E-switch UI Development / FSM
468 posts / 0 new
ToyKeeper
ToyKeeper's picture
Last seen: 5 hours 45 min ago
I made a UI toolkit for e-switch lights. It makes new UIs relatively easy to create, makes porting UIs to new hardware relatively easy, and makes bugs relatively easy to avoid. But that still leaves a big question:
What makes a good e-switch UI?
So I’m hoping to get some discussion going about what people want in a UI. What’s good, BLF?
ToyKeeper
ToyKeeper's picture
The UI toolkit is called Spaghetti Monster, or FSM for short.
(pictured: the [insert your preferred F-word] Spaghetti Monster)
FSM implements an event-driven finite state machine for cooperative multitasking, and attempts to abstract out most of the hardware-specific details so the main code can focus entirely in the interface.
The basic idea is that you #define some options, #include a single file, and then start writing a UI. The UI consists of one or more State objects for the finite state machine, a setup() function, a loop() function, and whatever else you need for the particular UI.
State objects are actually just callback functions. They take an Event type and a 16-bit integer parameter, and they are expected to return "EVENT_HANDLED" or "EVENT_NOT_HANDLED" depending on whether they do anything with the Event they're given. States can be stacked, so if the top-most State doesn't handle an Event, an underlying State gets a chance to handle it instead. The stacking also means it's possible to have utility States which do common tasks like "ask the user to enter a number, then return to the previous state". It can just pop() itself off the stack and return to the previous State without having to care what that State was.
The setup() function runs once every time power is connected. It should do things like loading eeprom and then pushing a default State onto the stack.
The loop() function runs repeatedly, whenever the MCU is otherwise idle. It's for doing long-running tasks, like blinking out a SOS pattern... or for tasks which shouldn't happen until the system is idle, like going into standby mode.
It can also have a low_voltage() function which runs whenever LVP activates, or this can be implemented by handling the EV_voltage_low Event on a per-state basis. Similar story for thermal regulation.
Otherwise most of the UI code ends up fairly similar to how I usually describe UIs. It's a list of States, and each State has a list of Events it accepts and the corresponding actions to take for each Event.
For example, let's say we wanted the following UI:
  • From off:
    • 1 click: Go to lowest level.
  • While on:
    • 1 click: Turn off.
    • Hold: Ramp up. At highest level, loop back to lowest level.
    • When voltage is low, ramp down then turn off.
The code would look something like this:
uint8_t off_state(EventPtr event, uint16_t arg) {
    if (event == EV_enter_state) {
        go_to_standby = 1; // sleep while off
        return EVENT_HANDLED;
    // 1 click: go to lowest level
    else if (event == EV_1click) {
        set_state(steady_state, 1);
    return EVENT_NOT_HANDLED;
uint8_t steady_state(EventPtr event, uint16_t arg) {
    // turn LED on when we first enter the mode
        set_level(arg);
    // 1 click: off
        set_state(off_state, 0);
    // hold: change brightness every HOLD_TIMEOUT ticks
    else if (event == EV_click1_hold) {
        if ((arg % HOLD_TIMEOUT) == 0) {
            set_level((actual_level+1) % (MAX_LEVEL));
void low_voltage() {
    // step down by one level or turn off
    if (actual_level > 1) {
        set_level(actual_level - 1);
    else {
void setup() {
    push_state(off_state, 0);
void loop() {
    if (go_to_standby) {
        go_to_standby = 0;
        set_level(0);
        standby_mode();
This example is only missing a couple small things to make it actually compile and run, like the option #defines and #include at the top, some declarations, and the set_level() function.
I hope it's fairly easy to read, as far as C code goes, and easy to modify.  The point of all this is to take the "spaghetti code" normally involved in writing firmware...  and lock it in a box where you don't have to see it or care about it.  All the spaghetti bits are hidden away under the hood.
The code isn't merged into trunk yet, but I put a development branch up here:
http://bazaar.launchpad.net/~toykeeper/flashlight-firmware/fsm/files/head:/ToyKeeper/spaghetti-monster/
ToyKeeper
ToyKeeper's picture
Here’s a summary of FSM-based interfaces created so far.
