It’s seems crazy to say a light with 18 power leds needs a lower low but it would have been nice here. The UI isn’t anything fancy but compared to the mess of their S42, where you couldn’t turn it off without going to level 2 and if you try it goes to turbo and if you try at that point to switch modes you get strobe. Yeah, way better than that but not a big fan of the hold and wait to turn off but have been getting used to it in their lights and the Manker ones. Maybe it’s just their thing.
Just got my Nichia! One bank is a noticeably dimmer than the other two in Low and Med (not enough to be noticeable to the casual observer on Med), but seemed to be gone by Med1. To get a good look (without frying my retinas out) I used a Shade 12 welding mask to look directly at the light at all levels . I could then see that the one bank is still dimmer on Med1, but only slightly so. On High and Turbo, all banks appear to be emitting at equal levels.
Only one little nick at the base of the head. I installed then took out the tripod mount, as the hole for it seems to be the natural spot to rest the head on your index finger.
Dedicated Extension Tube and additional battery holder doubling capacity??
One of troubles of this model.
After contacting BG, it seems to send a battery holder.
It becomes two battery holders, it is used for spare use or for verification, it is a meaning hit.
As soon as both heads are turbo with 2 heads it will be red indicator.
The battery is Samsung 30Q.
Once turned on, it became a green indicator with one head.
In the outdoors, the XP-G3 also showed no unevenness and was not bad.
I also feel a little bright.
I took some beamshot last night. Both Q8 & MF01 is very impressive based on cost–performance ratio! I estimate MF01 is over 10000lm. MF01 UI really bug me… it works, but I much prefer Acebeam, Olight or Q8 ’s UI.
:exclamation: *Sorry guys, I decide to take off some of my beamshot photos. I was so exciting about new MF01 & BLF Q8, I forgot to check the batteries in the lights before taking the beamshot photo. I recheck all batteries & found out none of them is fully charge 4.20V; only MF01 & BLF Q8 used fully charge batteries.
I’ll post new beamshot soon* :exclamation:
From top to bottom:
Control
MF01 219c- ~10000+lm
BLF Q8- 5600lm
m43 219c D320- 7400lm
Olight X7 NW- 8900lm
MK34vn xpl-hi 4000k- 7400lm WB 5000k/iso 400/ shutter 1/4
Just using a ceiling bounce test I’m reading the MF01 34.8% higher than my M43 meteor. So if the meteor Nichia 219c is 6600 then that would make the MF01 around 8897 or so. I had used it a little earlier in the day so the cells were prob at 90%. But I’m happy with a 9000L OTF NW. Also, I’m just using a cheap Lux meter and they don’t measure NW as high as CW since I understand they are more sensitive to more blue vs reds.
Also, I meant to mention like other Astrolux lights with the green eye, you can turn off the green dragon breathing light and lock it out by holding down the button for 2 sec. Then, unlocking it by hold it again for 2 sec.
Mine just arrived (219c), cosmetically perfect except for a very tiny scratch ~0.5mm long. Have to be looking for it. Functioning perfectly but only 5 minutes playing with it in full sunlight so far. Think I’m going to love the beacon.
Just hold the button down for < 2 sec. to turn it off / on. This is the lockout.
It would be great if you could measure all brightness levels too. Than we can compare it.
Perhaps I will open a ticket on banggood and ask for a new driver of the XP-G3 Version.
It is not good if the XP-G3 reaches almost the output of the specs and the Nichia reaches only 65% of it.
I just received my Nichia-equipped light and can’t wait to see what a quad of VTC6 cells does to the neighborhood night sky. Only a few more hours until we see.
I bought some smoke grenade pouches for my soon-to-arrive Q8 lights and the main body of the light fits but the top-heavy bright end sticks out and it doesn’t reach the bottom. There’s a lot of velcro holding the flap on so I guess it could work, but I’ve got a couple other larger pouches ordered that will most likely work better.
I also added a screw-in thingy inside the tripod mount so I can attach a sturdy strap. It sticks out kinda far but it keeps it from rolling. Here’s the link to see what I mean:
I swapped out the 30Qs that I ordered for this light, with the HG2s in my HaikeLite MT07. Seemed to get quite a performance bump over the 30Qs. Also, it heats up a bit quicker, and the power level does not go to red as quickly in Turbo. I had previously tried out the 30Qs in the MT07, while I waited for the MF-01 to arrive, with no noticeable difference in output.
