Thanks! I’m just not familiarised with what 2s2p emitters are… :person_facepalming:
Gonna check that around! Anyway, that would imply the 18650 tube and the 2x18350 cells inside, right? The driver would have to be modded/changed too?
(I guess that sticking with a stock light with just 1x18350 will be easier for now as I’m not savvy enough to make those mods or dedome!…)
D4 has all the LEDs wired in parallel, 4p. 2s2p is having them as 2 parallel groups of 2 emitters in series. Doing so halves electrical loses of the host. It also spreads the load over 2 cells. But the cells are significantly weaker, so it’s uncertain (to me) what would be the gains. I suppose they would be small.
Thanks for the explanation! Regarding capacity in runtime, 2 18350 will certainly loose for a 18650. Maybe the initial “boost” is better specially with IMR cells, but then it will certainly drop a lot.
Yeah, like I said, I guess a Emisar D4 stock light may be a good option, with 18650 and 18350 tube. :+1:
@ L4M4, there is Thrunite Neutron 2C V3 that goes with 18650 and 18350 too, with no extra tube!
Honestly, you should try messaging the Jaxman seller on Aliexpress. I just was looking to order a 18350 tube for the E2L host I bought from mtnelectronics.com, and they showed “no longer available”. So I messaged them about it, and they said the listing had expired and it would be up again. I checked back and it was available again the next day.
I ended up ordering the original short tube, as well as a black E2L host and black 18350 tube. This was just on August 16 and I’m still waiting for them, so I’m surprised the hosts are gone already. It really could be an expired listing or something like that.
Well… I have a XHP70 laying around…
I will think about that!
I won’t order a 18350 tube for the EMisar - that light is tiny enough and I have not the smallest hands, so a side-clicky light that small wouldn’t be nice to operate.
THe Jaxman is just too close to my two Convoy with triples (S3 grey, S2+ green) :P
I mean… those 18350s are cheap and the best that are on the market. I couldn’t resist.
I had an eye on 18350s for a long time, but since I am not a “900 Lumens is incredibly bright”-user, I need high-drain batteries, and the aspire are pretty much the first on the market.
It’s the same with the S41… “only” 1600Lumens… I entered the Flashlight-market before the XM-L was born and still have an old C8 with a P7 in it - 1600Lm out of a light that small then would have been a miracle back then. Today it’s nothing special and cheap to get.
Just to complete this thread - I have now the Astrolux S41, two S2+ with short tube (green with 219C 4000K triple, desert with soon to be 219C 4000K triple) and since the short tube fits my old S8, I just have ordered another one for that light.
So every cell has it’s master now
And the size of those 18350 S2+ is so nice - they fit so perfectly into my hands and pump out so much light (less than the D4 of course)
The D4 is small enough in the 18650 version
If I take the D4 in my hand, it doesn’t stick out on either side, so a 18350 tube on that would make the light uncomfortably small
Agreed. I also find the D4 with 18350 tube to be just a bit too small and slippery.
The 18500 tube with Talon grip tape added to the smooth portion of the body feels much more comfortable in the hand, and much lighter than using the 18560 tube.
yes, sometimes they go on sale but, afaict it is the ONLY choice with no PWM (which clearly does not matter to most BLFers in this thread, and thats ok). If it helps any, the PT16 includes a built in charger and a protected 16340, which makes it a good gift for a newbie that is not LiIon savvy…
fwiw, the PT 16 head does not block the LEDs like the above
seen shining through a piece of printer paper
fwiw, the PT16 is moddable, Ive had the Cool White XP-G2s replaced with High CRI 4000k N219b, and High CRI 3000k N219c (thanks to LightRider) in a couple of them.
