Sorry I missed this one, but I’m subscribed
If you are in a hurry, you could check if the boxless ones are in stock and if the code still works. If so, cancel the backordered cells and then re-order the boxless, however there is no guarantee that they will ship any faster.
In an hour or so I will check which deals are still active and update this thread.
No hurry. My Q8’s are back ordered too, and the GT won’t even in production for a while. Thanks though.
The Lii-500 has had a further price drop. It is now $17.85 if you have points or $19.11 with the code 4BLF
That was a good price for those. I ordered one for myself, finally something within my budget I’ll make sure to update the thread if they go below $1 again.
Only a few hours left on the Liitokala.
Hehe, haven’t seen the Anti Wolf Light in a while. Not as cheap as last time though. $8.99 “flash sale”. I always laugh at the picture of the two women fighting. :person_facepalming:
Found a couple more things that might interest some people.
MantisTek® White Tail USB Doctor Voltage Current Detector Power Tester Flash sale $3.49
UNIT UT658 3-9V 0-3A 0-9999mAh Digital LCD Display USB Tester $3.19
Ordered the UNIT 658 usb tester.Cheers.
HaikeLite MT03 II Devourer XHP70 2SPS 8760LM CW/NW High Power $87.20 with code ef76ef
White HaikeLite MT01 Trekker XHP50 V2 CW/NW 2500LM LED $39.20 with code ef76ef
Black HaikeLite MT01 Trekker XHP50 V2 CW/5000K NW 2500LM LED From $39.20 with code ef76ef
Jetbeam deals
Jetbeam RRT1 SST40 N4 BC 950LM Rapid Response Flashlight $39.00 with code fb954e
Jetbeam RRT2 SST40 N4 BC 950LM Rapid Response Flashlight $45.00 with code f5b7ba
Jetbeam WL-S4-GT XHP70 3300LM LED Flashlight 18650/CR123A $79.00 with code f14c4e
Sorry to those few who ordered at the original price. There is a new code to lower the price.
UNIT UT658 3-9V 0-3A 0-9999mAh Digital LCD Display USB Tester $3.19 $2.55 with code 22878c
4PCS Samsung 30QButton Top $18.69 at Banggood
Geekcreit® 0.28 Inch 2.5V-30V Mini Digital Voltmeter 25% discount
A few things from my wish list plus a random quad with a heap of good reviews that is on flash sale and a SK68 clone that seems like an OK gift for kids at that price. I am tempted by the heat resistant desk pad.
20mm Copper Base PCB Heat Sink For XM-L XML-2 XHP50 XHP70 $2.96 for 3 pieces with code 36BGC8 (Only 26 left for XM-L2 and 16 for XHP70)
Convoy S2+ Sheath Flash Sale $2.45
Smiling Shark SS-8022 Q5 3modes Zoomable Mini LED Flashlight $2.29
Eachine E010 Mini 2.4G 4CH 6 Axis Headless Mode RC Drone Quadcopter RTF $11.99
DANIU 35x25cm Heat Resistant Silicone Pad Desk Mat Heat Insulation type E pad is $5.09 with code DANIU
DANIU 6inch 150mm Electronic Digital Caliper $4.24 with code DANIU or $3.88 for VIP2 or higher. I recommend that people read the reviews before purchasing.
Astrolux TB-01 Bullet Copper/Staineless Steel Flash Sale $3.00 Only 4 copper remaining, plenty of stainless. I wish this was just a little larger and used a 10180 cell, I can’t get past the batteries that it uses.
Ordered a few mcpcbs , thanks
You’re welcome. Fingers crossed they are DTP. (FWIW they are DTP according to a member in another thread)
So…BG has a 3-items volume discount? If I knew I would order a third driver recently.
Anyway, got the DTP boards, thank you.
Digital caliper reviews make em sound like a crapshoot Better to spend a few more $$$ for decent quality ?
I looked at the stars rather than reading the reviews and you are correct. I had a version that looks identical and it was pretty good. It was accurate and repeatable to 0.1mm and made a good backup to my metal one.
I would only recommend this for non-critical measurements, such as if one knows any cell longer than 67mm won’t fit a light and that person wants to measure all their cells rather than testing them in the light.
