So it is not really a problem of the firmware but of the driver?
If the driver has no bleeder resistor the lightened tailcap may work or not (and the firmware/UI may work or not)?
It is a combination of driver and firmware. The stock driver with old 3/5 mode firmware work without a bleeder resistor with lighted tailcap.
The stock driver with Biscotti and lighted tailcap will turn in to next mode memory.
Driver with Biscotti and lighted tailcap only work correct with bleeder resistor on driver.
Biscotti relies on being able to measure time while the power is off, and the lighted tailcap means power is never âoffâ enough for that. So it breaks unless you add a bleeder resistor to bypass the driver while âoffâ.
The stock 3/5 mode firmware only measures time while on, so it doesnât care about the lighted tailcap. However, this also limits what the UI can do, because it canât tell the difference between a short press and a long press.
I took the lit PCB/switch from the tailcap and put it into one of my other S2+ which still has the old 3/5 firmware and a clear rubber boot - I love it! It is a really nice feature.
On the clear S2+ with the push button tailcap switch the glow was hardly noticeable.
I would really love to install a lit PCB/switch into my Convoy C8 - does anyone sell the PCB/switch separately? (I mean with the SMT resistor and LED and switch/spring already installed on the PCB)
Yes it looks very much like that one, however the one I got from Convoy doesnât have the interesting looking double spring setup, but it does have the same blue colour LED.
If I have some time I will take a photo of the PCB i got and post it up.
Is this likely to be a clone/fake? I did not see any clear S2+ in Simonâs store and did not know that the rubber switch version was officially released by him?
Simon does have a rubber tailcap version of the clear S2+ (I have one), but you have to ask him for it. I asked him as I remembered seeing a picture of one (possibly in this thread) and he said OK. Iâm not sure if he has the clear S2+ tailcaps with rubber boots in stock or theyâre are just left overs from the prototype fase, or he just throws an S2+ tailcap in the clear anodizing line (I have no idea how his chain of production works)
PS: I believe ordering from his Aliexpress store will be cheaper
Iâve never seen that before but it certainly looks legit. If thatâs a fake they did a disturbingly good job. I just sent an email to Simon asking about this. Itâs something we discussed long ago but I didnât hear anything about this being produced. Iâll let you know as soon as I find out whatâs going on. Thanks for the heads up.
20mm wonât work, the threaded hole for the metal switch is only around 10mm in diameter or so (The metal tailcap switch assembly screws into the tail cap)
If Simon says he is out of stock you could also go with the ebay rubber tailcap clear S2+ I linked above.
Shows you how out of touch I am these days. :person_facepalming: I didnât even know that. LOL Thanks for posting the link. Iâll try to remember to add it to the OP of the clear S2+ later.
