Looking at your (very nice) chart I see that you miss a C8 with XP-L V6 dedomed. It is not that you should have one but with a collection so completeā¦
That's a great chart ZozzV6! Very useful for comparisons. Really like the SST-40 beats the XPL2 V6, even at less amps! And the dedoming, like you said, doesn't lose much in lumens, but still nearly doubles the candela. Wow! I gotta order some more!! Have 3 on the way.
Thanks A Bunch for the meticulous work!!!
Thank you!
Half of these lights are one of my friendās property. And I donāt own 12 C8 at the same time I build some of them for request. And for the SST40 tests I replaced the leds and drivers in my grey c8 which earlier had the xp-l2. I wanted to see what mod worth the effortand what led is the best for a specific purpose. I know that I had to try them all but now I can refer things to people if they had idea for a special flashlight. :innocent:
Higher current means the battery sags faster, so the current is reduced faster than at lower currents. Also the light gets hotter.
Correct. Hotter, less efficient, but with higher peak brightness.
My 219c D4 is not too hot with VTC6. SST-40 has higher Vf curve, so it wouldnāt be too hot with this battery either.
Canāt wait for those VTC5As to arriveā¦.
Lots of work there Zozz. Thanks for sharing. :+1:
I have XML2 U4 dedomed 30+pcs. and SST40 dedomed 20pcs. from KD.
Set up in C8 , A17DD , AR lens.
XML2 U4 higher Vf 5A- 1500- Lumen 130,000Ā±cd
SST40 lower Vf 7A- 2000- Lumen 150,000Ā±cd at Level 7
edit :
1250LM 80,000cd at level 6
My batteries are VCT6 30Q HG2 and LK 26650
Thanks for sharing. I was just wondering has anyone tried a dedomed sst40 in a c8 yet. And hours later, I see your post. Thatās great numbers. Iām loving the sst40 more and more. I need to get me one.
7A is a lot of current draw for single cell fet dd light. I would not want to put that emitter on my single cell fet buildsā¦ Well maybe just one for fun to see how it shines minute or two on turbo
Chunky multi cell lights are different story and they could really benefit from it a lot.
Mine was over 8A
Iām getting 172,000 cd from sst40 in an olight sr52. Not dedomed:) So far its lasting but not sure how long it will.
Edit, I figured out the polarity on my ownā¦
This the correct polarity of the SST-40 LED
Credit for awesome macro picture goes to Djozz
I just finished modding my old Thrunite TN-31 from XM-L2 U4 to a SST40 I purchased from KD, the difference is very noticeable! The resistors on the TN-31 have been bypassed so itās pushing more amps to the led, on ceiling bounce eye test it is almost the same brightness as the XHP-35 HI on Brightest setting of my Acebeam K70, it is definitely pushing a lot of lumens!
Very happy with the mod! :sunglasses:
I do have a convoy l2 with the sst40 dedomeā¦ it put out 1600 lumen and 280k luxā¦ This light doesnāt get warm or hot at the high mode after 5 minutesā¦ I am doing more temperature testing tonightā¦ I can tell you this light have a great heatsinkā¦
On the bright (haha) side, with a lower Vf, itād stay in regulation a bit longer in a 7135-based light as the cell depletes.
@ Alex, since I followed your TN31 mod thread back when you did it, I decided to change my TN31 from the XML2 U2-1A to the same SST-40 emitter you just used. Sense resistors bypassed on mine also. Here are the results:
On the U2-1A dedomed,
408 KCD@5 meters
2043 lumens in my Josh K sphere
SST-40 dedomed same cells@ same voltage
446 KCD@5 meters
2496 lumens
Couple of things to note; my multiplier for the sphere could be slightly off, but I used the same one in both tests. I believe I measured the lux back several years ago, and saw closer to 500kcd when I took the reading at 6 meters.
Just for kicks, I tried some 30 Qās to compare to the protected 3400ās I did the tests with. The results were as I expected, no change.
I have several more on order to try in my multi-cell lights. Too bad the higher binned emitters canāt be found yet.
Noticed while I had the light apart that it had 20g wire to the emitter. Changed that over to 18g and got another little bump to 455kcd
408 KCD@5 meters
2043 lumens in my Josh K sphereSST-40 dedomed same cells@ same voltage
446 KCD@5 meters
2496 lumensCouple of things to note; my multiplier for the sphere could be slightly off, but I used the same one in both tests. I believe I measured the lux back several years ago, and saw closer to 500kcd when I took the reading at 6 meters.
Thanks for sharing scotlarock! So, it confirms my eyeball comparison that the SST-40 is almost as bright as the XHP-35 in the K70 on turbo, Dang! Way to bring the TN-31 back from obsolescence! I am thinking in selling both the K60 an K70 and just keep the TN-31 and the upcoming GigaThrower modded with a XHP-70.2! decisions, decisionsā¦ :sunglasses:
I ordered 3 SST-40 LEDās from Shenzhen Great Technology.
When I opened the sealed bag I saw they all had bubble-shaped inclusions. Some more visible than others.
In the left side LED: multiple incusions on the right side, near the leads. In the middle LED: a small inclusion a bit right of the middle. In the right side LED an inclusion on the far left side, but this is NOT hovering over the phosphor layer.
Now a larger picture of the LED on the right side. The LED is 180deg rotated, so the inclusion is now on the right side.
Are these LED useable, or are they just an accident waiting to happen? Sorry for my inability to take macro pictures.
Something in between I guessā¦ The inclusion is clear so there will not be a great deal of absorption taking place, Iām pretty sure you will be alright even when driving the leds to the max. But if my life depended on itā¦.
Thanks. Then Iāll just struggle on Firing up the old soldering iron, and so on.
