Doesn’t seem to be available on gearbest right now, though =/
Downsides seem to be no firefly mode (0.5) or lower powered medium mode in the 20-70 range. Not sure if either can ramp up infinitely between their modes.
H02 is taller and heavier than the H03.
But they have the same TIR or reflector.
H03 can preset all 4 modes in 2 levels with double click (low 1 / low 2 - medium 1 / medium 2 - high 1 / high 2 - turbo 1 / turbo 2).
If you’re a long distance hiker, then yes, 18650 is too heavy. I have a Zebralight H52 to cut down some of that weight and bulk, but unfortunately for you, I don’t think there’s a Nichia option. Since I’m out there to hike, I’m awake for very little time when it’s dark, so I can easily get 500 miles from a battery, so it’s safe to use a lithium primary AA, which saves even more weight. The H52 really is overkill for me, but I really like the ability to get a spare AA while restocking my food bag in town. The beam pattern is great for hiking too. Just the right amount of flood and throw to light up the trail, but still enough throw to find campsites if I waited to long to get off the trail.
For outdoor use, high CRI is what matters more than anything else, if you want to be able to see details.
The Nitecore NU20 CRI is a very nice lightweight headlamp.
I swapped out the default TIR from my RJ02 to a 60°. Very nice.
Tried a 90 and 120 which I got yesterday, but didn’t like the beams. Too much of a “bullseye”, rather bright ring around the periphery, then slightly darker towards the middle, then pretty much the same hotspot as my 60. It’s annoying even in practice, not just white-wall hunting.
Sticking with the 60, as it’s nice and smooth. If I need a little more throw, I got the come-with TIR just in case.
The Imalent HR20 is a nice package, but it has a normal beam, not a wide one, what more people prefer on a headlamp.
All comparisons I’ve read favour the H03 for headlamp and normal use.
Consider what you’re going to be using the headlamp for, before deciding on the battery type. An 18650 light really only makes sense if you need really long run time, or very high output + decent run time. Also, you don’t want to be bouncing around too much with the bulk and weight of an 18650 light on your head. Otherwise, a AA/14500 light makes more sense.
A 1xAA or 14500 light will give you about 8 hours at 50 lumens output, which is probably what you’ll be using most of the time. If you want to use it at 200 lumens, that just means you need to change the battery every couple of hours. If you need higher output than that on a constant basis, then you probably want an 18650 light.
I am considering this. It might be nicer to have a lighter weight headlamp, and just carry a spare 14500 battery in my backpack.
I’ve read some mixed reviews - for camping/hiking, would you say most people end up using ~ 20 lumens (low mode) or ~ 50-70 lumens (medium mode)?
That will help me get a better estimate of the runtime I’d get from each battery.
Can anyone help me fill out this chart for most batteries?
Average Runtime
Low (~20 lumens)
Medium (~50-70 lumens)
186500
75hrs@20
25hrs@70
14500
x
3hrs@50 (acebeam)
Anyone have a good sense of how long I’d typically get on a 14500 in medium (50-70 lumens)? The 3hrs on that acebeam seems really short, but found another thorfire that seems to show similar. Makes me lean towards an 18650.
I’m not seeing anything that does 8 hours @ 50 lumens like you described.
You really should pick up a Skilhunt H03.
It is a wonderful light, and I find it more comfortable than many of the smaller headlights that I had before becoming an BLF geek. It really does not seem heavy or bulky to me at all.
Do you want to have the ability to really light things up and see everything clearly, or do you just want to have enough light to make sure you don’t trip over a sleeping Black Bear? As far as lighting up stuff in your immediate field of vision goes the H03 is a game changer. However, if you are content with stumbling around on 50 lumens then its probably overkill.
Personally I would rather have the ability to really light things up when need be, it makes working on things like setting up a tent, cooking, or taking out the garbage much less of a struggle. If all you are doing is walking down a trail for 10 miles maybe you want a tiny headlamp like a nitecore NU10. if you want to work around the campsite the H03 is a no brainer.
If you need to see longer distances, then there are other versions of the H03 that are less floody, or you could go with the Nitecore HC30 / Imalent HR20
I have both and use the H03 for different reasons.
Runtime is 3x, for only 5mm longer. Compact and lightweight for 18650, warm white, good user interface, moon, if I want brighter.
On a reasonably efficient light, you should get about 100-150 lumens/watt out of your flashlight, using a modern Cree LED, and depending on the drain (middle modes are usually most efficient).
A 18650 has about 12 watt hours of energy.
An Eneloop Pro NiMH AA has about 3 watt hours of energy.
A good 14500 also has about 3 watt hours of energy.
So, you can figure out the approximate run time by using the formula:
run time in hours = capacity * efficiency / output
For example, a 14500 light with an efficiency of 125 lumens/watt, and an output of 50 lumens, has a run time of
3 * 125 / 50 = 7.5 hours
So, that acebeam doesn’t seem very good, if you really only are getting 3 hours at 50 lumens.
Generally, I use 50 lumens for walking in the dark, if I only want to light up my immediate path. An occasional blast of high output to see further, if I need to. Though I normally use a thrower for seeing further. I can go down to about 10 lumens, if I want to preserve more night vision. But below 10 lumens, I can’t see the ground very well, even right in front of me.
I own a Skilhunt H03, and love it, but was just looking up information on the Imalent HR20 which I saw was available recently for less than $20 with coupon available on BLF. I just checked and that code has expired, unfortunately, but a current code from M4DM4X will get the HR20 for $26.99, so it’s competitively priced to the H03.
The HR20 has built-in USB charging, ramping control of output via a rotary knob, AND comes with a battery - all for under $30. And if weight is a concern, the HR20 is just 2-3 grams heavier than the H03 at 46 or 47 grams w/o battery.
I may need to order one myself!
here’s a BLF review of the HR20, in case you want to give it a look:
Lexel I saw that H03 shorty and I has a short S41 tube home so I immediately done this to mine
It is so cute!
Did you shorten the tube? On my the O-rings doesn’t seal this way but the light works.
