Nice start Don. Love the vice with its custom built soft jaws.
:+1:
It got smoother & shinier overnight.
Now, whereās the rest of this light?
Looking good already! :sunglasses: :+1:
I completed the first stage of my wall of bookshelving and have a couple afternoons free before getting back to that home project, so I got back to this light project today.
Here is that first part I made and the section of wood I will cut the next part from.
Iāll be using about 6 inches of this if I only have to cut once. This piece has slowly been getting smaller since I bought it about 25 years ago. Then it was about as long as I am tall, a few inches under 6 feet.
Iāll be making a hole with this drill. 3.25ā (about 8.25 cm)
The clamp makes a decent safe handle
LOTS and lots of shavings!
Drilling takes a while as I stop and let the bit cool every half inch or so. Canāt use a water or lubricant bath as with metal. Pity. The bit needs a sharpening as it is also making a lot of dust as well as shavings.
For the curiousā¦ this is the base board I used under the padauk block to prevent tearout as well as to keep the bit from hitting the cast iron drill press platformā¦ The drill cuts shavings between 0.4 to 0.5 mm thick.
Thatās all for now. Thanks for looking.
Curious to learn and see where it will go Good work :+1:
If you ground/sanded a taper toward the shank on that hole saw boring bit you have there (Iād like to know what itās actually called) you will get rid of most of the heat issues. HSS really doesnāt like heat, for wood you could try wax as a lubricant. Also peck drill and high rpm.
Thatās some drill bit! And a nice chunk of wood :+1:
The drill bit is a Forstner bit, invented about 150 years ago by a Benjamin Forstner. Usually they do not have a toothed rim like this one, just a circular rim. They are meant to cut/drill a flat bottomed hole. The flat bottom holes have a slight dimple in the center where the centering spur protrudes slightly. This one was specifically sold as a clock making bitā¦ drilling a recess in a wood blank for a small battery powered analog clock movement. With a drill press you can drill overlapping holes, even drill at an angle if the work piece is clamped down to the table.
What CRX said. The block of wood is a lot bigger than it looks in the first picture on my phone.
nice start .keen to see the result
Progress measured in small incrementsā¦
I needed some more holes, soā¦
My under 2 inch forstner bits
Two holes done and my newly arrived Q8
3/4 of the bookshelves project done. 1/4 to go as a corner cabinet to the left. Then Iāll be free to do the waiting flashlight stuff unimpeded till the next (inevitable) project.
Wow wow, wood is so last year just kidding, Iām looking forwards to seeing the built!
Are you filling the bookcases full of flashlights?
If it was my own, probably. But Iām building them for our sonās place. FYI, they will end up with sliding Japanese Shoji doors. They look a little like a window with a lattice framework. Instead of transparent glass traditionally they use translucent paper. We will be using a laminated paper for greater longevity. LED strip lighting will be run behind the lip of each shelf. They will be dimmable.
There will be real books. Who knows what else? Maybe a Q8 if I can bring myself to give one of mine away. :person_facepalming:
Back to this years contest entryā¦.
More holes neededā¦
After drilling those three holes I sliced off a slab with the table saw. Then drilled out the holes in the block and pressed some aluminum threaded inserts into place.
Another view of the block and plate. When completed the plate will be mounted back onto the block face.
I need a round copper disc, 3/4 inch in diameter for a cell contact. Using aviation snips I cut one from a scrap of 0.020ā copper. This is the rough blank.
A file was used to remove the excess and round it off
That is a piece of 3/4ā walnut dowel used to check roundness and size. Looks okay to me.
More later.
Holes and groovesā¦
Using a very long 1/4ā bradpoint bit
The drill tore out at the bottom a little, but that is going to be hidden from view, so it never really happened
I need some grooves to run wires in. Never tried this before so here goesā¦
As well as the Dremel cutting wheel I used a Dremel cutting burr and a small Dremel drum sander.
More to come another day.
Very nice Don. Do you glue the threaded aluminium in or just press fit it? Iām learning lots about different drill bits as well. :+1:
It is a tight slip fit. I use a bench vice to slowly squeeze them into place. I did not use any glue on these as I donāt think Iāll ever torque the screws heavily enough to worry. When I feel the need to lock them more securely I use a triangular file and file a small groove down the length of the aluminum insert. Then when it is in place a drive a small brad, or finishing nail into that groove. It locks very well.
I used to have some special cyanoacrylate glue that was made to allow making a slip fit. Made by StarLoc, Wet one side like the wood hole, drive in the insert and in about 5 minutes it would set. I still have the empty bottle, but have not found anything like it. Havenāt looked hard though. I bought it from a UK seller a couple years ago.
Good to see some more progress, Don :+1:
Iām back in Aus after spending the last week or so in the US on vacation, & have a lot of catching up to do; both reading BLF, & working on my DIY buildā¦.
ā¦that reminds me, MRsDNF wanted some Drag Week picsā¦.
