Thanks for the info, Ill just have to stick with my 8 page instruction UI on this one haha.
Here’s a condensed version
Uh, that looks complicated.
It looks complicated, but it’s one of those things that is very wordy to explain but simple in execution.
I use UI 3 and love it. I have my 3 levels set like BeardedRaleigh just mentioned. Here’s my explanation from a few posts ago:
While the light is on, double-clicking will continuously cycle through the three brightness settings. A ‘fast then long click’ moves backward while the light is ON.
Once you get comfortable with the operation, you can also use shortcuts to the three modes from OFF.
At any time while the light is on, holding the switch activates Turbo until you let go and it returns to the mode you were in. This is one of my favorite features.
Out of shear curiosity: Has anyone (maybe ToyKeeper) identified the used chips on the driver or has at least high-res photos of the driver where the markings are readable?
I found this post on TLF where I can see the components or a photo on some russian site but neither A335 for the D1 component or VT1 are readable well enough or can be found somewhere.
From the general circuit it looks like VT1 is the mosfet for the boost converter, D1 is the uC since it has pads for the switch and LEDS and D2 is some kind of OPV?
I’m just curious how they implemented everything (discrete buck IC + control µC, µC does buck in SW, …)
If you are not able to make boost driver design “from zero”, dont try to rechip meteor driver. You will get tons of issuies from hardware that you wont fix.
I don’t want to change it, I just want to know how it works and which components are used.
While I’m no pro, I still have a common understanding of power electronics and electronics design.
Thanks, that’s a great info!
If I see correctly this is some kind of driver the M43 is based on? Because the M43 is missing some redundant parts that allow for higher currents/faster switching.
Yes, this is most complicated sample schematics that is allowed for sharing and making by yourself.
The M43 code and driver schematic aren’t available, but the schematic above is similar and an older version of Indigo is available. It’s written in assembly. This may be enough info for someone motivated to fill in the gaps between what is available and what is not, but nobody has created any other firmware which can run on it.
So, nothing Narsil-like on the Meteor.
However, if you want the Meteor UI (er, UIs) on your Narsil light (Q8, GT, D4/D1/D1S, etc), that can be arranged. I implemented most of it one evening while cloning UIs for my new toolkit, and could probably finish the rest in a few hours if anyone wants it.
Interested ! Not for a particular light , but i would like to use it in some e-switch lights . So , i’m not in a hurry
G'Day BLF'ers, and Meteor M43 "addicts",
The Noctigon Meteor M43 from intl-outdoor.com is now available with Nichia 219CT 90CRI 5000K LEDs
Edit: And the Emisar D4 from intl-outdoor.com is also available with the same LEDs
Best Regards,
George
My Meteor M43 Nichia 219C saved the day! Tonight was my daughter’s Homecoming dance and she had 16 of her friends come over beforehand. It was raining out so they couldn’t take pictures outside. When they gathered in the living room to take pictures, we were trying to figure out the best location, but the lighting wasn’t right. So I ran down stairs and grabbed my M43. I did a ceiling bounce in turbo and the pictures turned out great! There were lots of pictures, so in between pictures I cooled the flashlight with my hands. At times it got very hot, but it never shut down and kept providing great light. Some of the parents were quite impressed with the flashlight. This is the first time I actually felt justified buying such an expensive, but worth every dollar, flashlight.
Great story! Should of put a fan on it to cool it
Thanks for the info - I’ve been waiting for it to reappear, even if that makes things a bit awkward … so many nice lights, so little money! Wanted to get a 2nd MF-01, an MT07S, and either an SRT9 or Fitorch MR35, and now the M43 is available again … someone please convince me that I don’t need any more flashlights! (or maybe just one, or two…) :sunglasses:
The m43 its sold out with all leds… Anyone can confirm?
Saw this too. Specs were also changed back for the Nichia 219C to 80+ CRI (from 90+ CRI). It’s probably done because they’re busy selling the D1 and D4. My guess…
Well, at least that means I can see a cyan D4 coming my way! :heart_eyes:
If I had already had a Q8 I would not have purchased an M43. Would have saved a bit of cash.
