Just got my hands on some P2/ AA binned( kit 752)(VL voltage binned) emitters from those.
In a M2x host, they start at 8.5 amps with a VTC5 battery and they hold! over 2k lumens and the incledible 370k candlas folks with the lovely pinky 5500k tint( inder M2X default glass)
A default M2X compared to this looks like a joke, literaly
Those are the same stores BLF fellas, i know OT LED rom the time when they started, at first ( the store owner is called Amanda) they provided me even with the exact bin, but then they business expanded and they started selling fakes, factory reject and bad binned emitters, youll never find anything good in there now
Typical corporate illness, callled more profit and greed: thats the main reasos we have those random global econ crysis if you ask me, too much greed
You know, there was a time when this store have found 1304 Cree chips with the impossible bin and 96 CRI, and they were great….now, they care only for more profit, not the quality
99% of the buyers dont care the the emitters bin and quality as long as it “shines”
Sellers like RMM and IOS are rare as hell, Mouser for instance dont know exacly that they are selling, i had several quite long chats with their support, and believe or not i do believe that most of BLFers will work ways better than those ppl
Thanks for this. Wait, so does a dedomed sst40 throw very similar to a dedomed xpg2? I would t think it would, but looking at your numbers on those host,especially the c8, it seems like a xpg2 would give similar results. I think I remember seeing you get like 175 kcd on a c8.
Bought them here, they look ok to me, nothing to indicate they are fake!
They look exactly like in djozz first post:
They are CW for sure (which is ok for me because I need them to have best throw they can and NW or WW
doesn’t throw as good as CW) but there is no seller on aliexpress that will provide more precise informations.
I would be very happy if I could buy from Mouser or MTN (all those nice drivers :/) but I just can’t afford
paying 60$-70$ for 10 leds + 20-30$ for shipping
As stated before, I ordered from Shenzhen Great Technology Co.,Ltd. All came with bubbles. Some small, some big(ger). So at least some of them should be dedomed. Question was: shaving or solvents. I decided for the first and remembered that TK once mentioned using a washer. The bond wires protruded about 1.5mm in the dome, counting from the star. Of course I had no suitable washer in my box of bits and bobs. What I did have was this (very old and rusty) key to a bicycle lock.
I gave it a tour on my whetstone, and then it looked like this. A nice smooth working surface for my knife.
With a handle. And the 7mm hole almost directly offered a perfect fit for the base of the 5050 LED.
So you put the tool upon the star. The LED sticks out a bit, and presto!
Unfortunately I used the wrong knife. Or the knife wrong. Despite the smooth tool, the surface of the LED looked like a plowed field. Time to execute plan B: using MEK. Two hours later the LED looked like this
The result? I’m not sure what to think of the absolute values on my LX1010B luxmeter, set at 2 meter. I’ll give you the outcome “as is”. They should be treated as relative results. Only comparable within the following list.
Nevertheless a nice outcome for my first dedome of an SST-40.
Convoy C8 with X5/X6-driver. XM-L2 with dome: 102
Convoy C8 with X5/X6-driver. XM-L2 dedomed: 183
Convoy C8 with X5/X6-driver. SST-40 with dome: 112
Convoy C8 with X5/X6-driver. SST-40 dedomed: 194
Convoy C8 with LD-2. SST-40 dedomed: 192
For reference
Olight M2X-UT with dedomed XM-L2. Stock: 290
Thrunite TN32. Stock: 424
Edit: did some tinkering and added a few results. In all cases the SST-40 offers a bit more throw than the XM-L2 U2-1A.
The bubble (s) come from re-flowing, got seven of them from Kaidomain and re-flowed as normal, the last 2 sat a little longer and developed a bubble (s) inside, no artifact’s in the beam from them that I can see, but then they are in a triple mmuX3 pulling just over 24amps. (right click then enlarge to see bubbles)
IJOY 21700 and Modified FETDD driver using the Hyperion FET that TomE turned me on too! :+1:
I also dedomed some of this leds and I am not that happy with results, I used heated liquid method that gives me almost perfect results with XPE, XPG, XML and XPL types of leds but SST-40 is tought cookie. In all cases silicone dome did not separate from phosphor surface so cleaning was required and that never gives “perfectly clean emitter surface” results.
So, I am not happy for now.
Click to enlarge…
As you can see, one of them is missing a bit of phosphor and the other one has tiny pieces of silicone that cant be removed without further damage to emitters surface…
