Can the experienced IR guys help out with the above? What is the maximum drive current? I’m planning on using a Nanjg 105c… I’ve read one should not do more than 1.5 amps, but I’ve heard comments of pushing more?
Thanks!
Thanks!
I pushed it harder than 1.5 amps but mine was on a direct thermal path copper board, that sheds heat much better than a Bergquist board. Gmarch made his own ledboard and drove his leds at 3A, but since the led was pulsing there was no continuous heat production. I'm not sure what the current limit is on your board.
Hi djozz. Ok, thanks for your input. I’ve decided to rather go with the noctigon. This will be the first time I use AS Thermal Adhesive - hope it performs ok. Will be looking at +–2.2 amps. Appreciated.
I assume then that you understand that:
1) the solder pads do not fully match, so to get the led flat on the board you have to be sparing with solder paste, use the right amount (squeezing out surplus solder from under the led will not work)
2)the thermal pad is connected to the led+, so with a Noctigon the whole ledboard is not neutral and will have to be electrically isolated from the flashlight body (but I guess that is why you mentioned the ASTh.adhesive)
(btw, as mentioned before: one advice with AS T adhesive: be quick!, before you know it, it is hardened, and then it is glued forever)
Hi djozz. Yes, I’m aware of what you’ve mentioned… Thanks for the tip on the AS adhesive drying quickly. I hope that I get it isolated first time, as you say, will probably not have a second chance! Should it not work out first time, I’ll try to loosen the adhesive with heat, but, lets hope its not necessary. Will give feedback.
Just some feedback on my build
I eventually made use of the Bergquist 20mm MCPCB rather than the Noctigon, for the reason of struggling to get the LED properly reflowed on the MCPCB - it was shorting out, tried a few times and then rather went the Bergquist route, which turned out to work very well for me.
I made use of the brass Convoy C8 pill from Fastech, screwed down with AS5. Driving current was 2.4 amps (measued at the tail). Made use of a Panasonic NCR18650BD, total overkill for the applucation but the highest capacity I had at hand.
Heat was not an issue on the driver at all. If Im not mistaken, this is in contrast with Djozz’s build. Strange. Not sure if the forward voltage on my LED was higher, hard to believe. I unfortunately did not measure this and at the time of writing I was not sure which LED was used by Djozz. My light meter showed quite stable results for around 2 minutes, I did not measure further, this was good enough for me.
I setup the light with 3 modes always starting on high doing around 2,4A on high 1.1 on medium and 0.3 on low.
I gave the light to a friend for testing with he’s ATN Trident Pro4x-2 scope. It did not work well at all. For some reason he tells me the light works best on the low mode? Luckily he also had GEN1 NV Goggles (did not ask the model) which totally blew he’s mind combined with the IR light - worked excellent.
I contacted ANT to hear what there opinion is about why the light does not work as expected with the scope. Unfortunately they are not getting back to me, even after following up twice.
Might it be any of the following. I’d like to hear your opinions if possible:
Im also thinking on getting some opinions on the hunting forums. Which is the best / most active forums to look into for this?
Hope my feedback helps.
I had a heat issue with my led because it was the 1.8V version (the driver had to burn off 2V: times 3A that is 6W). The led you use is 3.6V . (this Oslon has 2 dies next to each other, each 1.8V and there's a version that has them parallel and one in which the dies are in series)
At the time of my build I did not know that there also was a series version which is quite perfect for a common lineair driver, could have saved me the driver heatsink mod, but it was fun making it anyway :-)
The rest of your questions are way beyond my kbowledge..
Ok, that explains the heat issue then. Thanks Djozz…
I run them at 1.4A
any place i can find the old style, non-dtp copper pcbs ?