Momentary
A simple on-off interface.
  • Hold the button: Light is on.
  • Release the button: Light is off.
Mostly added as an example.
Baton
Similar to the Olight Baton series.
From off:
  • 1 click: Turn on at last-ramped level.
  • Hold: Lowest level, then ramp up in steps.
  • 2 clicks: Highest level.
  • 4 clicks: Soft lockout.
While on:
  • 1 click: Off.
  • Hold: Ramp up in steps. Loops back from highest level to lowest.
  • 2 clicks: Go to/from highest level.
Soft lockout:
  • 4 clicks: Turn on at “low” level.
Includes LVP and thermal regulation.
DarkHorse
Nearly exact clone of Zebralight’s UI from 2016.
From off:
  • 1 click: High mode.
  • 2 clicks: Med mode.
  • 3 clicks: Blinky mode.
  • 4 clicks: Battcheck mode.
  • Hold: Low mode, then ramp up.
Low/med/high modes:
  • 1 click: Off.
  • Hold: Ramp through low, med, and high… always starting at low.
  • 2 clicks: Toggle between H1/H2, M1/M2, or L1/L2 levels.
  • Click, hold: Change the brightness of current mode’s secondary (H2/M2/L2) level.
Battcheck mode:
  • Blinks 1 to 4 times then turns itself off. (0 blinks for less than 3.0V, 5 blinks for more than 4.2V)
Blinky mode:
  • 1 click: Off.
  • 2 clicks: Go to next blinky mode. The sequence is:
    • 0.2 Hz beacon at L1
    • 0.2 Hz beacon at H1
    • 4 Hz tactical strobe at H1
    • 19 Hz tactical strobe at H1
Remembers a few things after battery change:
  • Primary or secondary toggle for high/med/low.
  • H2/M2/L2 levels.
  • Which blinky was last used.
Andúril
Fancy all-in-one UI inspired by Tom E’s fantastic Narsil. It’s still a work in progress, so it’s expected to change.
I should probably mention that the smooth and discrete ramps have independent floor/ceiling values. You can have one with the ceiling all the way up, and one with the ceiling at a comfortable safe level. Or you can have one with moon and one without.
Discrete ramp mode has anywhere from 2 to 150 steps, spaced evenly (or as close to “even” as possible with integers).
A “hold” always ramps up, and a “click-release-hold” always ramps down.
Sorry about the 5-click action for momentary mode. Too many states available from “off”.
Beacon and momentary mode use the last-ramped brightness level.
Momentary mode is permanent until power is disconnected.
“Good night” mode starts at low and slowly ramps down for an hour, then shuts itself off. Intended for tail-standing next to a bed at night.
I set the PWM levels to start at 1/255. Depending on the hardware, this may be too low to make any light. However, the ramp floor can be set to whatever level you think looks good.
Config modes are similar to bistro — they blink out a number, pause, then “buzz” for a while. Click during the “buzz” to set a new value. It’ll keep buzzing as long as you keep clicking. If you want to skip an option, just wait without clicking.
Settings which are remembered after a battery change:
  • Smooth ramp floor / ceiling.
  • Discrete ramp floor / ceiling / steps.
  • Beacon timing.
  • Temperature limit.
  • Which strobe mode was last used.
  • Bike flasher brightness.
  • Party strobe speed.
  • Tactical strobe speed.
Includes LVP and smooth thermal regulation.
Werner Dual-Switch
Since it’s a thing people might want, and since I think Lexel may have been requesting it, I took a moment to make a Werner-style momentary UI, side e-switch plus tail clicky-switch.
https://code.launchpad.net/~toykeeper/flashlight-firmware/fsm
The short version is:
While completely off (power disconnected):
  • Click tail to turn on at memorized level.
  • Hold e-switch and click tail to enter utility mode.
While on (regular “on” mode):
  • Click tail switch to turn off.
