1. I have used a Nitecore HC30 (uses 18650) and I don’t find the weight uncomfortable. The tube has very thin walls compared to my other lights, so it’s very light, but I don’t know if all headlights follow this rule. It has the over the head strap, but that can be removed if you like. I have not hiked with it, so I don’t know if only the around the head strap would be enough for that. I don’t have any experience with 14500 headlights, but I’d imagine the lower run times may be an issue.
2. Nichias are more expensive, yes. The current most commonly used model seems to be the 219C, replacement to the previous 219B. So far in this forum the vast majority of flashlights I’ve seem using nichia leds are modded so, not stock
3. I’d go neutral white over cool white for sure, but only you can say how essential having higher CRI and nicer beam are. In my outdoor tests, having the 90+ cri nichia for sure is good to look at, but not essential to the point that other leds look bad
1. Do people find 18650’s too heavy for headlamps? These all seem to have an ugly 3 straps, and I’m wondering if I should go for a 1 × 14500 instead.
Definitely not too heavy.
Those 3 straps are optimal if you plan to be using it during any activity such as jogging, hiking etc, even a lighter headlamp would be prone to slide down on your head otherwise.
I would avoid the 14500 due to it having ~1/4 the energy of 18650 and the obvious limitation of runtime/brightness.
18650, a bit cool, but lightweight enough for me to not object to wearing it too long, and the dual-strap (around’n’over) setup is pretty comfortable. In hot weather or if you’ll be sweating, you might want to put a small layer of cloth between it and your forehead so it won’t feel so “rubbery”.
Takes standard 20mm TIRs, which I already replaced for 60°, and my 90s and 120s came today, so I’ll be trying those as well. You can even keep extra TIRs along with your spare cells if you need flood vs spot or v/v.
And how’s 10bux sound? For dropping a Hamilton, you get a decent light, and can afford to buy 3-4 for your budget.
Downside? Yeah, it’s on the cool side. Definitely not Angry Blue™, but cool. I always wondered about a pale-yellow filter to “warm” it ever so slightly, but never got around to trying that.
People here have torn it down, swapped emitters, but like I said, for the price, it’s “perfect” as-is.
Oh, built-in usb charging, and magic wave-on/wave-off IR sensor.
Me personally, I never liked the (lack of) runtime of AAs/14500s, so I (again, personally) wouldn’t pick one for any extended use.
Oh yeah… advantages of swapping out the TIR lens for a wider angle?
First, being able to see to the sides as well as in front of you.
Second, no nauseating/dizzying jerking back’n’forth of a bouncing spotlight in front of you as you’re jogging along. The nice even beam of a wide-angle TIR lights up everything very evenly.
Skilhunt H03
-With coupon it is under 30$ almost always
-It is almost the lightest 18650 headlamp
-it has nice floody beam
-It is available with nice neurtal tint efficient XM-L2 U4 led
-very good overall quality both the head strap and the flashlight
-usable as EDC light with magnetic tailcap and pocket clip
-it has thermal regulation and programmable modes
I have a Boruit RJ-02 and this H03. The H03 is newer for me and after I got it I never used the boruit again. The Boruit is heavier, the head strap sewing is itching my head. The strap material is much softer on Skilhunt. And the boruit switch become faulty and I need to press hard to work.
Thanks for the reply - I’m strongly leaning towards that one!
Questions:
- It looks like the temperature range is “4000-5000”? Trying to find out which emitter it is since 5k is starting to get pretty blue but 4k is pretty neutral.
Isn’t the XM-L2 pretty old by now? Any reason people aren’t using at least the XP-L’s?
Sorry I edited the post.
The U4 is the newest and most powerful bin of XM-L2.
It has 60 degree TIR lens so it has very good beam. I worked under my car 5 hours and I almost forgot that it is on my head. Tomorrow I can make some beamshots if you want or you can find plenty reviews here on BLF or on youtube if you search.
Sounds really nice, but I’m also thinking about just going really super cheap instead. Hmmmmmmm. Any 18650 headlamps under like $15-20 that are good other than that RJ02?
I can not name one. A few days ago the Imalent HR20 was on sale at banggood with coupon for 26,5$ included battery and with Micro USB charging.
There is a gap between Boruit RJ-02 and H03 and HR20.
When I bought the RJ02 I was happy.
When I bought H03 I thought I spent too much for a headlight…
But after the first use…It worth every penny and the boruit collecting dust since.
The H03 has more thinner wall of tube and a bit less material in the head so it is lighter.
And I think the UI is better. The H02 has 4 modes fixed. But the H03 has 4 modes with selectable lower or higher submode and the light memorizing what you selected. For egzample I use it in low2, med2, High1, and turbo2. 2 is higher output than 1. you can switch between 1-2 with double click.
Definitely an XP footprint, but dunno if it’s even a real XP-G. Probably some generic Mystery Emitter. I’d love to swap it out for an XP-G2 or so, whatever’s the lowest Vf of the XP series, just to keep it in regulation as long as possible.
It’s not that “cool”, let alone “cold”, so don’t be scared off by that. I was out chiselling out a coupla feet of frozen snow that drifted up against a door (snowed, melted, refroze) for quite a while this past winter, and even reflecting off white snow, I didn’t mind it at all.
Gotta confess, with the price being what it is (and having like 4 spares), I kinda beat the Hell out of this critter, and other than losing the tethered rubber plug over the usb port (no idea how…), it’s held up admirably.
Hey, anyone know/recall offhand if 219BTs have the same solder-pad pattern as XP-Gs? I’d love to go high-CRI in at least one of these puppies.
Doesn’t seem to be available on gearbest right now, though =/
Downsides seem to be no firefly mode (0.5) or lower powered medium mode in the 20-70 range. Not sure if either can ramp up infinitely between their modes.
H02 is taller and heavier than the H03.
But they have the same TIR or reflector.
H03 can preset all 4 modes in 2 levels with double click (low 1 / low 2 - medium 1 / medium 2 - high 1 / high 2 - turbo 1 / turbo 2).
If you’re a long distance hiker, then yes, 18650 is too heavy. I have a Zebralight H52 to cut down some of that weight and bulk, but unfortunately for you, I don’t think there’s a Nichia option. Since I’m out there to hike, I’m awake for very little time when it’s dark, so I can easily get 500 miles from a battery, so it’s safe to use a lithium primary AA, which saves even more weight. The H52 really is overkill for me, but I really like the ability to get a spare AA while restocking my food bag in town. The beam pattern is great for hiking too. Just the right amount of flood and throw to light up the trail, but still enough throw to find campsites if I waited to long to get off the trail.
