Jerommel
(Jerommel)
September 13, 2017, 9:54pm
7
O, wait, if forgot to mention one important thing:
Centring gaskets !
They need to be 0.6 to 0.7mm thick and fit the 7mm hole of the reflector.
I have one of them left i my parts box, i used the other one already.
But it’s the last one i have of that type, so i’d rather keep it myself…
I did recently order some of these though:
https://www.fasttech.com/p/4512104
But i don’t know how thick they are (they’re not in yet, haven’t even been shipped yet).
Maybe as an alternative idea to increase throw you could try these:
https://www.aliexpress.com/item/CREE-XML-LED-Lens-Diameter-17mm-60-degrees-Smooth-surface-5050-lenses-XLamp-XM-L-T6/2043525162.html
Smooth surface, the 20° version (unfortunately no 10 or 15° version available).
Same form factor as the Skilhunt TIR, easy swap.
LightRider
(LightRider)
September 14, 2017, 2:02pm
8
Thanks for the tir link! I may try one or two of those?
PM sent to discuss the reflectors.
Lexel
(Lexel)
September 14, 2017, 2:41pm
9
the lens from Jetbeam Jet-1 MK fits perfectly in the H03
the 14mm lens from kaidomain is a bit thicker but should fit as well
LightRider
(LightRider)
September 14, 2017, 2:44pm
10
The lens or the reflector? I was thinking the lens is greater than 14mm. No? I’ll measure it when I get a chance
Lexel
(Lexel)
September 14, 2017, 3:04pm
11
err 17mm lens, the reflector inner diameter was 14mm
the Jetbeam reflector is deeper
this one should fit
http://www.kaidomain.com/p/S023866.16_9mm-x-1_0mm-Double-Multilayer-Coated-Water-White-Glass
Jerommel
(Jerommel)
September 14, 2017, 4:22pm
12
Jerommel
(Jerommel)
September 14, 2017, 4:30pm
13
A thicker lens will probably prevent the bezel from screwing down to the head all the way.
I would suggest to search for a lens with the exact same thickness as the Skilhunt lens.
Lexel
(Lexel)
September 14, 2017, 7:57pm
14
the 16.9x1mm fits perfectly, I remembered it thicker
LightRider
(LightRider)
September 15, 2017, 2:57pm
15
Jerommel, are you still willing to sell me the reflectors or I can send you the tirs they replace?
giorgoskok
(giorgoskok)
September 16, 2017, 3:39pm
16
I would be interested in the reflector’s diameter & height so i can buy one .
Thanks
Jerommel
(Jerommel)
September 16, 2017, 3:41pm
17
Yes, we’re gonna do an exchange (see PM).
Jerommel
(Jerommel)
September 16, 2017, 6:11pm
18
It’s 15mm diameter and 17.3mm 7.3mm high.
giorgoskok
(giorgoskok)
September 16, 2017, 5:43pm
19
Thanks ! It’ll be tough finding one .
Jerommel
(Jerommel)
September 16, 2017, 6:10pm
20
MISTAKE!
it’s 7.3mm high.
Sorry…
treoneo
(treoneo)
September 17, 2017, 7:34am
21
I thought the same. I want the H03R but take too long to get here. I can get an H03 on Amazon in two days.
Where can I purchase the reflector and lens that will fit from? Prefer USA.
finges
(finges)
September 17, 2017, 8:55am
22
Jerommel
(Jerommel)
September 17, 2017, 2:14pm
23
Brands should sell spare parts i.m.o.
In this case, a headlamp reflector set = gasket, reflector, lens.
For TIR replacements they can simply refer to Yajiamei on AliExpress.
Pavlo
(Pavlo)
October 27, 2017, 8:35pm
24
Hi guys,
I have emailed Skilhunt twice about TIR and Reflector parts and never got a reply.
Has anybody had any luck finding a 3rd party reflector that fits and works?
Thank you!
LightRider
(LightRider)
October 28, 2017, 7:58pm
26
I ordered one to try. It’s been delivered but I can’t find it. If I do I’ll let you know…
