I am still very interested in this project.
Banggood Sitemap - Wholesale Sitemap - China wholesale
China wholesale Sitemap, dropshIP wholesale from China, Professional Chinese wholesaler for general merchandise on wholesale price.
Email send to Barry and DBSAR
1 to point Barry to this thread and urge Thorfire to make this high quality lantern
2 to provide DBSAR with the Q8 CAD files so he can do the design, show Thorfire and us what is the plan with some pictures.
I could have worded it better, what I meant was the ability to set a timer so that it maintains current light output, then at the end of the timer goes to either off, or moonlight, whichever was selected.
This is something ideal for camping, so you can read in a sleeping bag until too sleepy to want to get up to turn off the light, which will wake you (and others with a noisy zipper) up anyway, and have the light turn off by itself, or revert to a night-light function if you do not want complete darkness.
Wait didn’t TK do things with timers?
Gonna point her to this post.
DBSAR, driver software needed things?
e switch
moon yes no
low 5, med 40, high 100% (or ramp?)
memory yes no
reverse by long click yes no
voltage readout
timer setting 1 light on, dimming after X time
timer setting 2 light off, slowly turn on after X time
sideswitch, beacon or off
this lantern seems very nice, subscribing so I can buy it in the future. Thanks for all the hard work.
Glad this thread is getting some action again. I’m definitely still interested in this and would also prefer a finished, dedicated lantern instead of an accessory for my Q8.
I didn’t know this thread existed. I’m a bit behind on the specs and goals… but it’s a lantern head for the Q8 body? Screw-on bezel attachment for a lantern-style diffuser? The driver is a Q8 driver, with FET+1 and e-switch and tiny85? Whole new light?
I’ve been using a “good night” mode on my lights for years, and was recently pondering adding an alarm clock mode. I doubt it would be a stretch to make something designed for lantern-style use.
The upside of a big MCU like the tiny85 is it has plenty of space for cool features. The downside is that it draws more power, so moon mode won’t last as long. Unless I can find a way to reduce operating power, but I don’t expect to find huge improvements there.
If it’s using an e-switch and Q8 driver, I could make firmware for it pretty quickly. If it’s new hardware it’ll take longer.
New light
I THINK best if it is sharing tube, tail and switch of the Q8.
Same bottom side of Q8 head, so same switch and tripod mount location but above that all new head.
And a new driver so a lower power using MCU is preferred for it is not a lumen monster at all. Runtime rules. I think DBSAR aims for 500 lumens, maybe even less from a single led.
But it is his project so he can say it much better
If it shares tube, tail and switch it’s still possible to have connections for charging etc. on the (under)side of the head, so definately sounds interesting.
Would also make it cheaper and easier for getting Thorfire interested in producing it.
My best paint skills :
For some reason I kind of expect DBSAR to do the connectors on the same flat as the tripod mount, so a rubber flap can be securely bolted to the tripod mount.
But of course it is up to him, he has the CAD files to go wild
LOL, is this the same “The_Miller” as before? I think I read probably 20 of your posts before realizing the new avatar and username were you.
username is still the same
I really liked the avatar with J-Dub74 Q8 beamshot, but it looked not distinctive enough so wanted to change it anyways
I think a nice idea would be to have a second tailcap, that way USB ports and coiled up charging cables can be secured in an already waterproof area. Drawback Is of course tailstand, unless the lantern has tuck-away legs. Diagram looks a bit unstable without legs anyway.
What?! No…
It used to be “The_Miller”… right?
Now it is “The Miller”
Or am I crazy?
edit: I am crazy.
I just used the wayback machine to look at an old cached version and it was “The Miller”. Why in the world did I think it was The_Miller?
I think for a lantern/camp light, water resistance/proof is more important that a typical EDC. I wouldn’t mind seeing connectors protected by something more robust than the typical loose friction fit flap.
edit: I just re-read your post - were you suggesting somehow using the tripod mount as a positive engagement point for securing the connector cover? I like that
Is having the charging port in the tail causing an electronic design problem? (like the need for an extra electrical connection from driver to tail?)
Some bright ideas Zulumoose! And I can understand the tripod mount being more handy on the underside, and thinking of that, if the tailcap is made a bit longer it can both house the tripod hole in the middle and on the inside space around the tripod-hole-pillar for a charging cable. (or a chunky ring magnet ) The silvered shade sounds useful too.
Yes, hold down a rubber thing to protect the port from water and dust using the tripod mouting hole that is there, maybe even using one of these so it can still be attached to a tripod while the protective rubber is in place:
Djoz, I think keeping the electronics on driver board makes a lot of sense, being a lantern tail standing is natural position
And there is space on the driver boards.
Use it with 3 cells and cables can go in the area for fourth cell
ideas for other features:
- waterproof slot for matches, usb cables etc
- 12v input
- Timer to off or moonlight mode
- threaded base for tripod mount
- flap or curtain for creating a shadow side, ideally reflective for more output to the other side
My thougts for this are:
1. would make the lantern bigger, but maybe there’s a nice compromise (also weatherproof will be more realistic and less expensive than waterproof)
2. if USB input supports QC 2.0, 12V would be possible with standard gear (regular USB Type-C or 3.0 cable and USB QC powerbank or power supply)
3. nice idea, also for childs
4. like with the Fenix CL20R, magnetic tripod mount would be perfect :)
5. this should be optional, to make it cheaper for people don’t needing it. Clever would be an electronic solution with controlling half of the horizontal LEDs separately (like the Cateye Rapid X3)
ok Miller sent me some info on the Q8 design. I will work on a basic specification description of a combination of my current prototype above using the Q8 battery tube/base possibly, (with drawings) and explanation on how the lantern could be used with the extra mentioned ideas mentioned. The Q8 driver may be a bit to much for a lantern, ( the higher modes would cause severe overheating very quickly and short run times on the higher modes) as for lanterns continuous run times are among the most important. Right now the prototype pulls roughly 700-mA on high, (from a modified 2-7135 Q-Lite driver) and keeps the XP-L U5-5A3 emitter right in its most efficient maximum lumens-vs-amp-draw range, and will give a full weekends worth of use on high with a single charge from four 2500mAh 18650 cells, but giving the light output of an incandescent 40-watt light bulb.
Per the Cree datasheets, 700ma through a U5 XP-L is about 265Lm.
In real world use that is plenty of light to sufficiently illuminate a small outdoor campsite or large room indoors. And I do think 250 or less will be the most commonly used level of the lantern. But I also think that it would be nice to have higher outputs (I mean, this is BLF after all) of maybe 500Lm available somehow.
What kind of driver did you have in mind for the production light, did you want it to be 7135-based?
If it is 7135 based, the PCB could easily be designed to accept additional 7135’s so that even if the production light shipped with 2*7135, the mod-minded users could add one or two more.
