TK's Emisar D4 review
Mine was from Hank and the bezel was hand tight and came off without any issue.
I needed a rubber gripper, but once I used that my bezel was loose. My D4 was of the latest batch from Mountain.
i was not able to unscrew mine either at least with bare hand, but with the help of non slippery glove it unscrew just fine.
I got a green D4 from Mtn.
The bezel seems to be glued on.
Far more difficult than hand-tight anyway.
None of the D4 bezel is glued, all you need is a bit more force.
But I advise the user do not try to unscrew the bezel (what is the need anyway?), the tightly screwed bezel is crucial
for the heat sinking.
Hank no D1 yet on your website?
So how do I get to the bicycle “stutter” strobe settings? Multiple clicks don’t seem to do it.
reading your quote made me realize there isn’t a strobe on the D4, just the beacon :frowning:
Thank you, I will buy one.
I know that fasttech has some holsters:
https://www.fasttech.com/category/0/search/p/0?&keywords=Holster
Maybe this:
https://www.fasttech.com/products/0/10005190/1411401-ultrafire-nylon-flashlight-holster-black
I’m not sure which is the best fit.
Hi gregor:
The ganzo holster also available in fasttech (not aff.) at 1,87 USD
Ganzo holster in gearbest (not aff.) at 1,23 USD
The Ultrafire of fasttech that shows at 2,88 USD is interesing, some one Can confirm that fits fine?
I nobody else have this FT ultrafire holster, I can buy it and report my findings.
How quickly is FT with delivery. I last ordered from them long time ago and I think parcel arrived in around 1 month, not very quickly.
Fits snug in a magazine pouch. Will probably fit the D1 as well.
Emisar D4 Clip
I have been looking for a suitable clip for the D4 also. Today i tried using a clip from a Convoy S2+, it is almost a perfect fit except it is a little long.
I also used heat shrink tubing around the ring area of the clip to protect the body from scratches. Tubing dimensions are 4mm in diameter and 24mm length. Used a small torch.
Very easy mod to do and should be ok for now until i find a more suitable clip.
Here are the links to pics showing what it looks like.
  1. To add GITD.
  2. (Maybe later) To replace the emitters.
Is that a standard 18350 body? And a trit?
Just ordered a Gray D4
It’s heavily modded by CRX.
I got around to installing an old Solarforce clip on my green D4 tonight. As I read about here, I needed to open up the inside diameter a little and install a conductive spacer inside the tailcap.
Hello, jfg! Welcome to BLF! :slight_smile:
Does your name have anything to do with coffee?
My SolarForce L2 clip has been working pretty well, but I should probably find something a little better than a paperclip to use as the spacer. It seems like the paperclip has reduced maximum output a bit.
The clip itself could stand to be a bit shorter, since it routes fabric directly into the edge of the clip groove. It’s not bad though, and I appreciate the wide opening on both sides of the contact point. It’s also nice that I can add/remove the clip without scratching anything.
Yeah, sorry, there is no strobe or bike mode on the D4.
I enjoy some blinkies at times, especially party strobes, but those weren’t part of the D4 design. If you ever get the chance though, it’s fun to play with water under a motion-freezing party strobe.
