JETBeam TH20
High-performance Tactical flashlight
Features
- Specially designed for tactical activities, military use, law enforcement and hunting
- Use one CREE XHP70.2 LED with lifespan of 50,000 hours
- Extremely high-performance tactical flashlight with max output up to 3450 lumens driven by one high-rate 18650 power battery
- Compatible with one common 18650 battery or two CR123A batteries
- JETBeam's patented triple tail switch technology allowing for momentary-on, strobe and easy access to all outputs, with one hand operation
- Four outputs with memory function and strobe available
- Max intensity up to 25600cd with a throw distance of 320m
- Max runtime up to 100 hours
- Optional with OP and SMO reflector for different demands
- Intelligent temperature control system to maximize liftspan of LED
- Low temperature resistance of minus 20 degrees Celsius
- Waterproof rating: IPX-8(2 meters under water)
- Impact resistance of 1m
- Toughened ultra-clear mineral glass with anti-reflective coating
- Constructed from aero grade aluminum alloy
- Military grade HAlll hard-anodized
If you are interested, notify in this thread (not in PM)
My main thread: GearBEST.com Coupon Codes&Flashsales
My other groupbuy threads:
KLARUS Mi1C ✺ Mini-Mighty EDC Flashlight - Interest List CODE IS SENT
NITECORE DL10 ✺ Dual-light source DIVING light - Interest list ACTIVE
