Test/review of Delipow 9V LiIon 800mAh (Yellow-green)
Official specifications:
  • Battery Type: Li-ion Battery
  • Rated Capacity: 800mAh(0.2C discharge)
  • Rated Voltage: 8.4V
  • Discharge cut-off voltage: 7V
  • Charging Voltage (standard): 9V
  • Discharge current (standard): 50mA
A cheap LiIon 9V battery from China
Overcharge protection on the A cell kicks in at 8,46 volt and over discharge protection at 5,53V
Overcharge protection on the B cell kicks in at 8,46 volt and over discharge protection at 5,56V
It do not have the rated 800mAh, but the discharge curves looks good for a 590mAh battery.
Conclusion
The capacity rating is too high, but it looks like a acceptable LiIon 9V battery.
Notes and links
Compare to other 9V batteries: Alkaline/NiMH/Lithium/other
It looks like there is no overdischarge protection?
Sorry I forgot to add that, it is included now.
I will expect it to be below 6V and it is.
But what do we know about the protection circuit? Has anyone seen good data on these protection circuits tested or examined for quality?
8.4 volts (when freshly charged), and around 7.5 volts over most of the run time, just won’t cut it for a lot of devices that require 9 volt batteries. I have smoke detectors that start sounding the low battery warning at around 7.6v. I use NiMH 9v batteries in them, but they use 7 internal cells for a total of 9.6v.
This battery would start sounding the warning way too soon. Though, the greater capacity might still give it a decent run-time.
BTW, how do you charge it? It must come with a special charger?
Battery seems equipped with a proper management system. Undervoltage protection is likely set at 2.75V/cell (battery cut offs: 5.53 and 5.56V). Cell balancing may be absent, of course.
There are some specific chargers for this sort of stuff, WalkIntoTheLight, Soshine has some for example. Peek here: “soshine 9V charger” search at FastTech
It can also be done with a generic CC/CV power supply, just set maximum voltage and current to the desired values. HKJ used 8.4V and 0.2A for the above-mentioned charging graph.
