That’s a beamshot of the Maxabeam from DM51 over on CPF. It’s one of the nicest beamshots I have ever seen.
Because of the pictures age (~2008) it’s probably a Gen2 Maxabem with 3-6Mcp depending on the used bulb. The current Gen3 Maxabeam does 12Mcp. It also seems like the bulb isn’t positioned perfectly in the reflector (beam and spot are a bit fuzzy).
I would still recommend saving up for a (used) Maxabeam. It’s such a great toy with motorized focus :D. The current models have no Step-Down and all Xenon bulbs have 100cri, so the light quality is much higher compared to LEDs.
Thanks
It’s expensive though, like $500+ usually, which I could put towards my next flashlight project.
On top of that, it is like 1.5x more expensive for me thanks to the canadian dollar xD
Certainly, I will not stop until I have a non-bulb flashlight that can beat all of those short arc lights on that graph
Pretty similar to the design often used for short arc lamps:
Compared to a lens+wavien collar of the same diameter it will have less lux though, since the lens won’t have the dead spot in the middle.
The lens will also give a tighter beam since all of the points on the surface will be at a longer distance from the LED.
