Interested
Interested in two, especially if it’s fairly lightweight. Anker has a version that’s reasonable weight wise. I backpack quite a bit so weight is a huge consideration. That said, durability is also key which is usually on the other side of the spectrum from weight.
I’m interested depending on price as well!
I’m interested, depending on price. Thanks
interested, kindly count me in. thank you!
I’m interested
Intrested
Interested pending price
Interested
Interested if the price is right.
Interested
Final specs and product pics can be found in OP.
Interested!
Spec looks good, although this FAQ question gave me pause:
Most solar cell manufacturers warrant a 25 year service life for things like rooftop modules. The 4 to 5 years specified by Blitzwolf seems very short in that context. Is there a reason why the service life for this portable panel is so much shorter?
I believe it’s because these portable panels are subject to more use and abuse being stuffed in a backpack, folded and unfolded numerous times and are generally put in harm’s way much more often than a rooftop panel. True, rooftop panels must contend with weather, but they aren’t being physically manipulated over and over. My thoughts anyway.
PET, polyethylene, is going to get damaged by the sun. You’re not going to see much of that on roofs.
Interested
In
