I have questions regarding the battery:
Are those 8 “normal” 18650?
The pack looks pretty non standard to me.
Can the cells in the pack be replaced?
I have many unused Panasonic 18650 3400mAh cells here.
Could I just solder them together?
Is it also possible to just use 8 cells and put them in, as they are….?
I’m pretty sure there isnt. Active cooling would be a whole other animal plus it would require pathways for cool air to enter and hot air to escape. This light doesn’t have that. It looks like it just let’s air in to expose more of the internal heatsink.
I’m still not sure if they kept the plate design heatsink from the video. Promo pictures show a different design.
Not. There is not ventilador. Combine step down, electronic thermal control, and air circulation. Im happy whit his thermal performance. I do not publish this data because can be very different whit the News modifications
Thanks
Can’t imagine it helps a great deal with those tiny holes
If you get the new head, could you use a piece of aluminium foil to close them and see if it makes a difference?
