Is that a hidden feature? It’s in the UI diagram, and Hank found it important enough to add some text about it to his version of the diagram. Here’s the image shown at Intl-Outdoor’s product page for the D4:
Ran a thermal runtime test on the D1 with a 30Q. It held turbo for about 1:24 sec. Gradually stepped down all the way to about the 10 minute mark. At that point I think it was about as bright as the regulated to FET jump point. Then held it until around the 12 minute mark when it started to ramp up again. Love it! After 15 minutes it was warm to the touch and the 30Q was at 4.10V.
Also, not in the video but I compared it to one of my worklights, a Streamlight Stinger LED HP 350lm 56kcd, and the D1 seems to throw a little farther with a significantly wider hotspot.
Yes, it is real nice for evening /night uses(reason I say that, if used in the day in poor artificial light, it can do all kinds of things to 4000k beams. 5000k works better for me in these conditions). I have an EDC plus triple, that is also xp-g2 4000k and why I new I would love the D4 4000k. Also Malkoff uses the 4000k xpg2 for his N (neutral).
Cool. It’s nice to see that it can run so long before the first step-down, and that it’s fairly gradual. I was really hoping the decreased power and increased thermal mass would make that happen, but I haven’t been able to actually test it yet because I don’t have a D1 yet.
I think the code I have now should behave better than the D4v2 firmware. At least, it makes the adjustments smooth instead of sudden, it should be less prone to noise in the regulation pattern, and it should step back up faster if it ever needs to.
I cant compare either with the other throwers mentioned. I have compared it with a predator pro v2.5 warm and you cant even see the Predators hot spot in the D1’s……So to me, the D1 is more intense and larger hot spot as well(spill is certainly more wide and bright). What i will say is it(to me anyway and this is from a guy who’s preference is towards flood than throw) is a nice useful beam. Compared to some, the hot spot is quite large and bright spill in abundance(wide spill). With the great UI, its just so easy to dial down the power if it does overwhelm in close quarters.
There are some trees out front, maybe 150+yrds away(across street, behind houses). Using the D1, it of course lit them up, bot nothing crazy compared to dedicated throwers. I think the output is very usable, and from me who does not have that many uses for throwers…………
The D4 and D1 make a great team! Complement each other well.
Thanks! All I needed to know to add this on my list. For some reason I thought I couldn’t so I passed on the light. Now it’s sold out. I snooze I lose. Time to wait
