#GB48 NEW BlitzWolf® BW-L3 Portable Four Solar Panel USB Charger Group Buy - ACTIVE
269 posts / 0 new
freeme
freeme's picture
Last seen: 50 min 55 sec ago
New BlitzWolf® BW-L3 four panel 28W solar panel is on its way!!!
Since many of you have request such product in the past, I think there is definitely a demand for their upcoming model. cool
Credit: BlitzWolf® www.blitzwolf.com
BlitzWolf® BW-L3 28W 3.8A SunPower Foldable Solar Charger Dual USB with Power3S
Flash Sale: $37.29  60% OFF $92.99 )
Group Buy Price: $59.99 $81.99 )
Coupon: PM me
BlitzWolf® 15W 2A Foldable Portable Dual Usb Sun Power Solar Cell Panel Charger with Power3S
Flash Sale: $17.99 $58.99 )
Coupon:  6897BF
Product specifications:
Model BW-L3
Charging Port 2*USB Port
Output 1/ Output 2 5V/ 3.8A(Max)
Power 28W
Panel Type SunPower
Transformation Efficiency Over 23.5%
Panel Type SunPower
Opened Size 828*280*13mm
Closed Size 160*280*32mm
Weight About 0.63 Kg
Features
1. Powerful SunPower Solar Cells.
2. The transformation efficiency of SunPower is up to 23.5%, most other similar products on the market are 15% or less.
3. Dual Port Power3S Technology.
4. Intelligently identifies connected devices and provides fast charging for up to two devices simultaneously.
Package Includes:
1x Blitzwolf BW-L3 28W 3.8A Solar Charger
1x USB Charging Cable
1x User Manual
1x Warranty Card
4x Climbing buckle
FAQ
1. The BW-L3 is not charging my device, what can I do?
(1) Check to ensure the panel is at a 90-degree angle to the sun.
(2) Cloudy weather or indirect sunlight can cause fluctuations in output that slows down or stops your device from charging.To remedy this, try placing the BW-L3 in more direct sunlight or wait for the weather to clear.
(3) Check to ensure that your device’s input current and voltage requirements fall within the accepted range of the BW-L3.
(4) The Power3S circuit will identify your device before beginning to charge it. Identification of the connected device can take up to 2 minutes.
(5) Devices, such as the iPhone have an internal temperature sensor. When the device is too hot, it will automatically shut down to prevent damage to the battery. If your device has overheated, wait for it to cool down and try again. We recommend you place all devices in the charging pouch or a shade covered area to prevent overheating.
2. How do I check my device's input current and voltage?
Please refer to your device’s user manual, original OEM charging adapter or contact the manufacturer to determine this information.
3. Can I use the BW-L3 to charge a power bank or Bluetooth speaker?
Yes, the BW-L3 is capable of charging any regular USB device.
4. My iPad/iPhone is not charging or is charging slowly, what can I do?
(1) Ensure the panel is at a 90-degree angle to the sun.
(2) For an iPad: We recommend connecting the BW-L3 to an auxiliary power bank first and then charge the iPad from the power bank. If you are charging an iPad directly with the BW-L3, and the panel is generating less than 0.8A (low sunlight conditions),the iPad will not indicate that it is charging, but it will be slow charging.
(3) iPhone: The iPhone has an internal low current cutoff and will not charge if the BW-L3 is producing less than 0.8A.
5. How long does it take to charge my device completely?
Provided the sunlight is adequate, and the panel is at a 90-degree angle to the sun, most modern smartphones will charge in under 4.5 hours. In cloudy, overcast or other low sunlight conditions, your device may take longer than usual to filly charge. The total charging time also varies based on your device's battery capacity and input charging current; we recommend you consult your device's user manual for more details.
6. How long is the life span of the BW-L3?
The PET panels will gradually fade when exposed to the sun resulting in reduced output over time. If used properly, the life span of the solar panel is approximately 4 to 5 years. After this time, the panels output may be too low to provide an adequate charge.
7. The BW-L3 is charging my device in sunlight, but when I move the BW-L3 into the shade
(where it stops charging) and then back into the sun, it does not start charging my device again?
When moving the BW-L3 from shade to sunlight, you need to reinitiate charging by disconnecting and reconnecting the device. If the device is not disconnected and reconnected, it can take up to 10 minutes for the BW-L3 to resume charging the device. The exception to this procedure is the iPhone; you do not need to reinitiate, it will quickly resume charging when moved back into the sunlight.
For those who are unfamiliar with BW charger, here is a full review of their three panel BW-L1 (over 3000pcs sold to date).
Edited by: freeme on 08/08/2018 - 12:31
freeme
freeme's picture
Interest List (reply in this thread if you are interested - NO PM please).
