Pre production sample [Review] Astrolux MF-01 4x18650 flashlight supplied by Banggood
It seems like the lights weren’t tested before shipping. Not looking good.
Let’s see how Banggood responds.
I’ll take one NarsilM driver for the MF01 as well.
Ahh, ok - Thanx! I'll get an order in. My MF01 is still in transit. I'll check it out carefully when it arrives, post some stock #'s.
Finland? Oh boy. Maybe Lexel is gonna build a couple?
I’ll figure out myself as well. I’ve got two of those coming my way. Interestingly, it still doesn’t feel like a bad purchase; the price is just too good to take the risk, unlike with an Imalent DT70.
He uses Meco protected battery
You can see clearly when powering directly to turbo protection kicks in as well when shut off
This is a poor battery fault not the light itself
This makes sense. And that’s certainly good news for the MF01. Also kudos to Meco, because their protection is working well.
Nice find.
Why do people think they can install 4,000 mah protected cells in a 12k lumen light? That is false mah rating for sure on those cheap cells.
High current lights need high current cells. Good ones.
Meco are crappy batteries too bad HKJ has not tested them
But 4000mAh on the label says all you need to know
Unless you hang here on BLF (or CPF) it is not that easy to know.
Ironically, four pieces of 5000 mAh Ultrafire cells seem to be able to power a 20000 lumen Ultrafire Skyray King clone, so 12000 lumens should be no problem…. :stuck_out_tongue:
Aren’t you over reacting a bit? Lol
Still think the same?
Luckily it was not a faulty MF01. Phew…
I Just received the Nichia from the last sale. Seems like a great light with good weight too it. All the LEDs are working well. Although I can’t see anymore from looking side on at the light on turbo during the middle of the day. I am using button top 30qs, they went in fairly easy.
Here is a solution for those wanting access to low mode to reserve the night vision.
Always put on low mode before you switch off the light. This mode will memorised on low and when you need turbo, you can access by double clicks.
Not the best method but im happy with it for now. :stuck_out_tongue: . I suspect they will amend the driver to have low mode direct access.
Or you can unscrew the tailcap half turn to cut power, then screw on to power again. Light indicates when power is cut off for convenience. Light will turn on in low mode as well. Also not really elegant… but this works as well.
your method is even better :smiley:
Hello, I have recieved both versions, but in XP-G2 there is a big space between the lens and the besel - it easily accepts envelope end. In Nichia version I was able to insert “only” A4 sheet. Now this makes me wonder 2 things:
1. Is waterproofness really there
2. If I try to screw the besel is there a chance to damage the LEDs?
Any thoughts?
if you shake the light the lens should not moove
the o-ring is on the edge so to stick in there a bit is normal
if the lens moves you can sand down the bezels back a bit,
I had to do this on the prototype, but it should be fixed in the production lights
The TIR lense is seperate from the glass lens, so you should be okay with turning the bezel to tighten or loosen it. Still, it might be best to push down on the glass lens as you turn the bezel to make sure it does not turn and rip the domes off the leds.
Basic question, how do you use 7135s on a 2S (8.4V) light ?
Or do they just work well beyond ratings ?