  • Click side switch to go brighter.
  • Hold side switch to go dimmer.
In utility mode:
  • Click side switch to go to regular “on” mode.
  • Hold side switch to go turn on at lowest level.
  • Double click side switch to turn on at highest level.
  • 3 clicks: Battcheck.
  • 4 clicks: Ramp config.
Battcheck mode: Blinks out battery voltage.
  • Click to go back to utility mode.
  • 2 clicks for tempcheck mode.
Tempcheck mode: Blinks out current temperature in C.
  • 2 clicks for battcheck mode.
  • 4 clicks for thermal config mode.
Ramp config:
  • During first “buzz”, click N times to set floor level to N out of 150 total levels.
  • During second “buzz”, click N times to set ceiling level to 151 minus N.
  • During third “buzz”, click N times to set number of total brightness steps.
  • Each “buzz” can be skipped to leave the value as-is.
Thermal config:
  • During first “buzz”, click N times to calibrate current temperature to N degrees C.
  • During second “buzz”, click N times to set thermal ceiling to 30 C + N.
Includes LVP and smooth thermal regulation, copied directly from Anduril.
djozz
djozz's picture
Last seen: 30 min 57 sec ago
I think there’s 2 good types of UI:
1) one that is so simple that it works for everyone without thinking, on-off is one of those glorious UI’s, but ramp up-ramp down is another one. There’s no objection against safety measures going on in the background, like reverse polarity protection, LVP and thermal management.
2) a UI that can be configured to anyone’s preferred simple or difficult UI, so also the ones in 1) , but any variation should be possible. Key is that once it is configured, you just notice your simple UI and no surprises happen like unintended strobes or blasts in your face. I was very charmed by led4power’s LD3 user interface, although it is a clicky UI.
(If the BLF-A6 driver was available in just ramp up/ramp down with background safety stuff, I would swap all my drivers.)
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
Lexel
Lexel's picture
Last seen: 1 hour 38 min ago
I think NarsilM is close to be perfect,
if you like more options to play with and understand how to change the settings
also in modes its quite simple to operate
ToyKeeper
ToyKeeper's picture
I filled in the “reserved” posts #2 and #3 with a summary of the toolkit and a summary of what has been made with it so far.
I agree that NarsilM is pretty dang spiffy, to use some awkwardly mild words for it. I always wanted to change a few things though, which is how I ended up with the unnamed UI in comment #3.
I don’t know what to call it though. Maybe I should call it “Supafly”. Silly
djozz wrote:
If the BLF-A6 driver was available in just ramp up/ramp down with background safety stuff, …
I’m not sure if it would interest you, but have you looked at Crescendo? It runs on a BLF-A6 driver and does smooth ramp up/down with background safety stuff like LVP and thermal regulation.
Also a bunch of blinkies, but those can be compiled out or avoided.
korpzgrinda
korpzgrinda's picture
Last seen: 2 days 12 hours ago
Location: Eastern Woodlands in the Wilderness of North America
LOL Nice thread TK! Love them flowcharts! Wink
that deathstar moon… !!!Big Smile
May I ask, what is the Good Night blinkie mode?
deathless
Last seen: 1 day 20 hours ago
May you be touched by its noodly appendages.
Keep up the great work
ToyKeeper
ToyKeeper's picture
The “good night” mode starts at “low” and slowly ramps down for an hour, then shuts itself off.
It’s not really a blinky, but there wasn’t a more appropriate place to put it. And I like to do battcheck on the way to goodnight, so that puts them right next to each other. Perhaps I should call that group “specials” or something instead of “blinkies”.
leroycp
Last seen: 2 hours 48 min ago
Thumbs up to “unnamed” and crescendo. Both perfect
Tally-ho
Tally-ho's picture
Last seen: 17 hours 47 min ago
I really would like to see something like an HDS clicky UI.
I’m still using my HDS with SSC P4 (100 lumens) despite its dim LED just because of the excellent tint + CRI and very particular UI.