  1. freeme
  2. netprince
  3. Silent_Star
  4. The Miller
  5. Sledgestone
  6. glockboy
  7. noboneshotdog
  8. Zulumoose
  9. Paul321
  10. MaleNurse
  11. Gea2427
  12. shimey
  13. PBWilson
  14. Abqjohnny
  15. korpzgrinda
  16. Charga
  17. leaftye
  18. garyyoung
  19. yclongthrow
  20. brad
  21. noetik
  22. dw911
  23. kotobuki
  24. weklund
  25. weklund
  26. weklund
  27. weklund
  28. xxx
  29. CJ Avlis
  30. Phlogiston
  31. olivedrab
  32. RollerBoySE
  33. will34
  34. ISO
  35. DBSAR
  36. HighCaliber
  37. rizky_p
  38. my9221
  39. yasenf
  40. g_sintornillos
  41. hunter1
  42. syracuse
  43. Jtm94
  44. mizou51
  45. Anthon
  46. Marcello
  47. Sonofspectrum
  48. tekwyzrd
  49. djozz
  50. baldo21
  51. baldo21
  52. derfyled
  53. MontyPyfon
  54. korpzgrinda
  55. KawiBoy1428
  56. sandanbob
  57. scotlarock
  58. Nicolicous
  59. No Agenda
  60. Phantom1
  61. sac02
  62. sac02
  63. sac02
  64. geepaw
  65. Dutcheee
  66. scdaf
  67. firedome
  68. Beachlogger
  69. jacc
  70. Eggun
  71. bikenber73
  72. Kozy
  73. I_SpY
  74. otonetgear68
  75. Billy X
  76. s1m888
  77. WaylonJennings
  78. Ig
  79. charles lin
  80. richnpc
  81. JPLight
  82. Flomotion
  83. atbglenn
  84. ilovejesuschrist
  85. khas
  86. Koaksijalac
  87. aslpg
  88. nnmnu1
  89. Kindle
  90. jacktheclipper
  91. Minimoke
  92. jamaya
  93. Gj
  94. Petroleum Lantern Guy
  95. JakeDjanitor
  96. acml
  97. Lopan
  98. LightRider
  99. krutone
  100. osb40000
  101. invisiblejules
  102. teachtom
  103. igeigeige
  104. RobertB
  105. AEDe
  106. specialk
  107. ifratos
  108. abril
  109. jfong
  110. adsum
  111. SebaZ74
  112. Vene67
  113. piotrek966
  114. gorb507
  115. Stittville Ed
  116. mizjif
  117. k-wong
  118. two¢¢
  119. TheBo
Jerommel
Jerommel's picture
Last seen: 1 month 4 days ago
Skip to 2:30 when he finally unfolds it…
Nice gadget !
20 Watts is a LOT.
But with the black fabric everything will get very hot in the sun, won’t it?
2Q19
netprince
Last seen: 1 hour 15 min ago
Interested if its a 4 panel and priced right…
Silent_Star
Silent_Star's picture
Last seen: 2 days 5 hours ago
I’m already have this one.
But I want one more).
 Genesis 1:3 "And God said, "Let there be light,"  and there was light."
The Miller
The Miller's picture
Last seen: 10 months 2 weeks ago
How is it? What can and do you charge with it?
Add me Freeme for I want something like this but so many choices it is hard so I figure this mist be a really good one for you would not start a groupbuy for it if it wasn’t Wink
freeme
freeme's picture
For hot sunny day, I think it is better to keep the charging device (mobile phone, powerbank ,etc) under shade.
Jerommel wrote:
Skip to 2:30 when he finally unfolds it... Nice gadget ! 20 Watts is a LOT. But with the black fabric everything will get very hot in the sun, won't it?
Sledgestone
Interested!
glockboy
Last seen: 5 hours 34 min ago
Please add me to the list.
Thanks
noboneshotdog
Last seen: 21 min 54 sec ago
Definitely interested!
Thier ain’t no bones in a hot dog. F. York
Zulumoose
Zulumoose's picture
Last seen: 1 day 6 hours ago
Possibly interested, price dependant.
Beam me up!
Paul321
Paul321's picture
Last seen: 2 days 14 hours ago
Yes, interested in the four panel not the three panel in the video
Paul-
MaleNurse
Last seen: 1 day 10 hours ago
Interested!
Gea2427
Interested if price is right!
shimey
Last seen: 2 weeks 3 days ago
Interested pending price!
PBWilson
Last seen: 1 hour 32 min ago
Please add me to the list. I’m interested if the price is right. Thanks.
Abqjohnny
Last seen: 5 months 6 days ago
I have been wanting one of these. Depending on price
korpzgrinda
korpzgrinda's picture
Last seen: 2 months 23 hours ago
Location: Eastern Woodlands in the Wilderness of North America
Interested to know the price
WaylonJennings
Last seen: 10 months 1 week ago
Very interested.
Charga
Charga's picture
Last seen: 1 month 3 days ago
In!!
' Lumen est omen '
Hope is no option!
leaftye
Last seen: 1 month 5 days ago
Interested.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
garyyoung
Last seen: 2 weeks 2 days ago
Interested.
yclongthrow
Last seen: 1 day 23 hours ago
Interested.
brad
brad's picture
Last seen: 1 hour 40 min ago
Interested but need a review.
noetik
noetik's picture
Last seen: 1 day 20 hours ago
in
dw911
Last seen: 1 week 3 days ago
Interested, depending on price.
Thanks
kotobuki
Thanks
weklund
weklund's picture
Last seen: 2 hours 51 min ago
I am in for (4) please.
Many Thanks.
... Happy Landings ...
xxx
xxx's picture
Thanks
CJ Avlis
Last seen: 23 hours 24 min ago
Interested. Please add my name.
Phlogiston
Last seen: 3 weeks 2 days ago
Please add my name to the list.
My interest depends on the price, though.
