It’s on sale on Aliexpress for $20.80 now
I am trying not to spend any more money on lights for awhile :person_facepalming:
Thanks
This is one of those that’s great for people only having one or two lights. It has all the protections, the lighted warning to charge the cell, takes a high capacity 26650 so it’ll run a good long time (less, of course, if modified for output, but still good)
De-soldering the emitter it was quickly noticeable that the heat spread throughout the head, so the design is efficient even without a DTP MCPCB. All in all, I find it fairly impressive and a good competition for the big name brands out there.
Thanks for the review, Dale. Interesting light, just ordered one. Could be a great host for XHP with TIR.
Have you by chance measured the size of the driver and the reflector?
Yes, no different than a great many e-switch only flashlights. Double click to put in lockout, double click to remove lockout.
Edit: Gotta admit, watching that “no” reaction is funny.
Looks like (without removing it) the driver is 26.2mm diameter, the left hand thread brass retaining ring has a shelf in it that the driver sits into, centering the driver and making good solid ground contact. And the lens is approx 30.8mm. The reflector opening is 27mm.
Is there 1 o-ring around the reflector, but none between the lens and the reflector, or the bezel and the lens? Seems like you would need an o-ring around the outside of the bezel threads, and one in between the glass and bezel to keep water out.
That’s what I thought too. There is the one o-ring between reflector/lens/inside of bezel, but no o-ring between the bezel and head. What stops ingress between the bezel and head? For all that they did right, they may have missed something right there. Should be an o-ring up at the top of the threads on the SS bezel and a landing inside the aluminum head.
Edit: Ok, so I checked the actual physical aspect of the bezel and head… there is indeed an o-ring groove in the SS bezel and there is a landing, there just wasn’t an o-ring applied. There are 2 extra o-rings in the bag included in the box so I put one on the bezel and it does fit to seal, so that’s covered even if they left it out on my sample when assembling the light.
Edit II: In a similar way that the newer Eagle Eye X6’s have a ramped shelf on the reflector that squeezes the o-ring out into the bezel, this one does the same thing. When tightened down the bezel is sealed by the o-ring on top of the reflector in a 3 way contact of lens/reflector/bezel. It’s somewhat difficult to get this o-ring to spread out into this shelf once taken apart, I found that a back and forth on/off as I tightened it allowed it to flare out into the reflector shelf.
So, if there’s no o-ring sealing where the lens sits up against the bezel, can water get past the lens around the inside of the bezel and down into reflector housing? or do you think that o-ring around the reflector sufficiently seals that off?
It seems as though the o-ring around the reflector get’s smashed out into the sides of the bezel, like the Eagle Eye X6. When putting the reflector/o-ring/lens into the SS bezel it wants to hang up on the o-ring, so when tightened it should press out and make the seal.
Ok sounds good. Nice review btw!
I have an Lumintop SD26 that is of comparable size. The Lumintop has a fancier X patterned knurling and a slightly larger head diameter but they’re pretty close to the same overall size. The hot spot from the Sofirn SP33 is smaller but both are well defined. The Lumintop emitter color is blue-white, as compared to what is a now noticeable pink or slightly rosy hue in the Sofirn. I had thought the Sofirn hue was around a 3C, and that may well be, but it’s either that or a 3D.
The Sofirn has the lighted side switch cover, a nice touch, and also a SS bezel, again a nice touch. The Sofirn also comes in around half the price of the Lumintop, so all in all it’s a nice deal on a well made light.
Great review Dale, and really interesting light, Sofirn also have some new C8 models with 5,6Amp on highest level in stock with XPL , and 1700+ lumens they claim… Also driver have two setup with moonlight, and without blinking modes. They look good as Thorfire C8, so I am tempting to order one from Ali store.
Hello Khas,
The C8—C8F are ready on Aliexpress.com. If you are interested in testing the torch with 2 light groups, please feel free to contact us on Aliexpress:
Have a good time
Tracy
I have ordered one it’s currently :
“Waiting for pick up” Since : 2017-09-15 09:26:11 [GMT+8]
Hope somebody will pick it up soon
SP33 works fine with light diffuser for Convoy M1/M2. Good camping lamp with lot of light :+1:
Cool info, thanks for posting… I really like this one a lot, used it last night and am just really impressed with it’s coverage. This is one of those that a person would do well to have if only having a couple of lights. This and a Klarus G35 or an Olight M2X-UT Javelot and a guy would be pretty well fixed. (or gal)
Not really. The side switch design is all wrong. You need a light with a seperate switch, not one built into the driver.
I was searching this forum for a 26650 flashlight and settled for the sofirn one but apparently that model has been recently upgraded.
Those are the notable differences I found.
※ Emitter: CREE XHP50.2 LED
※ Working Voltage: 2.8V-4.3V
※ Battery Options: One 18650 Li-ion battery or single 26650 battery
※ Dimension:128mm (length)*37mm (head diameter)
※ Weight: 150±2 gram (without batteries)
※ Aerospace grade 6061 grade aluminum alloy, CNC manufactured to hard-anodized anti-abrasive finish to get solid built body, anti-crash geometry and better heat exchange.
※ Toughened mineral glass lens; Orange peel reflector
※ The waterproof level: in accordance with IPX8 (Ingress Protection X8- resistant to submersion up to a maximum depth of 2 m underwater for up to 30 minutes)
※ Mode Memory: It memorizes the last brightness level used in the general modes (except Strobe and Turbo)
※ Advanced Temperature Regulation (ATR) technology: ATR will adjust the brightness automatically when the temperature reaches 55℃ (131 °F) to prevent overheating.
※ Automatic Step-down: Turbo mode steps down to High mode after 2 minutes of working to prevent overheating.
Step-down and Advanced Temperature Regulation (ATR) coexist.
※ Power Indicator: The LED indicator on side switch displays Green for 5 seconds if remaining battery power is good. The indicator is Red, if battery power is poor. Red Flashes indicates extremely low power - replace or recharge battery as soon as possible.
※ Reverse polarity protection from improper battery installation.
※ High Voltage Protection: The light cannot turn on if the voltage was over 5 Volts
※ Low Voltage Protection: the light turns off automatically when the voltage was lower than around 2.6 Volts; The Turbo will be disabled autocratically when the voltage is lower than 3.4 volts; It steps down to lower modes automatically when the voltage is lower than 3 Volts
Has anyone else noticed or reviewed the updated version ?
Thanks for your time