I didn’t play with most recent UI then I don’t know if HDS UI is still worth it.
tekwyzrd
tekwyzrd's picture
Last seen: 2 weeks 4 days ago
The term ‘goddess’ is well-deserved. Wish i knew you in the everyday.
bansuri
Last seen: 6 hours 9 min ago
I hope “unnamed” makes it’s way into some drivers. I have some nice lights that have uninspired UIs, I would gut them all in a heartbeat for this.
It looks like a fast click always leads to OFF, that is great in case a user has a finger spasm or a non-flashoholic gets a hold of it and starts spazzing with the button.
Just turn it off.
I used to love the programming options of HDS and Liteflux but they have gotten way too expensive for me.
Beacons, strobes, the brilliant Good Night, they’ll all get used.
Some O-lights have a little 1 or 2 minute timer, I’ve always wondered why they didn’t make it longer. It’s pretty cool to put next to the bed at night…well… cool for 2 minutes. One that ramps down over the course of an hour would get used every night.
Maybe this will show up in the D1?
Great work TK!!
Mayor Glenn Welsch: There's a saying in Missouri, if you don't like the weather just wait five minutes. In Blaine, with hard work, I think we can get that down to three or four minutes.
ToyKeeper
ToyKeeper's picture
I decided to try cloning the Meteor M43 UI tonight.
First I cloned UI1 — no problem.
Cloned UI2 — no problem.
Started on UI3 and then I noticed… it has different actions defined for “short click”, “long click”, and “hold”. And different actions for “two short clicks”, “short click then long click”, and “short click, then hold”. Facepalm
No wonder I could never get some of the actions to work reliably.
Otherwise it’s going well though. I’ll continue later when I get my palm unstuck from my forehead.
joechina
Last seen: 12 hours 2 min ago
In SM: Unnamed
what is the difference between
from OFF: 2 fast clicks
from OFF: click, then hold ?
Are the tips of the two green arrows pointing right?
My guess:
go to a temperature secure level below TURBO.
If I want then TURBO I must double click.
goes to the same line. o_O
maybe this should point directly to TURBO?
Joe
electricjelly
electricjelly's picture
Last seen: 1 week 1 day ago
I’m really liking the looks of the unnamed UI. The user configurable floor and ceiling within the ramp range is a very nice feature. I also like the ability to switch between smooth and discrete ramping on the fly without going into configuration settings.
Awesome work as always.
ToyKeeper
ToyKeeper's picture
joechina wrote:
In SM: Unnamed
If you double-click from off, it goes to the ramp ceiling level and stays there.
If you click, release, then hold from off, it goes to the ramp ceiling level and ramps down. It’s like a double click, except you hold the second click and it ramps until you let go.
Basically, it lets you navigate from the top or bottom from off. So, there isn’t really any need to configure whether modes are in low-to-high vs high-to-low order, because you get both.
JaredM
JaredM's picture
Last seen: 1 day 21 hours ago
Wow TK. Excellent work as always! Thumbs UpBig Smile
I thought of a UI before reading this and was very pleased ( and reassured ) when I saw your Unnamed ‘Supafly’ UI. It’s extremely similar to what I was thinking!
There are a few minor differences, and these are my preferences. (to be taken as my $0.02 )
From off:
‘S’ = short click ( 'L' = long click (> 0.5s)
‘+’ = <0.5s
1L > Min/Moonlight
1S > md1 or “low-med” memory, user determined
1S + 1L > md2 or “high-med”, user determined
2S > Max/Turbo
3S > Off effectively, but with one Turbo Flash (the “HEY! LOOK HERE!” function)
4S > md1 effectively, (with aforementioned pre-flash)
5S > Blinky Special
Note: From BOLD levels, continue to hold to ramp UP. Delay start of ramp for 1.5-2 sec
Clarification: The difference between md2 shortcut and md1 then ramp is determined by duration between clicks, or “double click speed”
From on (when on-time > ~0.5-1.0s ) :
1S > off
1L > ramp towards center
1L pause 1L > reverse ramp
2S > Turbo/Max [ if again] return to previous level (if previous level was OFF, then go to md1)
1S + 1L > Momentary Turbo/Max
3S > blinky
beyond here I don’t have many strong preferences.. mostly because I haven’t thought about it much yet.
