Has anybody recently bought the Keepower batteries mentioned in the OP? Are they still the correct type (the older model)?
I would like to purchase one of these light soon. Can the extension tube be bought in raw form? If not, I may just order all black so it matches.
Also, I would like to use the H6Flex driver, but I’m not sure if I can make it fit. Are there any other drivers that can handle 11v input or 3 LifePO4 batteries?
Its a shame this lights only drawback for me are the damn batteries which needs to be very good from what i understand? sure i can buy the light but looking at some decent batteries 2 of those will more or less cost as much as the l6 light alone as shipping lithion batties is big problem today, that for me is a big no thanks which is a shame would like a big nasty thrower like this but since it needs beefy 26650 batteries to powerup i will have to wait before buying i guess…
TWN, this is the Zener modified FET variant to enable the 17mm FET driver to work with 2 cells.
https://www.dropbox.com/s/btgr9mmd5uo24eu/AVRGCC93.c?dl=0
https://www.dropbox.com/s/8exj0nyctu28ui0/AVRGCC93.hex?dl=0
https://www.dropbox.com/s/u920tz0a1rrwhyn/flashAVRGCC93.bat?dl=0
If I remember correctly, the e-switch has wires to ground and leg #3 of the MCU. It’s a 64 level ramping, click and hold (short hold) for moon from off, double click (not quickly) for turbo from off. Last mode memory is engaged. Reverses when the switch is pressed and held within 2 seconds. Single click when on turns it off.
Texas_Avenger drivers work well in there too. 3-channel with LDO so slightly more efficient than a Zener-FET. Flash with NarsilM and ramp away Its been a bit since I built mine but I’m almost certain the 30mm driver is a drop-in replacement for stock. Either are fine choices though.
Pay attention to the version of the Texas Avenger driver, they’re not all LDO equipped. Have had em both ways.
Silly though, to think of having a flashlight that can pull 12A from the 5,000mAh cells and then worry about efficiency. Smaller lights work well when you don’t need much light, big lights, being not as easy to tote around, typically aren’t used for small jobs where duration of the weak light is a virtue. Just sayin… Obviously the large light CAN do the work of smaller lights, just not really where it’s design parameters lay.
As an update, I just found out that Richard at MTN Electronics is now offering the ramping software used on the D4 light as an option on his 30mm 2S fet driver for the L6. Other drivers as well, I think.
It’s not quite Narsil, but pretty close. It’s also 2 channel (fet+1) as compared to the 3 channel (fet+8+1) Texas Avenger that Lexel is building. It’s competition for Lexel, but I don’t think Lexel will make drivers forever. When he stops there will be an alternative.
And Richard can build them hundreds at a time…
I was just putting it out there as an option. Nothing wrong with a Zener+FET. I’ve got them too, in lots of lights. TA’s drivers are great too though…
The Zener modified FET driver is fine as long as you have it in a light with a mechanical clicky for power cut-off. On an e-switch light, the drain is rather high. With the L6 having both a tail mechanical switch and an e-switch, cutting power is easy and makes it safe to store with charged cells.
I personally have found TA’s driver’s to be rather intricate and difficult to build with a high rate of success. That’s just me though… I do use one of his in my Ti/Cu Quad EDC that I built from scratch. They’re doable, just harder than the typical 17mm FET.
It has probably been discussed many times in the topic, but are there any recommendations on protected 26650s? I have an L6vn from Vinh, so it has a power boost. I don’t want unprotected 26650s, but ones with the best (least) voltage sag to them. I’m looking moreso for objective data than subjective recommendations.
Are there any comparisons of protected 26650s and voltage sag charts?
Almost all protected cells are going to have higher internal resistance. This means less output on all levels.
I think Vinh uses a fet driver, right?
So with my fet driver and xhp70, I haven’t compared cells with the 70.2, I measured amp draw with blue Liitokala 5000 mah and protected KeepPower 5200 mah cells.
The KeepPowers did 9.6 amp.
The Liitokalas did 12.6 amp.
Now keep in mind that your light has the 70.2.
With Liitokalas you might get 17 to 18 amps. The KeepPowers are only rated to 10 amps. So they will probably cause the protection circuit to trip on turbo shutting the light off.
The second problem with protected cells is the length. 70mm cells fully compress both springs so if you have bypasses your probably not going to get them to fit. You’ll need to unscrew the battery tube from the head a few turns to get extra length. The problem with that is you might feel the slop between the 2 parts as you handle the light.
I think your going to be forced to use unprotected cells. I don’t know of any protected cell that can handle that amp load.
I’m sure Vinh only recommends unprotected cells with his L6vn. Maybe ask him if he’s ever found a protected cell that works with his light?
No, he actually recommends protected cells with the L6. I’m not sure if his driver is 100% fet. He pushes a high output bit 70.2 to 6500 lumens, and I know you guys have pushed the 70.2 to upwards of 9000 lumens.
I’d check with him about which protected cell to use. I’ve only had the KeepPowers which as supposed to be a top performer.
I see an Orbtronic rated at 15 amps.
He uses Acebeam protected cells for his lights, but I was wondering if there were any other protected 26650s with less voltage sag than those.
My L6 with 70.2 is doing some 9500 lumens with flat top non-protected LiitoKala cells. No sure why the issue of protected always comes up, the chemistry of today’s high discharge Li-ion’s is much safer than it used to be and as such, negates the need for the protection circuits in all but the newest of rookie hands.
WORD!
I just ordered one from Vinh.
I got the Orbtronic 26650
26650 battery Li-ion PROTECTED 3.7V by Orbtronic.
Real 5200mAh that will hold its rated capacity even under high current discharge load.
Free protective case included with each pair of 26650 batteries purchased.
Battery Specs:
Cell Capacity: 5200mAh
Cell Type: 26650
Dimensions: 26.5 mm x 68.8 mm (+/- 0.05mm)
Full charge: 4.2V
Recommended charging current: 2A – 3A CC/CV (Battery can be charged with current lower than 2A, but charging time will take much longer)
Nominal voltage: 3.7V
Cut-off: 2.5V
Max. Constant Current Discharge 15A (Protection circuit – cut off at 15A)
Weight: 97 g
Chemistry: Li-ion / Hybrid IMR
Positive terminal: Wide Button Top
Electronic External Protection: YES – full protection (overcharge, overdischarge, overcurrent (cutoff @ 15 Amp), short circuit)
For most applications, that Orbtronic sounds pretty good. My L6 is pulling 19.38A at the tail from a pair of Efest 20700 cells (the LiitoKala cells are a bit less, around 17A as I recall), reckon those Orbtronic cells wouldn’t run it.
