➡ (GB) STATUS:ACTIVE !! ;-) Klarus P20 Nichia219C
I listed another minisize, perhaps more interest?…or not….
Biggest yes for me. :slight_smile:
I’m interested.
I have some interest in the E20R. It reminds me of the Jetbeam EC-R16, though this one has more output.
maybe—not really — the jump from 1 lumens is too much
what really makes sense is a log scale
1 3 10 30 100 300 1000
every level is about 3x the previous
these levels, make no sense , basically
also what would the cost be?
over $30 no way
i also wonder why they say
\Features:
-Mainly used for outdoor camping,EDC,adventuring,searching,rescuing,etc.”
what does that mean? they expect someone to pay more for something so ‘specialized’?
why is not suitable for carrying all the time, work, home, car?
wle
6 modes…no thanks. 1/3/10/30…this does not make any sense, sorry. 4 modes for go from 1 to 30 lumens in a edc with side switch…,?:person_facepalming:
all i can say is, you have apparently never seen this kind of log mode spacing
the reason for it is, the jumps appear even to the eye
could be any factor
1 4 16 64 256 1000
also with memory there is no reason to start on 1
astrolux S1 does a good approximation of this
wle
CUTE!!!
I know this is going to be too expensive for me, so I will keep it at the $12 On The Road M3 clone (Olight clone) with USB charging and clip i just ordered today.
Or is this one actually affordable?
still, want to know parasitic drain (important on such small cell) and see a review.
But CUTE for sure!
Sure, sir, I know enough about logaritmic perception…… Ultracompact lights for keychain and EDC do not need tons of modes. I respect your opinion.
Is good the logaritm for the tool? (before broke by the alkaleaks case) Enough for bought you one at least….
Although you do not believe it, I have some experience in flashlights, …. test, reviews … perception …. etc.
In! :sunglasses:
That is exactly why manufacturers ought to check Bistro and Narsil out, now it is often/almost always lots of preferences and a limited choice, while there are suchbgood firmwares where each user can set it up just how they prefer.
I’m interested
I do like the Klarus! Although I can’t really figure how it works from their description.
Hi djozz, from user manual:
Operation
When OFF, click the side switch to enter into the last
memorized mode when last powered off, click to change
mode, cycle through moonlight(1LM)→Low mode
→Medium mode(45LM)→High mode(600LM or 305LM);
Long press side switch for 1S to enter into the moonlight
mode when OFF.
Long press side switch for 1S to turn OFF when ON;
Quick double-click the side switch to enter into strobe
when the side switch is unlocked; Double click again to
enter into SOS and click to exit.
Lock-Out
Long press the side switch for 5S to lock the flashlight
controls. Press the side switch three times to unlock the
flashlight (The lamp will flash three times to indicate
status change and will flash twice to indicate the
flashlight is failed to unlock).
Battery Capacity Indicator
When OFF, press the side switch three times, the main
lamp flashes to indicate the battery capacity:
Three times: 70–100 capacity;
Twice: 30–70 capacity;
Once: less than 30% capacity;
The lamp flashes twice every three minutes when battery
at less than 10% capacity, replace battery
immediately;
Note: The lamp will display as above only when using
16340 Li-ion batteries. ”
Interested in both.
Interested in both!
Interested in both Thanks
do you have a link please ?
thanks
I was not allowed to post links/ specs within this thread!!! (??)
looks good, is there are going to be 18650 version?
I like the Mi1C. Smaller than the Olight S1baton, now that is small.
Olight: Diameter=21mm, Length=61mm
Mi1C: Diameter=20.5, Length=54.5mm
But I’m not sure I like this statement: “Fade-in and Fade-out function when the turbo mode is the initial mode for on and off to promote eye safety and improve user experience.” I don’t like lights that have 100% as the first level - it makes sense for police/fire departments (actual tactical use), but not for me where I don’t want to blind myself each time I turn on the light. I would need to know more about how the UI works before considering ordering.
