Little Emisar family
Put the 18350 tube on and you hardly know it’s there.I don’t even notice a dropoff in output with an aspire cell
Just a few rough n ready beam pics for a rough idea
D4 xp-g2 4000k
D4vn xp-g2 PDT
D4 219c 5000k
D1 xpl HI 5000k
ven: Sledgestone:Nice pics as always, Ven!
How is the tint on the D1?
Thanks for kind words, looks nice so far(typical 5000k xpl HI), not had real dark yet! So i will have a better idea in 3-4hrs. Quite a large hotspot compared to some small throwers i have had, nice and intense but not to a point its unusable closer up(does that make sense). Personally i think 30-40kcd type beams is ample for most EDC type uses that need some easily accessible throw(variable of course). So many lights are too big to carry easily and tend to get left at home, no excuses with this one!
May be a little bulky for pants carry(pants dependent), but say during colder months and the coats/jackets come out………….should be no issue EDCing .
I meant more for the larger head type bulk. The 18650 form on the D4 is fine for me to EDC. Tad bulky(diameter wise to my ZL’s) but i can easily live with the benefits.
This succinctly says how I feel about my D4 compared to my ZL SC62w.
ven:I meant more for the larger head type bulk. The 18650 form on the D4 is fine for me to EDC. Tad bulky(diameter wise to my ZL’s) but i can easily live with the benefits.
I have the sc62d in work(only 320lm but use H2 mainly at 145lm!..………its enough for me), so easy to pocket and not know there. For an 18650 fed light, its sure impressive in the compact form stakes.
Here is the sc63w next to the D4
Been using the D4 xp-g2 4000k quite a bit this evening, damn this CT is nice. So easy on my tired and should be in bed eyes…………really like it.
Nice beamshots. Got to love that 4000k xp-g2.
+1 that was my favorite as well.
the D1 looks like it has great spill
although it looks like the camera changed the exposure
unless that one is out of sequence and was earlier in the evening
Mp0wer:Just got one delivered from MT, thanks for the review
Ah, so that’s where the last 4 Aspire cells went.
I had the page open to order, but went to eat first and when I came back they were out of stock. Oops.
Too bad I can’t try out my aspire batteries, I think there’s something wrong with my 18350 tube, the light works great with the 18650 and 18500 tube…any suggestions ??
did you try turning it around?
the shorter threads go toward the head
I did try both ends, I also tried using a paper clip to see if maybe it wasn’t grounding properly
Could you post a picture or 2 showing the 18350 tube, particularly the ends?
Thanks
you might try putting the longer threads toward the head
and then trying the paperclip to bridge the battery base to the bare tube edge
it’s such a simple tube there must be a simple explanation
like the shorter threaded part not reaching deep enough?
MPOwer
I had that problem. I used some steel wool on the edges/ends, mine works fine now.
Thanks
Interesting.
Just found out from reading on CPF about a hidden feature in the UI:
After you double-click while the light is on to jump to max turbo, you can double-click again to return to the previous brightness setting.
and then trying the paperclip to bridge the battery base to the bare tube edgeit’s such a simple tube there must be a simple explanation
The long side worked with the paper clip, but not with the cap, if you look at the picture one side of the tube is thinner.
Well, that is strange, butt we know the short end is the problem.
I’m sure Mtn will make it right. Give them a call.
Sub’ing because how did I ever miss this thread. Will have to order one here shortly…
Just to clarify, what are the differences in the D4 and the D4vn models? Somewhere in the last 70 pages I am sure I missed some important information.
