Put a cherry-picked XHP70.2 80cri 2-step 3000k emitter in my L6, but the hotspot is still greenish compared to the spill, which I would say is magenta-ish. I have not scratched off the phosphor at the edges of the emitter though.
Now I’m thinking getting that lower binned easywhite emitter wasn’t worth the cut in lumens and lux if I could perhaps get a cherry-picked 4000k one with higher flux bin but still decent tint to it.
Think of how the batteries fit in the tube. 2 batteries, end to end with the positive of one touching the negative of the other. They have to touch to get electricity to flow. If the positive post is not high enough, they can not touch.
So if you use flat tops that don’t touch, like me with the blue Liitokala cells, you need to add solder blobs to raise the positive posts. Or some people use a tiny neodymium magnet between the cells to get a connection. (Magnets can cause extra resistance and maybe a short circuit under certain circumstances, so they are not a good idea).
Other choices are button top batteries or “raised flat top” batteries.
You can use 18650’s with a spacer tube to keep them centered, but you get less run time and maybe less output, depending on which 18650 cells you use.
Here is the rest of Vinhs answers. I do NOT like to paraphrase. I like providing original info.
PLEASE keep in mind this applies for the L6vn ONLY , NOT the stock light or what many of you modders on here may build.
1.Why can’t I use High Drain/IMR 26650 in the L6vn when you approved the use of VTC6 and 30Q for my K40vn,TK75vn,TK61vn and TN42vn??
70.2 cant handle the high draw from direct driven.
2.Could using them in a series be the reason for alarm? No
3.Would it hurt the L6vn to use an IMR 26650 for a half hour? Yes
For the First time in my 5 year hobby I am getting the light b/4 the batteries! :person_facepalming:
I am going to listen to Vinh. I do NOT know enough about the electrical aspects of the Torch and the batteries to dispute him or others who may have a different opinion.
I am keeping it simple,meanwhile I will be tortured for 2 more days until the Orbtronic get here!
I tried Efest 20700’s in my L6 on the 70.2 and it pulled 19.38A at the tail. Seems the 70.2 is pretty tough, but I don’t know how close I may be to frying it. So I keep the LiitoKala’s in it as they run a couple amps lower. Still does 9100 lumens though.
It’s always good to run what Vinh recommends he knows his lights best! And the wait will be worth it hang in there BUD!!
I have the 70.2 (2) P2-1A, P2-1C and the P2-3B in 4 of my modified lights, Lumintop SD75 Jaxman X6, Convoy L6 and the UTorch UT02
The 70.2 is pretty tough, I had them turn blue at 22-23amps at the hit running 2S2P VTC5A’s in my SD75 modified carrier, but running the VTC5’s just over 20 amps. Running the Lexel T/A Narsil 800SIR FETdriver.
I tested everything I have in my JaxmanX6 2S 404SIRFETDD the IJOY 21700’s hit at just over 21amps down to the Basens and the KeepPowers 15-17amps.
Do you have a clamp on amp meter? It would be interesting to see what your light is pulling with these recommended batteries!!
My M2X holster works for the M2X/M3X/U21vn[26650 light] and now the L6vn!
The last thing I want to do is carry a light for 4+ miles. I have CAPO and 3 lights on me every hike. I did not want to put this in a fanny pack or carry it,who cares if the flap does not close!
Maybe in my next life I will acquire the skill and be able to mod my own lights like you guys!
It depends on the driver output at it lowest level. If it’s a very low moonlight, then some of the dies might not light up, but anything above moonlight should be all of them.
Sometimes protected cells can act funny. Both of my KeepPower protected cells did a weird flicker on the stock driver on high mode. I have a video of it. It only did it at 4v and above. Very strange. Using different batteries fixed it.
my friend was asking for some beam shots tonight, figure I share it here too. this is my l6 @ 17A start, after 5mins it is too hot to handle, seriously!
I don’t feel it’s the driver, although maybe. I noticed that the flickering is no longer an issue with the light, but I figure it doesn’t flicker now because the one half of the XHP70 .2 doesn’t light up, while before when it flickered, it was that one half of the LED going in and out.
Even if it’s 1% output or 100% output, I can see only one side of the emitter glow once I power the light off.
Will have to message Vinh about it. He accidentally gave me a tail-switch UI instead of a side-switch UI anyways.
The dies on the xhp70.2 are wired in 2s2p. So if it has been pushed hard and run very hot it’s possible one of those little bonding wires has been damaged and is not getting good contact. That would cause 2 of the dies to not light up or be weaker.
