If it was my own, probably. But Iām building them for our sonās place. FYI, they will end up with sliding Japanese Shoji doors. They look a little like a window with a lattice framework. Instead of transparent glass traditionally they use translucent paper. We will be using a laminated paper for greater longevity. LED strip lighting will be run behind the lip of each shelf. They will be dimmable.
There will be real books. Who knows what else? Maybe a Q8 if I can bring myself to give one of mine away. :person_facepalming:
Back to this years contest entryā¦.
More holes neededā¦
After drilling those three holes I sliced off a slab with the table saw. Then drilled out the holes in the block and pressed some aluminum threaded inserts into place.
Another view of the block and plate. When completed the plate will be mounted back onto the block face.
I need a round copper disc, 3/4 inch in diameter for a cell contact. Using aviation snips I cut one from a scrap of 0.020ā copper. This is the rough blank.
A file was used to remove the excess and round it off
That is a piece of 3/4ā walnut dowel used to check roundness and size. Looks okay to me.
It is a tight slip fit. I use a bench vice to slowly squeeze them into place. I did not use any glue on these as I donāt think Iāll ever torque the screws heavily enough to worry. When I feel the need to lock them more securely I use a triangular file and file a small groove down the length of the aluminum insert. Then when it is in place a drive a small brad, or finishing nail into that groove. It locks very well.
I used to have some special cyanoacrylate glue that was made to allow making a slip fit. Made by StarLoc, Wet one side like the wood hole, drive in the insert and in about 5 minutes it would set. I still have the empty bottle, but have not found anything like it. Havenāt looked hard though. I bought it from a UK seller a couple years ago.
Iām back in Aus after spending the last week or so in the US on vacation, & have a lot of catching up to do; both reading BLF, & working on my DIY buildā¦.
ā¦that reminds me, MRsDNF wanted some Drag Week picsā¦.
FYI MtnDon, a US penny is 3/4ā diameter, and if you get an older one (what was itā¦ pre-1982?) it is nearly pure copper (at least as pure as that plate you cut out, probably.) Once you sand it down flat, it is nice for this kind of thing.
Some days are better than others; some worse than most. Today was one of those oops days I suspect most of us have experienced from time to time.
Rather than starting with a new block of padauk I am making a slight redesign to cover, do away with the oops. I sliced of some of one side and have a slab of something brown glued and clamped. I say something brown as I have no recollection what it is. Itās not American walnut. The glued up laminate is on the left. The wood on the right is just a clamp block. Tomorrow Iāll trim the excess and then slice off just enough to return the block to its former thickness. Then carry on.
The contrast between red/orange and brown should look fine. I hope it looks planned.
To add insult to injury I misplaced the wonderfully round piece of copper sheet I made. It seems to have been swallowed up the the gremlins. :person_facepalming: So I found two 1976 pennys and filed away the design on the tailside. Iāll use those rather than carve and file some more sheet goods.
I trimmed off the glued on ābrownā wood. I made an āOā into a āUā. I removed a portion of the wall that encompassed the large diameter hole using the table saw, then a file and a sanding block. The block edges will be radiused next.
Hereās the side with the glued in ābrownā wood.
The removable access plate that I refer to as the back.
I tend to hang onto things. The 8-32 screws that secure the back are aluminum chassis screws from way back when we raced 1/10 and 1/12 scale cars. The screws are from my box of left over Associated RC10 parts. The heads are a little rough on those; final assembly will be with ābrand newā 33 year old screws.
Hmmm. Where U perceive a C, I C a U. :person_facepalming: Funny how we look at the same thing and see something different. My head must be on sideways to see a U. :laughing:
Towel ; That is a genuine āshop towelā! A hand me down, so I am totally safe with whatever I do with it. :+1: It is a little worse for the shop wear though,ā¦ I should have looked for a cleaner one for a photo backdrop.
Moving on. I filed down one side of a pair of pre ā82, real copper, pennies to make two contact plates for the cell. Both have a spring soldered to one side and a wire soldered in place as well. I neglected to take pictures of one of them before I installed it in the cell hole. :person_facepalming: I did photograph the other though. Iām planning on using a flat top Panasonic 18650B cell. The springs will also allow a button top to be used. The driver that is planned has LVP so Iām not thinking of a protected cell at all.
The disc below has the wire through a hole from one side.
The side with the spring in place. Yes, black = negative.
The first disc I made I glued in place before thinking of the camera. Darn. The red arrow points to the contact disc with the spring in place. Kinda hard to get a photo shooting down the cell hole.
This image from the bottom access hole view shows the edge of the copper disc with the + wire. The darkened spot is the result of the CA glue.
The switch is a small Omten 1288 reverse clicky. It needs to be mounted on the end of a dowel rod (wood) that the first item I made (the copper cap drilled for a switch boot) will fit over. The Omten 1288 is just a little smaller than the dowel rod. I needed to drill holes through the dowel to run the wiring. Some holes at an angleā¦
Hereās looking at the upper end with a tweezer through one holeā¦
This is the view of the bottom end. The slot on the circumference is a keyway that will slide over the protruding edge of the copper disc, in the access hole.
Hereās a couple of pre assembly shots showing the switch mount with wires running through the inner holes. That will slip into the hole in the body of the light.
Also note the rounded edges of the block. Those were done with a 3/8ā roundover bit in the router. I sanded the block and gave it a couple of coats of clear acrylic finish. The final finish coats will be applied when it is complete.Right now I simply wanted to keep the wood clean and keep the orange color from wood dust from getting on me.
Lastly for today, another shot showing the + end copper disc. A little easier to see than in the other shots.
Thanks. I have a wide variety of abrasives that I use. I like the acrylic clear coat. (Minwax Polycrylic) Dries quickly, even more so in the low humidity of our desert. Makes a smooth finish that responds wellto the 280, 320 and 400 grits Iāll use between the final coats. Padauk though, has some rather large pores. Very obvious in the end grain and a little less so when cut with grain, but visible on most surfaces on this. Not objectionable on most things Iāve madewith it.
