Domain expired.
Really excited to see this new version. Will there be a model with cool white led?
Could someone clear up the specs on this light? Is this light 4500, 5000, or 5500 lumens and is the max throw 500 or 750 meters? Thanks.
looks good!
what you mean ” no step down”, the light maintains the output even it reachs 100*C ?
If you shut down the thermal control, the output will maintains even it reachs 80 degree C.
i like your flashlights mostly (tested 3 of them)
but idea to put XHP with SMO is strange.
i mean XHP performs best with OP.
may be you guy thought about XPL-hi or L2 there? good old decisions for throwers.
anyway, i`m glad to see that you keep on doing new stuff.
It's XHP70.2, not XHP70. The XHP70.2 performs well with an SMO - if focused well, cant see the black hole, and throw is definitely better. In fact if you are interested in max throw, we've been using SMO's with the XHP70 in the past. Now pretty much we are all switching to the XHP70.2.
I’ve got some 70 vs 70.2 in an L6 with SMO comparison pictures here.
If you look at the darker shots you can see the improved beam pattern of the 70.2. The dark hole is much reduced. When viewed at normal brightness levels the 70.2 appears very smooth. I got 830 meters on my light and I know my numbers are a bit lower than average.
woah, there is a chance i can boil an egg with this light, i guess
Hi
My MT07S stopped working after one day.
Work dwo modes, in one flicker, I can not turn off the flashlight.
The flashlight (the reflector) probably I see smoke rising.
What could be damaged?
Hi
The flashlight (the reflector) probably I see smoke rising.What could be damaged?
Probably driver (I mean what else?). I’d contact vendor immediately for DOA warranty.
@hIKARInoob, thanks for the quick reply.
Tomorrow I can record a video that shows the damage.
Are you from HaikeLite?
In many reviews people write that this model can work with 2 * 18650 - is not that true?
Tomorrow I can record a video that shows the damage.Are you from HaikeLite?
Hey how are you man? No I’m not from Haikelite, hehe. From what I know, the MT07S is 4S (4 cells in series), so you do need all four cells for the light to work. This is not the case with the larger MT07 which can operate with just two cells.
Both Banggood and Gearbest have a DOA (dead on arrival) warranty. Within three days for Banggood and seven days for Gearbest (IIRC), if you report a defect, then you don’t have to pay for shipping to China. So it’s best to upload video to Youtube and report problem within this period.
Nice video and impressive beamshots from Mr. Charles Bridgtec
Got it, mine is NW, very impressive and brighter than my RC40 3500lm. 4500lumens heat up whole light fast even the batt tube. I took battery out and batteries are not as warm though.
I used small magnet to make contact. Don’t feel like to remove the +ve batt plastic yet.
Interesting…360kcd
How is this model an upgrade if it has 2,000 less lumen? What is different about it? Did they switch to a sliced dome xhp50.2?