I might be biased, but I think that’s the ticket SmileBeer
patmurris
patmurris's picture
Last seen: 2 days 15 hours ago
Great work as usual TK!
Regarding the question “what is the best single side switch UI”, i share djozz comments.
Apart from my personal preferences the one thing that worries me the most is whether a non flashaolic can use a light without any explanation. We enthusiasts tend to forget about it, but most people only think about flashlights as something you turn on and off, providing a decent brightness level – not moon/firefly or blindingly bright turbo either. A mid level usually provides more then what they would expect anyway.
Some UIs offer different mode groups, including a ‘simple’ one, but you have to switch group and you may not be around to do so if someone needs the light on his own or in an emergency. So i think the above described behavior should be the default in any UI.
As a side note, i’ve witnessed that ‘people’ can easily resort to a long press if things don’t act has they expect. It seems natural to press a switch harder and longer when in doubt. That’s something to consider while designing a UI.
One of my favorite UI is the DQG Tiny 26650 3rd. Single click goes off/mid/off – providing 8 hours at 600 lumen. Long press from off goes to turbo then single click off. While on, long press cycles through modes.
I did also like the good old SRK style UI. off/high/mid/off all single clicks. Anyone can figure it out. I’d rather have off/low/mid/high/off but you get the idea. Double click goes disco on some.
Tixx
These are awesome!
SupaFly is just that!
I would love to get Crescendo on a couple of my A6 drivers, but would never be able to accomplish this myself.
Since this is the proper place for it, my suggestion was to turn the double blink when installing a new battery to moonlight instead of something bright like now. Reason: If you unscrew the cap for lockout and use the light in the middle of the night, you have to see 2 bright flashes first.
Second was no memorized moon or turbo since shortcuts already exist (this was someone else’s suggestion which I liked)
Thank you!
allcool
My rookie input...
Make a simple from off, hold button to ramp ui, 1 click to memory and devote the rest of resources to a better Thermal regulation sampling system and smooth hiccup free ramp.
Going on the premise of heat is the worst enemy of durability/longevity/lumens,,,
Then maybe create an advanced ui/hardware that allows individual heat sensors for each led to show/control its individual performance, maybe helping troubleshoot a problem with that led circuit/dtp/etc, that makes it run hotter, lower lumen, etc, With a hardware/ui system that lets one turn on/off each individual led and regulate power level of each led...? this would be a flashoholic only Ui, or maybe just a pipe dream...lol
My only fear is on improving the heat reg is that the on chip heat regulation/sensor without remote sensor is not ideal for the fastest most precise, consistent, efficient heat regulation. So until a dedicated circuit/chip is used, maybe with a remote sensor soldered on the dtp, then all the software in the world won't help..?
jmo
mozart.f
Last seen: 1 min 59 sec ago
Hi TK.
Is it possible to share the unnamed firmware?
Thanks.
joechina
ToyKeeper wrote:
joechina wrote:
In SM: Unnamed
Ah, thanks.
I couldn’t get that from the flowchart
dave1010
Last seen: 6 days 16 hours ago
The “good night” mode sounds great. If the timer in a flashlight is good enough for that kind of thing then I wonder if you could make an alarm clock mode that slowly ramps up the light after a programmed (with clicks) time.
ToyKeeper
ToyKeeper's picture
In general terms, I agree. The tricky part is translating that to specific implementation details — especially if the UI is intended to satisfy both enthusiasts and muggles.
The common 3-mode SK-68 UI (high, low, strobe) is very muggle-friendly but enthusiasts usually hate it. Or the HiveLD driver has lots of features for enthusiasts, but it requires a 9-page manual to operate, and setting config options requires a soldering iron and a metronome.
