Thanks for the input Neven. I agree it looks like I overheated my mcpcb. I don’t have any “good” equipment for reflow and just do it on my stovetop. Hard to regulate that. And while I do have a set of those “flush-cut” side cutters, they’re pretty old and dull and don’t bite like they used to. May be time to replace those. Anyway, my post was intended to give folks coming after me a few things to look out for, learn from my mistakes. This driver setup is a really really good product and you should be proud of it.
I really do appreciate you offering to send me a new mcpcb even though the damage to mine is my own fault. That’s very nice of you and really good customer service. Its not necessary though. I will be ordering more from you in the next couple of days, once I plan out a few more builds using your parts, and can just toss an extra board in my order. That’s one of the cheaper lessons I’ve learned working on elecrtronics. I would like to be able to order some of those single-emitter boards though. Any chance you’d be adding those to your web store anytime soon?
That confused me at first too. A single driver can’t go 2-12. There’s a 2-3 amp version, or 4-6 amps, or 7-9 amps, or 8-12. So if you order the 12 amp driver, it’ll only go “down” to 8, etc.
Not sure about your driver question, but I can try on your second. I ordered a white tail at 240uA and find it way too bright. Its easily visible during the day and uncomfortable to look at in the dark. So I’ll be opening mine back up to dim it down considerably. No big deal, I expected to do a bit of tuning.
That said, this is a really personal issue and we don’t all like the same brightness. I’m sure there are folks who would prefer this one just like it is, nice and bright.
One customer is asking does ILC-1 fit into BLF A6/Astrolux S1 tailcap, since I don't have any of those, does anyone know what is washer diameter? Is button diameter 16mm, or 14mm?
I tried it in my A6. Does not fit. The diameter of the switch is just barely too wide to drop down in there. The “can” on the outside makes it a really nice all-in-one drop-in piece but it also makes it slightly wider, too wide for the A6.
Yes, looks to me like a part that fits the A6 would fit the EE X6 as well. That would be a very nice part to have available.
Also I have a question. I’ve been poking at my lighted tailcap module I pulled off the LEDs of one channel and swapped them for another color, trying to achieve a two-color alternating look. Now I have a strange behavior. When I first put power to the tailcap, the original white channel flashes quickly then goes back out while my new orange channel stays on all the time. What would cause that? Is there a fix?
Could you check tailcap current? Which resistor values you put on each channel? Also please check voltage across each resistor, it should be 0.1V. No blinks should occur.
There are some components on bottom(inner) side of top PCB, and they are soldered with lower temp lead free solder (~145C), top side is soldered with normal lead free solder (~217C).
There is a possibility of de-soldering components on bottom side if you use hot air on top side,but if ILC-1 is still, those components would remain in place because of solder cohesion force. For resistor change better is to use normal iron, not just because of bottom side components, but because of Omten switch which is close to resistors and it's made of plastic that doesn't like temperatures >120C.
