post here if I decide myself for one !!