Getting both power and simplicity at the same time is somewhat tricky. The “unnamed” UI definitely errs more toward power and less toward simplicity. That’s kind of the point of it though — to be fancy and full of features that I want on my personal lights.
ToyKeeper
ToyKeeper's picture
That was a thing I left alone in the D4 interface. On my custom UIs though, I generally do a single very-quick blink when power is connected. Very very quick. Unless it’s intended for a dual-switch light (e-switch and power cut switch), in which case it definitely shouldn’t blink at power-on.
The quick blink can be just as bright, but it doesn’t look as bright because it’s so short. Regardless, if you don’t want to be seen, it’s a good idea to cover the front of the light while tightening the tailcap.
It could perhaps be made optional, or I could maybe add a lockout config option to specify whether lockout blinks on exit or not. With soft lockout on 4 clicks, I usually go for that instead of unscrewing the tailcap. Perhaps it could have two or three modes: blink on exit, moon on exit, or no feedback at all.
ToyKeeper
ToyKeeper's picture
allcool wrote:
better Thermal regulation sampling system and smooth hiccup free ramp. …
I have some ideas for improving thermal regulation, and plan to try them soon. It won’t take the entire rest of the ROM though.
About the ramp blinks, those are there because people requested it. Before, the ramp was actually too smooth and left people feeling lost, with no idea how bright it was or how long it would run.
But if the space isn’t needed for other things, it would be relatively easy to add an option to toggle the ramp blinks.
allcool wrote:
individual heat sensors for each led to show/control its individual performance … until a dedicated circuit/chip is used, maybe with a remote sensor soldered on the dtp, then all the software in the world won’t help..?
Bingo. That’s not a software thing. The software has access to only one pixel, one button, and one poorly-placed thermal sensor.
ToyKeeper
ToyKeeper's picture
Yes, but not quite yet. I’m still working out a few details. Mostly trying to coordinate with other people, which takes time.
The timer is pretty good (in my test, it timed an hour to a precision of less than a second), but waiting 8 hours before turning on is a little tricky. It would mean one of the following:
  • Leaving the MCU on all night, at about 5 mA, so ~40 mAh power used each night just waiting.
  • Implementing a special “twilight” half-sleep mode specifically for things like this alarm clock mode. (like standby, but the WDT would wake up every couple seconds and send a “tick” to the current State handler, with ADC turned off so it can’t sense low voltage)
I don’t like that first one, because 5mA is really high for a mode where it isn’t doing anything. I may be able to make the second one happen though, and it might be kind of nice for other things too (like controlling an indicator LED during standby mode).
In any case, if you want a light to blast in your face each morning, that might be do-able. Smile
(it’s just going to need a bit of plumbing work first)
(OTOH, timers exist which plug into wall outlets and turn on whatever they’re connected to at a specified time, so that’s probably a cheaper and easier way to do it)
mozart.f
TK, as you already stated, a refined thermal regulation would be a welcome feature. Perhaps the possibility to config in the ui it’s sensitivity to react to temperatures changes, and the correspondent amount of decrease and increase of power to the emitter(s), would permit a fine tune of this function to the many different setups that we use in ours lights (small and big hosts, single and multiple emitters, drasticaly different levels of driver current etc).
ToyKeeper
ToyKeeper's picture
I have a SRK with Q8 driver, and a D4, and hopefully soon a D1, to test on. If I can make the thermal regulation “just work” on all those, it’ll probably be flexible enough for most purposes with no need to fine-tune anything. Hopefully the physical traits (like power level and thermal mass) will give the regulation enough feedback to adjust itself. Like, a big light heats up slower so it can react slower or in smaller steps.
However, that said, at a firmware level there are quite a few knobs to tweak, to make sure it reacts at the right speed and intensity without oscillating. And I need to test with tail-standing and no fan, since that was a scenario where the D4’s regulation would over-shoot and then take a long time to recover. It did fine with a hand to sink heat to, or with moving air, but the stagnant air case didn’t behave very well.
mozart.f
TK is it possible to add in the blinkies the heart beat and the sos like Crescendo have?
