None of the D4 bezel is glued, all you need is a bit more force.
But I advise the user do not try to unscrew the bezel (what is the need anyway?), the tightly screwed bezel is crucial
for the heat sinking.
I have been looking for a suitable clip for the D4 also. Today i tried using a clip from a Convoy S2+, it is almost a perfect fit except it is a little long.
I also used heat shrink tubing around the ring area of the clip to protect the body from scratches. Tubing dimensions are 4mm in diameter and 24mm length. Used a small torch.
Very easy mod to do and should be ok for now until i find a more suitable clip.
Here are the links to pics showing what it looks like.
I got around to installing an old Solarforce clip on my green D4 tonight. As I read about here, I needed to open up the inside diameter a little and install a conductive spacer inside the tailcap.
My SolarForce L2 clip has been working pretty well, but I should probably find something a little better than a paperclip to use as the spacer. It seems like the paperclip has reduced maximum output a bit.
The clip itself could stand to be a bit shorter, since it routes fabric directly into the edge of the clip groove. It’s not bad though, and I appreciate the wide opening on both sides of the contact point. It’s also nice that I can add/remove the clip without scratching anything.
Yeah, sorry, there is no strobe or bike mode on the D4.
I enjoy some blinkies at times, especially party strobes, but those weren’t part of the D4 design. If you ever get the chance though, it’s fun to play with water under a motion-freezing party strobe.
I used a piece of solid copper wire. I had flatten it with a hammer to allow the tailcap to tighten down enough to keep the clip from rotating around.
Its not ideal. I’d prefer a clip attached with screws, but this solarforce clip is alot more secure than a snap on clip.
Question for Hank Wang — can you sell extra tailcaps?
I want to try some drilling and fiddling to attach a belt clip and lanyard/split ring attachment point.
Finding a copper ring/washer the right size to fit in the tailcap to use the Solarforce belt clips would also be good.
The main problem I have with this flashlight is it’s easy to drop.
And the very last thing I’d want to happen is to drop it while it’s heating up and have it land in an unreachable place and start a fire.
