The SRK design has always mandated button top cells. And to get the most output from the Q8 you’d want unprotected high drain… but that’s just an option. Nothing different from a ‘regular’ SRK clone there.
Would this end up being like Supbeam K40M in a smaller package? I love the super-wide beam that throws pretty well of that light. It is one of my favorite “general use” lights for sure. If BLF could build a similar wide beam/nice throw light in a smaller package I would buy two for sure.
The circular CBT90 and CBT140 are not COBs, it is a single LED, and they are about as efficient as cree LEDs.
The only difference is that instead of being 6 or 12v they are 3v and much higher current.
Yes Jerommel, when a zoomie is done as BLF special I have something to do with it can only be a tad strange, so double lens or some sort of wavien thing.
I have seen your Brinyte and have a Jaxman Z1, no point in making a regular, those are available in good quality already
I’m not sure if the BLF Lantern project is still on your table as a future project, but many would still like to see that be added hopefully in the future.
As to efficiency, if I read the datasheet correctly, the top bin of CBT-90 does 2100 lm at the rated current. That’s 9A. At this current Vf is 3.1 V. So 75 lm/W. In Texas Ace tests of XHP35 E2 bin we see the same output with c.a. 100 lm/W. There’s HI E4 available.
ADDED: that said, I’d love to see a big thrower based on CBT-90.
ADDED: though probably compact 3*18650 package is (by far) not enough to make it thermally stable at high output.
Yes I saw your post.
I had hoped Barry and you would have kicked it off.
Charging, interesting head
Could it be done in such a way the head Lego’s with the Q8?
Maybe some sort of jumper so we could do this one with the long tube 2S for long runtimes. Adjust jumper and use it with the normal Q8 or short ST tube?
Though a really good diffuser (with inverted shining cone surrounded by frosted white) that screws on the Q8 instead of bezel would make it a lantern but missing the smart design features you made.)
Just thinking out loud here
Those luminous LEDs, only the 140 seems round. 21A is a good match with the Q8 driver though, are they as expensive as the SST were/are?
” Chip on board package assures straightforward system assembly with the best
possible thermal performance for high power devices.”
This is referring to the fact that the LED chip comes attached to the MCPCB board.
It is not a “COB” type LED that has multiple blue LEDs underneath a phosphor layer.
I never hear much from Barry. (i don;t remember who that was. :P) im not sure about the high amp output of the Q8 driver would work with a continuous-running lantern head. The main concept and ability of the lantern design is to have a warmer white output that creates less eye glare, a warmer tone & higher CRI for lantern use, added with substantial long run times even on maximum mode, compactness for storage, ability to run on 1, 2 ,3 or 4 cells, have built in regulated parallel charging (that can charge from a solar panel in off grid locations) etc. If i had a Q8 sample to work with and modify, i could probably start from scratch on a re-worked second lantern prototype based on the Q8 body and its driver with all its modes, but at a reduced current to increase run times.) (and add charging ability)
Below is the current prototype still being battered hard and used & performing as the best LED lantern i ever used, here on a mountaintop expedition we did back in July in a mountain range on the Atlantic coast:
I like to do tests so I will be happy If I can help the future projects with some homework.
The convoy and Q8 thread compatibility is a good idea.
Also a very small light I think would be better with 18350 than 16340 because now we have the Aspire 18350 as a decent high drain cell but I can not name much good 16340.
I can measure lumens, Intensity, temperature, current, voltage. I can solder and put together a driver so you can count on me in if need to do some experiment on future lights :sunglasses:
DBSAR, yes you are right, sorry for again talking about a simple diffuser.
So a Q8 tube compatible head
Driver with less amps then Q8
Single warm led
USB charging.
It seems a driver like the ST needs but with less 7135 chips and charging chip
Of course in your proto the total length is more then needed, since you build on a SRK.
You had an inverted reflector/cone planned for sideways light right?
Powerbank function?
Charge the lantern with a solar panel and at night cherfe phone and or speaker.
Ample space and more versatile.
Maybe cool to do ST and lantern at the same time aiming for early summer for finishing the lantern.
You have a Q8 ordered?
Not a red lighted switch but green acting as beacon.
Definitely add a charging chip to the driver board, maybe a TP4056 chip type (as integrated designed by someone who has that capability) and indeed a USB power output is a possibility too as the lantern runs from four 18650 cells in parallel. (using four 3500mah cells would give it a 14000 mah charging theoretical capacity?) I already thought about adding a separate “glow” led to the switch boot on the prototype, based from the circuit design from the Steam Pipe light glow tube, ( which has been running for the last few years on the same pair of AA batteries) meaning from the lanterns batteries the drain would unmeasurable.
edit: I did order one Q8 , ( but they say its on back order now) but that Q8 is to use as a flashlight. (not going to butcher that one for a lantern prototype.
Added I will be building a “jig” to hold the 30Q cells in this week coming, and wired with #12 guage wire and 20 Amp switch to run the tests on the 30Q cells.
(tests will be scenarios that could happen in a 4-parallel light like the Q8 or SRK, will include:
- one fully depleted cell dropped in the parallel circuit with three other full charged cells
- one full charged cell shunted in the circuit in reverse-polarity against three other full charged cells. (if all cells survive the first test)
other tests open to suggestion if any cells survive.
A bezel swap or plug-in diffuser would change the Q8 into a lantern it seems. Ramping lets you adjust the brightness (and runtime), charging and PB feature could be an add-on ‘ring’ in between the batteries and the head…
Maybe there are efficiency issues i don’t understand though… but it seems a Q8 is a good base. Why build something very similar from scratch again?
