Out of curiosity, I tested thermal regulation on a light with a H17F driver, a brand new Okluma copper DC2. Jeff sent me one to thank me for all the free code, and perhaps also because I think he might want an open-source version of it. And I graphed it against my D4-219c with FSM:
The H17F thermal ramp-down is as smooth as it can get (the occasional bump was because I was holding the light and I moved). It seems to step down at a maximum speed of two PWM levels per second on FET modes or one PWM level per second otherwise, one channel at a time, until the temperature is no longer out of spec. This makes it really smooth but also really slow. Eight minutes to reach stable state at the configured temperature limit.
My FSM-based D4 also steps down one PWM level at a time, but itās much faster, up to 8 adjustments per second. It looks just as smooth in person, but it reaches its destination(s) sooner and then is a bit more jittery after reaching stable state. One minute to reach stable state in this test, and another minute for the aluminum bodyās outer temperature to catch up.
The DC2ās slow response seemed appropriate though, because it has a massive chunk of copper to sink heat into. It never got too hot to hold; the outside of the light stayed a pretty steady temperature.
Meanwhile, the higher-powered D4 has only a small chunk of aluminum, so it got painfully hot during the first minute even though it was stepping down so fast. It remained pretty hot during the second minute, but it did not continue to ramp down because the predictive algorithm figured out that there was no need since the temperature was already decreasing fast enough.
As a side note, I need to recharge the DC2ās battery and measure its maximum output properly. Its vertical scale on this graph may be a bit off ā IIRC it was about 2300 or 2400 lm at the beginning but I need to double check.
Itād be interesting to see how each light behaves with the drivers swapped. Thatās not very feasible, but sometime soon I should at least be able to measure FSMās behavior on a larger light, a SRK or Q8. If my guesses are right, it should still work fine with more thermal mass and should adjust output more slowly, because the extra thermal mass reduces the rate of change and that reduces the magnitude of response.
ā¦
Itās not shown in the graph, but afterward I held a block of ice against the DC2. The output ramped back up, but it was just as slow as when it ramped down. Even with the light literally ice-cold, it was still slow. The D4, however, when itās that cold, increases the output rather quickly. Itās not quite as fast as the initial ramp-down, but itās still relatively quick.
