Would someone mind checking their Thorfire TK4A for me?
3 posts / 0 new
WillyD
Last seen: 1 week 3 days ago
Can you tell me if there’s a spacer between the reflector and the MCPCB? There’s a hundred pics of this light on here, but I can’t seem to tell for certain if there’s a spacer or not. I’m putting one back together and I don’t recall if it had a spacer. Also, the diameter on the small side of the reflector is an oddball size that doesn’t fit any standard spacers I have which leads me to believe it either sits directly on the board or I need to make a custom spacer. Thanks!
RobertB
RobertB's picture
Last seen: 21 hours 33 min ago
I can see a white centering gasket in mine looking down the reflector, but how’d you get the head off? Mine is glued on tight as a drum
WillyD
Thanks Robert! The glue loosens up when hit with a blowtorch. That’s the only way I can get these apart.
