Convoy L6... XHP70 Beast!
4823 posts / 0 new
wolfdog1226
wolfdog1226's picture
Last seen: 1 year 3 months ago
JasonWW wrote:
I’d check with him about which protected cell to use. I’ve only had the KeepPowers which as supposed to be a top performer.
I see an Orbtronic rated at 15 amps.
I just ordered one from Vinh. Smile
I got the Orbtronic 26650
26650 battery Li-ion PROTECTED 3.7V by Orbtronic.
Real 5200mAh that will hold its rated capacity even under high current discharge load.
Free protective case included with each pair of 26650 batteries purchased.
Battery Specs:
Cell Capacity: 5200mAh
Cell Type: 26650
Dimensions: 26.5 mm x 68.8 mm (+/- 0.05mm)
Full charge: 4.2V
Recommended charging current: 2A – 3A CC/CV (Battery can be charged with current lower than 2A, but charging time will take much longer)
Nominal voltage: 3.7V
Cut-off: 2.5V
Max. Constant Current Discharge 15A (Protection circuit – cut off at 15A)
Weight: 97 g
Chemistry: Li-ion / Hybrid IMR
Positive terminal: Wide Button Top
Electronic External Protection: YES – full protection (overcharge, overdischarge, overcurrent (cutoff @ 15 Amp), short circuit)
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
DB Custom
DB Custom's picture
Last seen: 1 month 1 week ago
For most applications, that Orbtronic sounds pretty good. My L6 is pulling 19.38A at the tail from a pair of Efest 20700 cells (the LiitoKala cells are a bit less, around 17A as I recall), reckon those Orbtronic cells wouldn’t run it.
Newlumen
Newlumen's picture
I don’t know how is your xhp 70.2 survive with l6 with 9000 lumen ..
wolfdog1226
You are probably right, the Orbtronics may not work in your light. But I bought them for my light and I am sure they will work fine.
        WOLFDOG
DB Custom
DB Custom's picture
I haven’t run it very long at the highest level to date, who knows, might not last long. Good thing for me there’s more out there. Big Smile Somewhere along the way I got into pushing for all a light was worth, got hooked on that and it’s just how I do it now. Always looking for maximums from any given light. Not practical, I know, but it’s the challenge…
DB Custom
DB Custom's picture
But of course wolfdog, and in many another light they should work well also.
You DID, after all, go to a lot of trouble to post all the specs on those cells in case anyone else was interested… Wink They should make a good viable alternative for a gifted L6, even with some tweaks done to it. So it’s good to know what’s out there and available. Thanks! Smile
wolfdog1226
I do not understand the specifics of why one should use “Protected” over IMR. I am just following the recommendation from the gentleman who sold me the light.Only a handful of his lights does he stress us to use Protected batteries.
I am just glad that I chose the Orbtronic 26650 over the Acebeam 26650. The Orbtronic had a capacity of 5096mAh with a 9A continuous load.
I am not positive, but I do not think the Acebeam can even handle a 9A load,,at least not safely[too hot @ 7A]
The review below does NOT include the Orbtronic[15A max continuous discharge], instead it pairs the Xtar and Soshine against the Acebeam 26650. The Acebeam appears pitiful to me! It got way too hot at 7A .
For those who do not know the link can be translated into English. Cool
http://www.taschenlampen-forum.de/threads/acebeam-26650-5000mah-protecte...
        WOLFDOG
twisted raven
Last seen: 2 weeks 4 days ago
Where is a link to these protected orbtronics?
JasonWW
JasonWW's picture
Last seen: 29 min ago
I saw them with a Google search.
twisted raven
Ok, if it’s the one listed on their site, then I’ll have to get some of those.
wolfdog1226
They are in Tampa, FLA. area,,sal was still able to ship them to me yesterday despite all the power outages.
https://www.orbtronic.com/protected-26650-li-ion-battery-5200mah-orbtronic
        WOLFDOG
JasonWW
JasonWW's picture
Let us know how the Orbtronics perform and if they fit in the L6 without have to backout the battery tube from the head a little bit.
spinynorman
Last seen: 4 months 4 weeks ago
Orbtronic usually ships really fast. Like order on Friday, here (NC) on Monday fast. Faster than Amazon Prime. Thumbs Up
wolfdog1226
CPF coupon code will save you $2.60- C11P66F
        WOLFDOG
wolfdog1226
Will do,,,the batteries are due on Monday and the L6vn could be arriving the same day. In any event I will have both early next week.
Sal informed me that they fit in the L6.I put my trust in him!
The batteries are 68.8m with a max length of 70mm for the L6…….I believe the girth[width] should also be fine.
        WOLFDOG
KyleGates
Last seen: 1 hour 39 sec ago
I have those in my stock L6. Nothing special required to run them. All parts screwed fully together and they work great.
wolfdog1226
Welcome to BLF. Thanks for the confirmation. Wink
        WOLFDOG
twisted raven
Put a cherry-picked XHP70.2 80cri 2-step 3000k emitter in my L6, but the hotspot is still greenish compared to the spill, which I would say is magenta-ish. I have not scratched off the phosphor at the edges of the emitter though.
Now I’m thinking getting that lower binned easywhite emitter wasn’t worth the cut in lumens and lux if I could perhaps get a cherry-picked 4000k one with higher flux bin but still decent tint to it.
