*BLF LT1 Lantern Project) (updated Nov,17,2020)
Yes I wanted to convey that 12v out seems not smart to offer
  1. I find laptops WAY convenient than tablets.
  2. I find a power bank WAY cheaper than tablet. Especially that I have batteries anyway.
  3. 4*35E holds more energy than an average laptop, though there’s conversion loss.
  4. If I use all my high-capacity batteries, I could run an energy-efficient laptop for entire weekend. Or my i7-7700k one for 12 hours. :slight_smile:
You doing business work out in the woods? Lol
If I go camping I want to be left alone, and the quality of the latern and runtime is for me the top priority, the other stuff is nice to have, but if it would impact the quality of the lantern I’d rather do without the other stuff.
Agreed. You are camping, leave the laptop at home and use your phone if you MUST check email (or Facebook if that’s your thing). Or as Jason said, a tablet if you can’t survive for a weekend with “just” a phone screen (but them why are you camping at all?) and as was mentioned, most laptops need 19v anyway, so the point is moot IMO.
Now on the other hand, 12v in seems highly useful, being able to charge the light from a car or 12v solar source adds a lot of functionality.
I think if it is decided to go with 12v out, it should be in the form of a cigarette lighter socket. That means any car adapted devices including usb adaptors, lead lamps, car vacuum cleaners, mini compressors or airbed inflators can be used. Sounds useful but it seems like a bit of a stretch at the same time, a big ask for 4x 18650s, and the potential amp draws make the required components probably a bit chunky and expensive.
Maybe a task for another project, a one-size-fits-all emergency power source, with adaptors for everything and a light for convenience.
no way i can imagine a boost circuit to make the 2.9-4.2V cells deliver 12V would make sense and probably is very expensive
Lets forget about anything other then 5V USB out please.
Definitely agree there. Its just not practical or a good idea at all to put a 12 volt output on a small lantern, especially one that has to be compact as a beer can and have long run times from 4 - 18650 cells in parallel.
a 5 volt USB charging cirsuit is possible, but a 12 volt out, no.
Many power banks have cells in parallel with QC USB output at 12V. Let alone all the single 18650 XHP35 lights.
And all those XHP35 drivers out there?
A single boost driver could deliver 6(?)V to the LEDs, 5V to the USB output and 12V to the 12V output. It would possibly be somewhat more expensive than linear + small boost, but would deliver better efficiency, higher 5V power and 12V (with slightly worse efficiency) on top of that.
[quote=sac02]
Is it really? There are plenty of 12V->USB converters out there…
Great, thanks! (nobody has understanding for the decision of pb anyway)
[quote=Agro]
This is true
And would mean a port less, less electronics so yeah valid IMHO but it is up to DBSAR of course.
[quote=The Miller]
To keep the cost, size, and complexity of the lantern to what is practical, no 12 volt output is planned. This is to be a “lantern” that is meant to do what a lantern is supposed to do. :slight_smile:
(I use a portable 20 AH LiIon booster unit i bought from Interstate for when i need a portable 12 volt output on wilderness or camping trips.
HI,
ive been watching this project off and on for a long time now,
I have a couple of suggestions for you , feel free to totally ignore them as they are only a couple of ideas from a distant admirer,
1, if you are going to put a USB power out on the lantern then please make it a USB-c compatible output.
yes i know this is not a simple circuit but it means it is 100% upto date and would make it last a lot longer as a design.
it would allow fast charge (2-3 amps from memory) both in and out with the right components.
2. is there a reason you dont just use the led’s on the torch side with a reflector on the top not the bottom and then just turn the torch upside down? it would mean you are just adding a reflector to the top instead of trying to mount the led’s up on top.
anyway , feel free to ignore
Scorpia
Physically it’s a good choice. But supporting USB 3.1 by protocol would make the project to expensive.
Also the 2.4A usable without USB3.1 are indeed quite a bunch of power (15W). More than enough to charge 1-4x 18650 cells with up to 1A and powering the lantern simultaneously.
Talk is being done
While there are very cheap chips to be found it is a tell tale sign Xiaomi is using a Ti chip in its powerbanks.
I asked the USB C question in the PM DBSAR, DEL and TK are having aboit the driver. But as always costs are an important factor and with all the mUSB hardware it is long from dead and loads if adapters can be found and surely will be able to be bought for many many years to come.
yes i understand cost is an issue not sure how much of an issue,
as for the usb-c connector it has one big advantage if done properly. 1 connector for charging and discharging.
also you wouldn’t need to support usb 3.1standard as this is a power back, im pretty sure there is a different standard for power delivery.
Either way, people are looking at the idea so it cant be all bad,
I have been playing with my Q8 with lantern attachment for a while and I noticed that the Q8 is pretty heavy for a lantern. And then I realised that this weight is not at all needed for a lantern: apart from the batteries the lamp may weigh next to nothing because the maximum power used will just be around 3W, so heat-path and -sinking is as good as irrelevant. A bit counter-intuitive for BLF, but I vote for a (sturdy enough for abuse but) lightweight design.
I definitely agree. If BLF is going to take on this project, I’d much rather see an original lantern design that strives to push the design of LED lanterns forward rather than a diffuser-like attachment or a design based off a flashlight that was never intended as a lantern. That said, I do like the size and form-factor of DBSAR’s prototype.
