Yep.
:+1: chocolate ice cream sandwich
Today I got the brass pillars made up which will hold the front & back cover plates in place.
These are made from sixteen 5mm M2 brass standoffs which I soldered together :TIRED:
Shown in the first picture is the back copper layer with the standoffs screwed in prepared for bonding the two bits of wood and copper mid layer together.
The second picture shows the copper heatsink bridge which connects the mid layer to the bottom for a thermal pathway.
The third picture shows the two rosewood pieces bonded to the copper mid layer with toothpicks in the screw holes to keep them clean.
Ready for filing into shape I used tightly wrapped tape for support to the temporary alignment screws so less pressure would be on them.
Roughly filed into shape, looking square on all sides :THUMBS-UP:
This gives you an indication of the size of the unit
Time to drill out the front hole for the quad emitters.
I used progressively larger drill bits then a rounded file to get most of the material out, still needs neatened up some but this is where the circles I scribed earlier were very useful.
Today's Tune:
www.youtube.com/embed/lltOuJBkDDA
Your builds are always so over-the-top crazy complicated and/or super difficult. This one is obviously no slacker in that regard. WOW! Iâm impressed. :sunglasses:
Thanks mate, that wasnât through choice and only half the story with the standoffs, I couldnât find any longer versions that were thin enough.
I had originally planned to use thicker ones but soon realized the wood would not tolerate any larger sized holes through it given the close positions to the edges, real headache there, about two hours soldering these things together straight, building it up only to have them snap off at different places one at a time when I tightened up the faceplate screws :laughing:
So I had to then redo the whole lot with threaded 2.5mm2 solid copper wire soldered through inside.
Donât ask how you thread 2.5mm copper wire
Looking good CRX. You are gong to have to get a thicker wallet to hold this credit card sized light.
I must of missed the bit about threading 2.5mm copper. How did you do it?
Trade secret
I hate that trade person. He has to many secrets.
Got some work done on the electrical components today.
First the UV array which will surround the quad emitters. Using an old P60 reflector as a guide I shaped some 1mm solid copper wire into a circle and cut to length so the diameter measures 24mm and soldered the ends together. I then used an old optic as a guide to mark out the eight flat top UV LED positions.
I cut the negative pins so the total length is just under 7.5mm then removed some red sheathing from 28AWG silicone wire and slid onto the positive pins & soldered each emitter into place on the side of the copper ring. I then bent the legs into shape and soldered on some extensions and a resistor for each LED then added some 28AWG wire to each for connecting and finally did a quick test :THUMBS-UP:
I will straighten the emitters up later.
I also got most of the other components ready with leads, resistors etc Is this all gonna fit?? :))
Today's Tune:
www.youtube.com/embed/naiXjU03cV0
it will be a tight fit ! Will you drill holes for the UV leds around the optic hole on the top plate ?
The hole in the plate will be about 30mm, optic 24mm, LEDâs 3mm each with 34mm x 2mm glass on top.
Brass insert tubes for the charge indicator and momentary switches installed today, 3mm OD, 2mm ID.
Shown here is also the copper heatsink block for the charger board.
Using 2mm solid acrylic rod to carry the charger indicator light to the exterior.
Hole slightly countersunk, brass tube epoxied in place and acrylic rod fixed in place.
The end of the rod at the charger LED's is sanded rough to reduce the TIR effect and carry more light.
Same technique for the top brass inserts with a temporary light source to show effect through the acrylic rod.
Today's Tune:
www.youtube.com/embed/GX8fd3ZRbV0
Nice. :+1:
Looks really good already :+1:
Thanks very much guys :BEER:
More switch details, a piece of 2mm acrylic rod cut to size and a few layers of aluminium tape around it for a guide for the GITD resin mix then kapton tape around that to create a well for the resin compound, this serves two purposes, keeping the plunger from falling out and it will also be internally charged from the UV array/ quad emitters.
Tape removed and the resin filed to shape.
Some copper around the acrylic for a very snug fit inside the brass switch slide tube. Silicone grease will also be applied in the tubes.
These are such great ideas, and your pulling them off very well.
You must have good eye sight or good glasses.
Beer Goggles