The_Driver
The_Driver's picture
Last seen: 2 days 12 hours ago
De-Doming it and removing all excess phorphor will probably help, but you will get a higher cct with these new LEDs.
wolfdog1226
DB Custom wrote:
My L6 with 70.2 is doing some 9500 lumens with flat top non-protected LiitoKala cells. No sure why the issue of protected always comes up, the chemistry of today’s high discharge Li-ion’s is much safer than it used to be and as such, negates the need for the protection circuits in all but the newest of rookie hands.
I agree. That is what my predecessors taught me.
I have to talk to Vinh because this does not make sense to me.
He APPROVED these batteries for these lights. I have been using them for 9 months in the K40vn and 6 months in the others.
TK61vn V4- VTC6
TN42vn-30Q
TK75vn KT-30Q.
K40vn-30Q
I am going to ask WHY I can not use High drains/IMR in the L6vn when they are perfectly fine in the aforementioned lights and many others?
        WOLFDOG
twisted raven
I think it’s because he said unprotected cells don’t yield greater performance with however he configured the driver.
He’s also not a fan of batteries in a series.
KawiBoy1428
KawiBoy1428's picture
Last seen: 6 hours 9 min ago
Liability. Playing it safe against the uninformed masses?
KB1428 “Live Life WOT
wolfdog1226
He answered one of my questions[b/4 I bought the light] but I did not ask him why…not yet anyway.
4. Is any 26650 sufficient? How about an Efest ,Vape power or I Joy? Protected 26650 only
The light is arriving tomorrow and the Orbtronic 26650 on Monday! I am very tempted to use my Vappowers tomorrow night!
        WOLFDOG
mortuus
mortuus's picture
Last seen: 1 day 3 hours ago
would a battery like this work for l6 ? or does flat not work at all? so confusing this all Sad
http://www.ebay.com/itm/Aspire-INR-26650-4300mAh-20A-40A-Battery-UK-STOCK-Vaping-100-Authentic-/292026185203?hash=item43fe1df5f3:g:dvUAAOSwax5Yn9Iq
or
http://www.ebay.com/itm/LiitoKala-2pcs-lii-50A-3-7V-26650-5000mAh-Li-ion...
and can u even use 18650 for l6 ?
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
JasonWW
JasonWW's picture
or
Think of how the batteries fit in the tube. 2 batteries, end to end with the positive of one touching the negative of the other. They have to touch to get electricity to flow. If the positive post is not high enough, they can not touch.
So if you use flat tops that don’t touch, like me with the blue Liitokala cells, you need to add solder blobs to raise the positive posts. Or some people use a tiny neodymium magnet between the cells to get a connection. (Magnets can cause extra resistance and maybe a short circuit under certain circumstances, so they are not a good idea).
Other choices are button top batteries or “raised flat top” batteries.
You can use 18650’s with a spacer tube to keep them centered, but you get less run time and maybe less output, depending on which 18650 cells you use.
wolfdog1226
Here is the rest of Vinhs answers. I do NOT like to paraphrase. I like providing original info.
PLEASE keep in mind this applies for the L6vn ONLY , NOT the stock light or what many of you modders on here may build.
1.Why can’t I use High Drain/IMR 26650 in the L6vn when you approved the use of VTC6 and 30Q for my K40vn,TK75vn,TK61vn and TN42vn??
70.2 cant handle the high draw from direct driven.
2.Could using them in a series be the reason for alarm? No
3.Would it hurt the L6vn to use an IMR 26650 for a half hour? Yes
For the First time in my 5 year hobby I am getting the light b/4 the batteries! Facepalm
I am going to listen to Vinh. I do NOT know enough about the electrical aspects of the Torch and the batteries to dispute him or others who may have a different opinion.
I am keeping it simple,,,meanwhile I will be tortured for 2 more days until the Orbtronic get here!
        WOLFDOG
DB Custom
DB Custom's picture
I tried Efest 20700’s in my L6 on the 70.2 and it pulled 19.38A at the tail. Seems the 70.2 is pretty tough, but I don’t know how close I may be to frying it. So I keep the LiitoKala’s in it as they run a couple amps lower. Still does 9100 lumens though.
KawiBoy1428
It’s always good to run what Vinh recommends he knows his lights best! And the wait will be worth it hang in there BUD!!
I have the 70.2 (2) P2-1A, P2-1C and the P2-3B in 4 of my modified lights, Lumintop SD75 Jaxman X6, Convoy L6 and the UTorch UT02
The 70.2 is pretty tough, I had them turn blue at 22-23amps at the hit running 2S2P VTC5A’s in my SD75 modified carrier, but running the VTC5’s just over 20 amps. Running the Lexel T/A Narsil 800SIR FETdriver.
I tested everything I have in my JaxmanX6 2S 404SIRFETDD the IJOY 21700’s hit at just over 21amps down to the Basens and the KeepPowers 15-17amps.
Do you have a clamp on amp meter? It would be interesting to see what your light is pulling with these recommended batteries!!
wolfdog1226
Comparison:
Good enough for me!
My M2X holster works for the M2X/M3X/U21vn[26650 light] and now the L6vn!
The last thing I want to do is carry a light for 4+ miles. I have CAPO and 3 lights on me every hike. I did not want to put this in a fanny pack or carry it,,who cares if the flap does not close!
Maybe in my next life I will acquire the skill and be able to mod my own lights like you guys!
        WOLFDOG
twisted raven
Is it common for the XHP70, XHP70.2 to only halfly light up on its lowest output?
Only 2 dies of my XHP70.2 are lit on the lowest mode, and noticeably dimmer looking on higher modes.
I was getting some faint flickering on the higher modes as well (fresh batteries), but have since not been able to replicate it.
