The lens or the reflector? I was thinking the lens is greater than 14mm. No? I’ll measure it when I get a chance
err 17mm lens, the reflector inner diameter was 14mm
the Jetbeam reflector is deeper
this one should fit
http://www.kaidomain.com/p/S023866.16_9mm-x-1_0mm-Double-Multilayer-Coated-Water-White-Glass
I found the exact LED gaskets too:
http://www.kaidomain.com/p/S024686.11mm_8_2mm-White-Plastic-Insulation-Gaskets
A thicker lens will probably prevent the bezel from screwing down to the head all the way.
I would suggest to search for a lens with the exact same thickness as the Skilhunt lens.
the 16.9x1mm fits perfectly, I remembered it thicker
Jerommel, are you still willing to sell me the reflectors or I can send you the tirs they replace?
I would be interested in the reflector’s diameter & height so i can buy one .
Thanks
Yes, we’re gonna do an exchange (see PM).
It’s 15mm diameter and 17.3mm 7.3mm high.
Thanks ! It’ll be tough finding one .
MISTAKE!
it’s 7.3mm high.
Sorry…
I thought the same. I want the H03R but take too long to get here. I can get an H03 on Amazon in two days.
Where can I purchase the reflector and lens that will fit from? Prefer USA.
What about this reflector? http://www.kaidomain.com/p/S021651.15_8-D-x-8_8mm-H-OP-Aluminum-Reflector
Maybe it can be reduced in length…
Brands should sell spare parts i.m.o.
In this case, a headlamp reflector set = gasket, reflector, lens.
For TIR replacements they can simply refer to Yajiamei on AliExpress.
Hi guys,
I have emailed Skilhunt twice about TIR and Reflector parts and never got a reply.
Has anybody had any luck finding a 3rd party reflector that fits and works?
Thank you!
Me too
No…
I ordered one to try. It’s been delivered but I can’t find it. If I do I’ll let you know…
a downside of the reflector one is the hotspot of the NW is pretty yellow
I may consider a change, with the new AR lens, but it has its price to get a reflector H03 compared to the coupon TIR
Please keep us posted! Thanks
Yeah, typical small reflector hotspot, with a somewhat cooler white rim around the warmer circle of light.
I hate that.
It’s why i replaced the small reflectors of many of my lights with TIR optics.
